Author Topic: Which MX switch is most like rubber domes?  (Read 34456 times)
Offline Oobly
Re: Which MX switch is most like rubber domes?
« Reply #50 on: Tue, 10 March 2015, 06:36:38 »
well, I'm typing on the filch mx reds right now. It seems ok and it's very light. great for typing as it's pretty easy. I think I may keep this keyboard just for typing purposes. As you can probably tell, I'm just typing to type in this reply. I may have to find osx keycaps to use with my iMac.
any ideas where to get them?
thanks
Buy this base set and the Mac kit: http://www.pimpmykeyboard.com/deals/1976/
Just 2 days left :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline xrayos
« Reply #51 on: Tue, 10 March 2015, 07:54:37 »
^ thanks. I think I found what I was looking for with WASD. I can get custom keycaps for the modifiers PLUS the F-keys for brightness and volume control.
