Author Topic: Black Widow Ultimate wear off the black coat?  (Read 7518 times)
Offline ZorK
« on: Fri, 09 December 2011, 06:36:39 »
Hi there!
I just bought a black widow ultimate and I heard that the black coat is wearing off...And it will sure look very ugly...SO i am wondering:once it's starting wearing off,could I take it off all that black coating completely without deleting the letters?Cause not I would consider to take the keyboard back....
Thank you!
Offline himynameisbunny
« Reply #1 on: Fri, 09 December 2011, 08:00:55 »
Nope. The keys are completely translucent and are then coated with black rubber and then lasered off to create the letters.
If and when it does rub off look at getting a set of ducky shine keys, or even better, a set of Deck double shots.
Sent from my GT-I9100 using Tapatalk
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline ZorK
« Reply #2 on: Fri, 09 December 2011, 09:28:49 »
So the letters are, basicaly, a cut in the black coat???
 set of ducky shine keys, or even better, a set of Deck double shots...I am from Romania and I dont find DECK or DUCKY around here
« Reply #3 on: Fri, 09 December 2011, 16:03:01 »
Yes indeedy, that's exactly how they are made.
You will have to look into shopping internationally for them of course, but if it means it keeps your board alive longer who cares?
Quote from: ripster;467076
This mod post needs pics!!!
I know you're just pointing out that it's in the wrong section but if you want I can put my Data911 double shots on my BW and take some pics lol
[SIGPIC][/SIGPIC]
Offline Human
« Reply #4 on: Fri, 30 December 2011, 13:15:45 »
Quote from: himynameisbunny;467384
one thing Ts can be optimistic about, he should had mastered touch typing by the time the legends and coatings completely worn off.
Offline transcend3nt
« Reply #5 on: Sat, 07 January 2012, 04:16:59 »
anybody know how to get a set of ducky shine key caps?
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #6 on: Sat, 07 January 2012, 10:40:35 »
Why do people keep thinking the BWU keys are rubberized? They're just plastic. I've had mine for a couple months now, and there's no noticeable wear on the keys. I'm pretty sure people are thinking of the Lycosa, which had a major key wear problem and rubberized keys.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
