Author Topic: Rosewill vs Leopold.  (Read 5374 times)
Offline piken
« on: Tue, 27 December 2011, 09:12:17 »
I have made the decision to get one of the following and want to know the GH thoughts on them.
Rosewill with browns or reds
Leopold with browns or reds
I don't mind full size or tenkeyless (That is not a decision factor.)
I have 2 Filco boards right now and I am very happy with them, but the boards are expensive and I want to try an reduce the cost of the new board if possible.
I know Rosewill are made by costar and even the control board is marked filco, so I know the quality of the board.
How do the Leopold boards compare. I have heard mixed reviews of them on the forms here and can't determine if I should take the leap to try one.
I will be able to get either of these boards for the same price, about 115 shipped. So I would prefer to make the purchase based on quality.
Are there any differences between these boards that can be pointed out?
Offline Human
« Reply #1 on: Tue, 27 December 2011, 09:58:14 »
If price factor is being factored out, over 90% of ppl in GeekHack will sure ask you go for Rosewill as its quality is more assured.
Leopold's built quality is also quite superb from what I being heard so far. The major downside/risk are the stiff stabilisers and some random problems on controller.
p/s: If by any means you are looking for higher KRO(over 6) over USB, Leopold are for you then.
Offline piken
« Reply #2 on: Tue, 27 December 2011, 10:54:07 »
It is my understanding that the Rosewill is the same as the original majetouch.
Is this correct or is it the same as the majetouch 2? The boards I currently have are Majetouch2 and I like them a lot. But not really sure of the differences between the 2.
Offline noodles256
  • le legendary
« Reply #3 on: Tue, 27 December 2011, 10:55:42 »
i like rosewill
AF | Ducky YOTD |
Offline ktkr
« Reply #4 on: Tue, 27 December 2011, 11:05:47 »
Do you want a fugly logo? If yes, go Rosewill.
Offline piken
« Reply #5 on: Tue, 27 December 2011, 11:08:43 »
Quote from: ktkr;478388
Letting a logo design make your decision in which board to buy is pretty vain.
Offline Human
« Reply #6 on: Tue, 27 December 2011, 11:24:01 »
Quote from: piken;478393
Not really, at least at GH.
Some random picture I saved from GH last time.
[ Attachment Invalid Or Does Not Exist ] 36005[/ATTACH]
Offline bienc
« Reply #7 on: Tue, 27 December 2011, 11:45:30 »
I have no problems with the Rosewill logo. Looks fine to me, if it a bit big. I do love the red board behind the keys though. Brings everything together nicely.
| Rosewill RK-9000RE |
Offline NorrisB
« Reply #8 on: Tue, 27 December 2011, 11:47:47 »
Yes the Rosewill is a clone of the original majetouch.  Is there anyway to get rid of that fugly Rosewill logo?
Offline piken
« Reply #9 on: Tue, 27 December 2011, 11:49:07 »
Quote from: NorrisB;478423
What are the differences between the original majetouch and the majetouch 2?
Offline dimoniy
« Reply #10 on: Tue, 27 December 2011, 12:17:23 »
Both boards are good, so don't over-think it. Just pick the best deal you can find.
Tt eSPORTS MEKA G1 | Das S Pro Silent | Leopold FC500RR/AB
All of them full-size. I love my numpad!
Offline NorrisB
« Reply #11 on: Tue, 27 December 2011, 12:22:21 »
Quote from: piken;478424
The LEDs are a little dimmed on the new one but thats all she wrote.  Heres a post from "opsy" that summarizes the differences:
Except for external appearance stuff and the detachable cables, it's identical to a Filco. The only differences I've found from my previous tenkeyless mj2 are:
1. Detachable mini USB to USB cable and mini usb to PS/2 cable. (point rosewill)
2. Logo(half a point Filco)
3. Painted plate (wash)
4. Raised legends on the key caps (thicker infill?) (wash, both are thin flimsy junk caps, but if it IS infill on the Rosewill, it will likely be a bit tougher than Filco's trash keycaps)
5. No rubber "condoms" on the fold-out feet. (point Filco)
*6. Numpad present.
*7. MX blues
« Last Edit: Tue, 27 December 2011, 12:27:46 by NorrisB »
Offline piken
« Reply #12 on: Tue, 27 December 2011, 13:12:09 »
Quote from: ripster;478466
You mean Leopold vs Filco Gen 2.
That was good info to know, but I was trying to find out the difference between my majestouch2 and the majestouch to determine if I loose anything going with the rosewill over the leopold, or saying screw it and buy the majestouch2 ninja with browns for more money and call it a day.
Offline telepete
  • Jedi Knight and friend of Captain Solo.
« Reply #13 on: Tue, 27 December 2011, 17:26:22 »
Never used a Leopold. I like my Rosewill tho.
Don't you wish Carnifex was at your side?
Offline jellowiggler
« Reply #14 on: Tue, 27 December 2011, 19:22:04 »
Quote from: ripster;478481
Majestouch Gen1/Gen2 and the Rosewill Gen1/Gen2 are two separate keyboards.  Same OEM does not mean same keyboard.
For example iPads are made by many OEMs which make other tablets.
It is true that oems build many products to different specs in the same facility.
But the Rosewill boards actually say filco on the controller pcb, and the pcb of the keyboard.  There is definitely a closer link than say a Samsung and Sony 40" LCD tv. (same glass, different processing)
Maybe they built more boards than filco was willing to buy?
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline Greenbean
« Reply #15 on: Tue, 27 December 2011, 20:03:43 »
Quote from: ripster;478647
Just buy the Ninja.  You won't get any street cred with a Rosewill.
Although I DID just learn a different way to cover up that fugly logo from my buddies at OCN!
(Attachment Link) 36040[/ATTACH]
I don't get it.
You can always paint the board and hope for the best.
Offline jkercado
  • Green XM clickclacker
« Reply #16 on: Tue, 27 December 2011, 22:37:57 »
Street cred? Wtf, we're talking keyboards, you nerds. Me included.
Sent from my Samsung Focus using Board Express
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline scarhawk
« Reply #17 on: Tue, 27 December 2011, 23:08:22 »
I got a Rosewill yesterday. You could always just put a sticker on it. Not a big deal.
Offline mouse.the.lucky.dog
« Reply #18 on: Wed, 28 December 2011, 03:04:50 »
Being a geek means that you don't give a flying f*** about street cred. In fact you get more street cred for blowing off the street cred then you lose for the Rosewill.
« Last Edit: Wed, 28 December 2011, 07:04:52 by mouse.the.lucky.dog »
Offline jkercado
« Reply #19 on: Wed, 28 December 2011, 14:32:34 »
Quote from: ripster;478763
Speak for yourself.
Sent without a nerd default mobile setting.
Nerd. And proud of it. Some people here are in denial. Hehe.
Offline jkercado
« Reply #20 on: Wed, 28 December 2011, 15:39:32 »
Quote from: ripster;479155
Hey, you learned how to turn off your Mobile sig!
Congrats!
Uh, I posted that from my PC. >_> :becky:
Who's Becky, anyway?
Offline noodles256
  • le legendary
« Reply #21 on: Wed, 28 December 2011, 15:41:49 »
Quote from: jkercado;479157
he meant benny hanna
AF | Ducky YOTD |
Offline jkercado
« Reply #22 on: Wed, 28 December 2011, 16:01:50 »
Quote from: noodles256;479159
No, this ==> :becky: is called : becky :.
Offline jkercado
« Reply #23 on: Wed, 28 December 2011, 16:39:44 »
My looney bun is fine, Benny Lava.
Offline jkercado
« Reply #24 on: Wed, 28 December 2011, 17:55:33 »
Do you have more detailed info?
Offline piken
« Reply #25 on: Thu, 29 December 2011, 07:12:14 »
Quote from: ripster;479199
You sure go off topic a lot.
Did I mention the "Leopold wait" idea?
No you did not, but I read it yesterday in another post by you. I am thinking of waiting till Feb to buy the board now to see if they do release a new model.
Offline Zamorph
« Reply #26 on: Thu, 29 December 2011, 12:26:03 »
1000 hz over USB for Filco - 1ms delay..
 Whats the rate for a leopold?
Offline Human
« Reply #27 on: Thu, 29 December 2011, 12:34:43 »
Quote from: Zamorph;479660
Not stated(but normal USB mouse is 250Hz) but who really care? Like you can type faster than it, or even notice it?
Or if you are still skeptical bout it, better use PS/2 connection, no polling involved.
Offline scarhawk
« Reply #28 on: Thu, 29 December 2011, 22:01:22 »
Just got my RK-9000 in the mail today (my first mechanical KB) and damn am I happy with it :D
Offline iBro
« Reply #29 on: Thu, 29 December 2011, 23:29:43 »
You are speaking to a forum where many of the members spend 100$+ on new colored key caps to replace the perfectly good key caps that are on their potentially overpriced keyboard.
Vanity is practically required here.
Unicomp Space Saver (buckling spring) Silicon Graphics (dampened cream alps) KBC Poker (ghetto reds)
Offline TheProfosist
  • Custom Layouts Only!
« Reply #30 on: Sat, 31 December 2011, 05:33:55 »
Quote from: jellowiggler;478641
The new ones dont say filco that was the v1
Offline lightsout714
« Reply #31 on: Sat, 31 December 2011, 12:00:25 »
Quote from: iBro;480006
Lol I agree.
