Author Topic: Problem with my Blackwidow media keys.  (Read 4879 times)
Offline tukkez
« on: Sun, 27 November 2011, 16:01:32 »
Hey, I have a little problem with my media keys. Whenever I have both iTunes and foobar2000 open, and try to use the media keys, for example if i press play/pause combination from my blackwidow, it starts playing music from iTunes, not foobar2000 like i would like it to. How do i change it so the media keys work to foobar2000, not iTunes ?
Oh, wrong sub Forum, can someone move this to the keyboards one?
« Reply #1 on: Mon, 28 November 2011, 18:48:04 »
I'd uninstall iTunes if I were you: It's horrid.
But that's just my opinion. Make sure foobar is listed as your "default" audio player. Also, closing iTunes will also probably fix the confusion. (make sure it's not runnig hidden in the tray somewhere)
But deleting it is certainly the best option, because it's horrid.
