Author Topic: Custom keycaps on a DAS?  (Read 2104 times)
Offline theQman121
« on: Sat, 10 December 2011, 17:40:08 »
I'm looking into getting a DAS Professional silent, but I'm interested in all the custom keycaps I'm seeing on this site, such as the StarCraft keys and Team Liquid keys. Would these fit onto a DAS keyboard, or are DAS keycaps shaped differently? Thanks for all your help!
Offline LEGITBALLIN
« Reply #1 on: Sat, 10 December 2011, 18:09:50 »
im pretty sure any cherry mx keycaps will work with it you just have to make sure they are the same size modifiers (etc) and row would probably also come in play
V-tec just kicked in yo\'
Offline N8N
« Reply #2 on: Sat, 10 December 2011, 18:36:16 »
I think Das keys are the same profile as Filco, so if you keep that in mind there's still plenty of options.
« Reply #3 on: Mon, 12 December 2011, 01:02:02 »
Yeah, if you want to mix cherry/costar key profiles, you'll have a bumpy keyboard.
