Author Topic: Interest Check: Dolch key caps group buy  (Read 116950 times)
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #100 on: Fri, 30 December 2011, 16:07:28 »
Damn Hazeluff you're putting in mad work (nice sig)! Thank you so much!
Like you said someone has to take the plunge and I'm hoping we can reduce the costs to make this economical and possible for people to use in future group buys.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #101 on: Fri, 30 December 2011, 16:42:16 »
Quote from: JesuswasaZombie;480545
Continuing work now. Can you check with Melissa about using SVGs that are of the "area" to be cut out. and not just a center line? Center line won't cut it cos the width is varied in the font.
Fight For Freedom. Stand with Hong Kongers
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #102 on: Fri, 30 December 2011, 22:17:22 »
Progress:
Guys let me know if something seems wrong.
[ Attachment Invalid Or Does Not Exist ] 36304[/ATTACH]
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #103 on: Fri, 30 December 2011, 22:30:01 »
Quote from: hazeluff;480781
Progress:
(Attachment Link) 36304[/ATTACH]
The shapes look fantastic.  They all seem to be a bit too thick though?  F looks a bit squished vertically.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #104 on: Fri, 30 December 2011, 22:34:12 »
Quote from: hashbaz;480787
I worked off this photo:
[ Attachment Invalid Or Does Not Exist ] 36310[/ATTACH]
In comparison I think W,E,F,N,M actually look too thick (you can see it in the corners). The others to me look as thick as it does in the photo. I think tho it might be because of how pixels are rendered. DPI/resolution is a bit low and I think some of the pixels rendered made it thicker, cos on my design (not exported) it looks ok.
Here's a larger resolution:
[ Attachment Invalid Or Does Not Exist ] 36309[/ATTACH]
Imo they look less "thick"/"chubby" when You look at it zoomed in. Tho I think W, O and M are actually a bit thick. I'll prob touch those ones up, but i don't know about the others. I need more feedback.
Note: I used consistent thickness for lines that I know are the same. (e.g The Vertical line of 'L' is the same thickness as the vertical line of 'M')
EDIT: Touched up W,O and M. (Quite subtle on W and M)
[ Attachment Invalid Or Does Not Exist ] 36311[/ATTACH]
« Last Edit: Fri, 30 December 2011, 22:52:30 by hazeluff »
Offline hashbaz
  • Grand Ancient One
« Reply #105 on: Fri, 30 December 2011, 23:21:15 »
Huh, interesting.  The legends in your reference image definitely look chubbier than the Cherry 2-shots I'm typing on right now.  I thought Dolch caps were the same, but maybe not...  Experts, what say ye?
On the other hand, it could be the fact that the image is slightly blurry when viewed close up.  My own close-up shots of Cherry keys also look chubby:
[ Attachment Invalid Or Does Not Exist ] 36316[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 36317[/ATTACH]
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #106 on: Fri, 30 December 2011, 23:28:00 »
I took that picture with the crappy iphone4 camera.  I could take the picture again with my 5D MkII later.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #107 on: Fri, 30 December 2011, 23:29:34 »
Quote from: hashbaz;480799
(Attachment Link) 36316[/ATTACH] (Attachment Link) 36317[/ATTACH]
Your close-ups aren't blurry, The edges seem quite well defined and yeah it looks a bit chubby (i.e similar to the photo I've been working off of). It might be a matter of perspective. If it's actually thinner when you look at it in real life and a few people agree I'll go back and change them. For now I'll leave it.
« Last Edit: Fri, 30 December 2011, 23:31:35 by hazeluff »
Offline hashbaz
  • Grand Ancient One
« Reply #108 on: Fri, 30 December 2011, 23:32:29 »
Quote from: hazeluff;480803
Your close-ups aren't blurry, The edges seem quite well defined and yeah it looks a chubby (i.e similar to the photo I've been working off of). It might be a matter of perspective. If it's actually thinner when you look at it in real life and a few people agree I'll go back and change them. For now I'll leave it.
If the images don't look blurry ... you need to go deeper.  The lines aren't crisp when viewed at full-resolution (not zoomed).
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #109 on: Fri, 30 December 2011, 23:39:12 »
Quote from: hashbaz;480804
Fairly clean.
Anyway, time for a break.
Please other people let me know if it looks "too thick". I'm siding with it probably is, I just want some more people to make sure.
Offline Forin
« Reply #110 on: Sat, 31 December 2011, 06:00:56 »
I'm interested in Dolch color scheme (grey) keycaps.
Ducky DK1087 MX Brown, Filco MJ1 Tenkeyless MX Blue, CM Storm MX Blue
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #111 on: Sat, 31 December 2011, 12:48:00 »
Someone posted a classified with amazing photo of a cherry keyboard:
http://geekhack.org/showthread.php?25555-NIB-Cherry-G80-2551HAD-with-beautiful-doubleshots
Totally illustrates how my lettering is too thick. Will go and work on that sometime.
Offline jwaz
  • * based mod
« Reply #112 on: Sat, 31 December 2011, 13:24:46 »
Guess they take Fridays off, I just left her a message...
« Last Edit: Sat, 31 December 2011, 14:04:54 by JesuswasaZombie »
Offline hashbaz
  • Grand Ancient One
« Reply #113 on: Sat, 31 December 2011, 13:50:27 »
Quote from: JesuswasaZombie;481043
Guess they take Fridays off, I just left here a message...
SP has been off since the 23rd I think.  But yeah, they do take Fridays off normally as well.
Offline DraJin
« Reply #114 on: Sun, 01 January 2012, 06:09:19 »
I'm interested.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #115 on: Sun, 01 January 2012, 20:30:02 »
Ok redid the images. They are thinner now.
First try:
  [ Attachment Invalid Or Does Not Exist ] 36437[/ATTACH]
Newest try:
[ Attachment Invalid Or Does Not Exist ] 36438[/ATTACH]
« Last Edit: Sun, 01 January 2012, 20:37:41 by hazeluff »
Offline litster
« Reply #116 on: Sun, 01 January 2012, 20:42:51 »
Thin is in!  Nice!
Offline DaemonRaccoon
« Reply #117 on: Sun, 01 January 2012, 20:44:52 »
The thin looks wonky, the R and P are too narrow, I'd change the width of the lines instead, while keeping the overall character width intact.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #118 on: Sun, 01 January 2012, 20:47:47 »
Quote from: DaemonRaccoon;481650
The thin looks wonky, the R and P are too narrow, I'd change the width of the lines instead, well keeping the overall character width intact.
By the way that is what I did...(Obv the overall character width gets shorter if I decrease the widths on line.)
Edit: Maybe I should of compensated for that...
How does this look?
[ Attachment Invalid Or Does Not Exist ] 36443[/ATTACH]
« Last Edit: Sun, 01 January 2012, 20:52:51 by hazeluff »
Offline hashbaz
  • Grand Ancient One
« Reply #119 on: Sun, 01 January 2012, 22:25:16 »
Those look fantastic.  Your SVGs have already kept their New Year's resolution to shed the chub.
« Reply #120 on: Sun, 01 January 2012, 22:27:45 »
Quote from: hazeluff;481652
How does this look?
(Attachment Link) 36443[/ATTACH]
That looks much better.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #121 on: Sun, 01 January 2012, 22:32:53 »
Quote from: DaemonRaccoon;481688
Aweshum!
I'll get on with the rest of the keys later = p. (not looking forward to writing "Page up" and "Page Down"...).
Offline jpm804
  • KeyCap Assasin
« Reply #122 on: Mon, 02 January 2012, 01:57:49 »
How does this look?
Looks good to me... :thumb:
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline mehkat1974
« Reply #123 on: Mon, 02 January 2012, 03:07:25 »
oh jpm you got the red one, cant believe I missed that group buy lol
HHKB Type-S / KBC Poker with reds
Offline aoya
« Reply #124 on: Fri, 06 January 2012, 21:16:54 »
Sorry if this has already been answered, but how close is this to coming to fruition?
Offline jwaz
  • * based mod
« Reply #125 on: Fri, 06 January 2012, 23:12:09 »
Hazleluff is working on the legends for the keys. When I have an estimate on the price per kit I'll post it in the OP and tally up the names and see if it is doable for a somewhat reasonable price.
Offline hashbaz
  • Grand Ancient One
« Reply #126 on: Fri, 06 January 2012, 23:46:02 »
Hazle: Did Melissa and/or cycloverid get back to you about the path vs. area SVG approach?
Offline jellowiggler
« Reply #127 on: Sat, 07 January 2012, 00:18:45 »
Interested.
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #128 on: Sat, 07 January 2012, 02:04:50 »
Quote from: hashbaz;485169
Cycloverid never got back to me. And I asked OP to ask melissa since hes in charge of this buy. = / Also want to check with OP if we're remaking the Moogle kit parts as well (They look close, and I don't think I can make it any better (The lines are thin)).
(I gotta take a break from making the SVGs, I've got 2 courswork due next friday)
Offline jwaz
  • * based mod
« Reply #129 on: Sat, 07 January 2012, 02:36:57 »
will post tomorrow morning with her response.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #130 on: Sat, 07 January 2012, 02:47:00 »
Quote from: JesuswasaZombie;485224
Cheers~
Offline laikaislost
« Reply #131 on: Sat, 07 January 2012, 03:39:32 »
Those look awesome Hazeluff!  Is the 'M' thicker than the rest though?
If the price ends up remotely reasonable, count me in for a set.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #132 on: Sat, 07 January 2012, 03:42:10 »
Quote from: laikaislost;485249
Good catch. I had made it thinner before I redid all the other keys. Will fix it on my end (won't be posting up a update till I finish a nother bunch of keys).
Thanks
Offline jwaz
  • * based mod
« Reply #133 on: Sat, 07 January 2012, 15:11:06 »
« Last Edit: Sun, 08 January 2012, 14:12:28 by JesuswasaZombie »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #134 on: Sat, 07 January 2012, 16:27:09 »
Quote from: JesuswasaZombie;485483
Would you mind if I posted it at Deskthority? Those guys might have some good insight.
I don't know why you need to ask.
Offline trax
« Reply #135 on: Sat, 07 January 2012, 18:38:33 »
Yes
For ALPS to please.
Switches tried so far
Cherry MX Red Blue Black Clear
ALPS White Black (fake)Blue
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline jwaz
  • * based mod
« Reply #136 on: Sun, 08 January 2012, 22:34:17 »
[ Attachment Invalid Or Does Not Exist ] 37039[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 37040[/ATTACH]
Here's a good comparison
Offline suprsmo
  • Sydney, Australia
« Reply #137 on: Mon, 09 January 2012, 04:21:38 »
I'd be keen for a set :)
Poker
QFR
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #138 on: Mon, 09 January 2012, 07:50:35 »
Quote from: JesuswasaZombie;486404
(Attachment Link) 37039[/ATTACH] (Attachment Link) 37040[/ATTACH]
Beautiful Photo.
I've noticed that:
-The arch in the A is too high
-The Leg of K is no far out enough
-Quotation marks are too thick
-slash needs to be slightly more angled(?)
-Question mark is too thick
- signs are too thick
-Comma needs a slighly longer thingy ( I have no idea what that bit is called? a tail?)
Did you scan the keyboard, cos it certainly looks like it >< cos thats perfect cos we don't get parallax error.
Offline Reptile
« Reply #139 on: Mon, 09 January 2012, 13:59:40 »
Quote from: Oqsy;459763
Not R3. Ugly.
What did R3 look like?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline hashbaz
  • Grand Ancient One
« Reply #140 on: Mon, 09 January 2012, 14:15:32 »
Quote from: Reptile;486728
I like the big, centered font, but the all-capital, bizarrely variable-width modifiers and such look bad.  Look at Control and Backspace.  wtf?
Offline Reptile
« Reply #141 on: Mon, 09 January 2012, 15:50:55 »
I still don't understand why it is so hard to get replica cherry font/symbols. I believe sixty on deskthority said he even had the real font but cannot share?
This bugs and baffles me at the same time lol
Offline jwaz
  • * based mod
« Reply #142 on: Mon, 09 January 2012, 15:58:05 »
I saw that post by Sixty as well and am not sure what he meant. Perhaps some sort of copyright issue?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #143 on: Mon, 09 January 2012, 16:02:51 »
Quote from: JesuswasaZombie;486823
Most Likely.
Offline hashbaz
  • Grand Ancient One
« Reply #144 on: Mon, 09 January 2012, 16:11:58 »
*sigh*
We should start a poll to convince Cherry to sell us new 2-shot sets (with center-stemmed modifiers and capslock of course).
Offline Reptile
« Reply #145 on: Mon, 09 January 2012, 17:48:36 »
I understand copyright issues but cmon no one has sourced it? Even if you changed one small thing you could get past that :evil:
Offline hashbaz
  • Grand Ancient One
« Reply #146 on: Mon, 09 January 2012, 22:36:41 »
Quote from: Reptile;486894
Maybe, technically.  You have to convince SP though. : /
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #147 on: Tue, 10 January 2012, 08:27:26 »
Anyway,
OP (I call him OP cos I can't remember his name correctly) has spoken with Melissa about making the font. Unfortunately it has to be a centerline for the font (i.e. Single thickness for the font). This means we won't get as much detail (and I have to "redraw" them).
« Reply #148 on: Tue, 10 January 2012, 08:28:23 »
Quote from: hashbaz;487034
What font is it, commercial licenses aren't usually that expensive...
Offline hashbaz
  • Grand Ancient One
« Reply #149 on: Tue, 10 January 2012, 11:31:09 »
It's a custom font, owned by Cherry.
