Author Topic: Ergonomic Tenkeyless keyboard  (Read 4607 times)
Offline afton
« on: Fri, 09 December 2011, 19:07:15 »
Does such thing exist yet?
I'm ordering MS Curve 3000, and before I saw the
numpad, need to know if such thing exist yet? :)
using: Filco Majestouch Tenkeyless MX Brown switch
Offline cbf123
« Reply #1 on: Fri, 09 December 2011, 21:57:06 »
Known quantity: Kinesis Advantage, Maltron dual-hand 3D, various secondhand options
Unknown quantity, but apparently now shipping: Truly Ergonomic Keyboard
Daily drivers are:
Microsoft Natural (the original, and still going strong)
Microsoft Natural Elite
Offline Kindari
« Reply #2 on: Sun, 11 December 2011, 12:50:46 »
Yes
truly ergonomic dot com - sorry I can't post links yet. I think they use Cherry MX Browns. They're just coming out, so I don't know how long before you can start ordering them.
Offline bbbbqq
« Reply #3 on: Mon, 12 December 2011, 00:30:12 »
Kinesis makes some: The Advantage (cherry), Maxim (domes), and Freestyle (domes)
Maltron makes one with Cherry switches, but it's ****ing expensive
Cherry Corp. makes one, the mx5000
Goldtouch is another adjustable board
IBM made the model M-15. Good luck finding one.
Offline purple_haze
« Reply #4 on: Mon, 12 December 2011, 03:25:34 »
ouch...i just died a little inside looking at that picture.  I went through 3 iterations of that keyboard and one iteration of the previous gen before succumbing to the mechanical keyboard bug.
Das Keyboard Silent S MX Browns | Filco Majestouch 2 MX Browns | Filco Majestouch MX Blues TKL
Offline shrap
« Reply #5 on: Mon, 12 December 2011, 14:13:02 »
You can change any normal rubber dome into a Tenkeyless:
http://tlb.org/keyboardchop.html
I've done it to three MS Natural Elites with varying success.
