Author Topic: Broken Filco Ideas?  (Read 3947 times)
Offline Ekaros
Broken Filco Ideas?
« on: Mon, 12 December 2011, 13:33:47 »
My Filco Majestouch stopped working. It doesn't work either in PS/2 or USB, when I connect it via PS/2 the lock lights light up and down, but it doesn't register anything or the locks work after connecting.
Any ideas?
It's bit over a year old now and I haven't poured anything in it...
Tested on both USB and PS/2 on two different computers, PS/2 computer which it stopped working still works with my old MS Internet Keyboard...
PS. I need to bring some decent board here too...
« Last Edit: Mon, 12 December 2011, 14:04:47 by Ekaros »
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Broken Filco Ideas?
« Reply #1 on: Mon, 12 December 2011, 23:21:43 »
Phantom!
Me, I'd see if I could repair it with an ohmmeter and some solder (and maybe some switches?) but clearly the best idea is to use the case for a phantom.
Edit: if it's not a tenkeyless, I'd add a tenkey in there as well. you might be able to reuse the old board for this, depending on the width of the copper traces, etc.
« Last Edit: Mon, 12 December 2011, 23:24:51 by dorkvader »
Offline Tony
Broken Filco Ideas?
« Reply #2 on: Mon, 12 December 2011, 23:55:01 »
The lock lights up means there is still good physical circuit connection but not in logical order. Perhaps the cable from usb to the board has been damaged.
Offline Ekaros
Broken Filco Ideas?
« Reply #3 on: Tue, 13 December 2011, 04:28:43 »
Full sized one. Not sure about how long warranty Keyboardco offers...
[SIGPIC][/SIGPIC]
Offline Ekaros
Broken Filco Ideas?
« Reply #4 on: Tue, 13 December 2011, 09:39:52 »
I have to find multimeter.
Anyone have idea if it's possible to replace Filco's controller with teensy?
[SIGPIC][/SIGPIC]
Offline alaricljs
  • I be WOT'ing all day...
Broken Filco Ideas?
« Reply #5 on: Tue, 13 December 2011, 10:44:41 »
Yes it is... at least with the 87key.  The full size might require the teensy++ for more IO pins.
Filco w/ Imsto thick PBT
Offline SmallFry
Broken Filco Ideas?
« Reply #6 on: Thu, 15 December 2011, 09:00:37 »
Otherwise, I'll have my AIKONs for sale soon. That would allow you to remap it and make a Fn layer etc.
Offline Ekaros
Broken Filco Ideas?
« Reply #7 on: Thu, 15 December 2011, 09:40:05 »
Hmm, yep I likely have to go with some new controller. If I can't source an other Filco one... Have to find out first if it's not the cable.
[SIGPIC][/SIGPIC]
Offline Ekaros
Broken Filco Ideas?
« Reply #8 on: Fri, 16 December 2011, 10:42:06 »
Tested with multimeter, the cable connects all the pins...
I would likely get teensy fastest, still not sure which one is easisest for noob...
[SIGPIC][/SIGPIC]
Offline Ekaros
Broken Filco Ideas?
« Reply #9 on: Sun, 18 December 2011, 11:47:50 »
This is very weird, once again it does work. Might be the cable. Have to test it in place when it stops once again.
[SIGPIC][/SIGPIC]
