Author Topic: .  (Read 3018 times)
Offline mr_a500
« on: Thu, 22 December 2011, 17:52:42 »
 :blank:
« Last Edit: Wed, 04 July 2018, 09:29:47 by mr_a500 »
Offline mr_a500
« Reply #1 on: Sat, 24 December 2011, 12:54:54 »
 :blank:
« Last Edit: Wed, 04 July 2018, 09:30:13 by mr_a500 »
Offline IvanIvanovich
  • Mr. Silk Underwear
Anybody here use Logic Pro and/or write music?
« Reply #2 on: Sat, 24 December 2011, 17:27:12 »
I used to write and record quite a bit, but after years of touring and dealing with the 'biz I got put off and more or less quit. I just dj now, as I find it more amusing and less demanding, plus the pay is usually better.
 I've never used that software, but cakewalk, cubase, reason and a little pro tools. Not sure what help I could give but I like your sample.
Offline Fast_Fingers
« Reply #3 on: Mon, 02 January 2012, 22:20:54 »
When I had a semester of computer music, I distinctly remember Logic being much more intuitive and easy to do complex MIDI arrangments than Pro Tools. Since I'm usually using a PC, I guess I'll try Reaper instead.
What's your setup? What monitors do you have?
Offline mr_a500
« Reply #4 on: Tue, 03 January 2012, 08:51:00 »
 :blank:
« Last Edit: Wed, 04 July 2018, 09:30:37 by mr_a500 »
