Author Topic: Going from Cherry Black switches?  (Read 1741 times)
Offline scarlatch
« on: Wed, 28 December 2011, 12:41:02 »
About 4 years ago, I purchased a Steelseries Steelkeys 6G Keyboard, which I believe has Cherry Black switches.  This was my first experience with a gaming keyboard, and I instantly fell in love with the feel of a mechanical keyboard.  Now, I'm in the market for a new mechanical keyboard and I ended up on this site.  I took a look at the Mechanical Keyboard Wiki and found a lot of great info there.  However, in my search, I'm looking for a suggestion.  I'm guessing most wouldn't recommend starting with Cherry Black switches, and I'd like to try a different kind of switch.
So, what switch would you recommend to someone that has gotten used to Cherry Black switches but would like something more typing-friendly?  I'm at a point in my life where I'm doing a lot of gaming AND a lot of typing for school and work, so I'm hoping to make this next purchase a good one.
Thanks in advance.  Love the web site and community!
EDIT:  As a side note, it's possible that my assumptions about the keyboard are completely wrong, as I'm still among what I'd consider the uninitiated when it comes to the world of mechanical keyboards.
Offline o2dazone
« Reply #1 on: Wed, 28 December 2011, 12:45:24 »
Blues area tactile and clacky. Because of this, they are a great typist switch, but for gaming, they're too noisy and tactile (from both reading what other people have said, and my personal experience). I found Browns to be a nice mixture between typing and gaming. I've never tried reds, but blacks were great for gaming. Topre keyswitches definitely require the most work for gaming, but I got used to em after a while (and ended up being quite good for gaming with a lot of hotkeys, like RTS's, MMO's, etc)
Offline Greenbean
« Reply #2 on: Wed, 28 December 2011, 14:29:38 »
If you like the linear feel of your MX Blacks, I would say the best option would be to purchase some MX Reds because they will be quite a bit lighter. Thus, typing becomes less of an effort and possibly faster.
Do you want a tenkeyless or full-sized keyboard?
Offline scarlatch
« Reply #3 on: Wed, 28 December 2011, 17:46:26 »
Quote from: Greenbean;479113
Presently, I'd prefer a full-sized keyboard.  Still find myself using the numeric keypad quite a lot for data entry.
Offline fusedpro
« Reply #4 on: Thu, 29 December 2011, 09:36:06 »
What do you like about the blacks and what do you dislike?
I personally use blues for both typing and gaming. One, because it is the only keyboard I have and two, because I think it feels fantastic. With that, the majority of people will say that blues are one of the best for pure typing, but in the end it all comes down to personal preference.
If you like the linear feel (smooth depression throughout the keystroke) of blacks, but not how much force is required to push the key down, then give reds a shot. Linear and light.
If you think you're missing some tactility (a small bump before key activation), then grab browns, blues, or clears. Browns have a slight tactile bump, but many claim they blow right through it when typing furiously, so it basically becomes a gritty linear switch. The bump is still there, just not very pronounced. Blues have a much more noticeable bump and a satisfying click noise. Clears are essentially blues without the click, maybe slightly heavier (but not black heavy).
Hope that dumbed down version helps.
Offline scarhawk
« Reply #5 on: Thu, 29 December 2011, 22:40:41 »
Get Cherry MX Blues. They're a bit noisy but they're not as bad as some people make them out to be. They're also the most common switch so you'll have lots of options to choose from. Personally I got a Rosewill.
