Author Topic: Custom Keycap Ideas Thread - all ideas welcome  (Read 1664965 times)
Offline blastoid
Re: Custom Keycap Ideas Thread - all ideas welcome
« Reply #900 on: Thu, 26 March 2015, 12:36:13 »
Looks good.  I'm not sure how I feel about the colorway, though.  It would probably look a lot better on an actual set of keys.  I also don't see a caret symbol or greater than symbol.  Is that deliberate?
It's deliberate. Bear in mind this is only a keyset, not an actual map. It's based on a keyboard someone found and posted here. And I'm not sure about the colors either. The keyboard-layout-editor.com link is above, feel free to play around with it.
Offline TalkingTree
    • My projects
Verbose Blank
« Reply #901 on: Thu, 26 March 2015, 15:58:27 »
Verbose Blank.
Offline derezzed
Re: Verbose Blank
« Reply #902 on: Thu, 26 March 2015, 23:28:14 »
Verbose Blank.
I like it.  This set would be great for a keyboard at the office.  The space bar looks too empty.  Consider adding a legend that reads "This space left intentionally blank".  Or adding that to the case, below the space bar.
« Reply #903 on: Sat, 28 March 2015, 01:53:01 »
Verbose Blank.
If the spacebar said SPACEBAR it would be perfect.
Offline TalkingTree
    • My projects
« Reply #904 on: Sat, 28 March 2015, 09:06:43 »
Ok, let's see what spacebar wins.
Offline derezzed
« Reply #905 on: Sat, 28 March 2015, 09:34:29 »
I think my idea sounds better than the actual execution.  There's just too much text.  I like "this side up" but it doesn't really fit with the them.   "Also blank" is good but I think the larger font makes it stand out too much.  I think "Spacebar", "Also Blank", or simply "Blank" in the same font size as the rest of the keys would work.  Or maybe go back to your original design with no legend on the spacebar.
Offline Dihedral
  • Mostly Harmless
« Reply #906 on: Sun, 29 March 2015, 05:10:29 »
I like 'Also Blank'
Offline ttzhou
  • in your base, belonging
« Reply #907 on: Mon, 06 April 2015, 10:07:18 »
Not sure if mentioned before but
but in a darker red would be an amazing keycap (red legend on black cap).
<--- huge berserk fan.
Offline Eremox
« Reply #908 on: Tue, 07 April 2015, 06:14:39 »
Why hasn't there been a group buy with emacs keycaps? I mean there are vim ones...
If image is broken then try: http://imgur.com/zuGCWEE
I do know that it's not the prettiest key design but i bet some of you more experienced could refine it. Both the colors and the logo.
I hope that someone will be inspired to start a GB. Or atleast a pool on massdrop for some different designs.
« Last Edit: Tue, 07 April 2015, 07:02:53 by Eremox »
Leopold FC750R | Func KB-460
Offline ttzhou
« Reply #909 on: Tue, 07 April 2015, 09:43:00 »
Because vim is superior.  :thumb: [/half kidding]
Joking haha, don't wanna start an editor war :P I like the keycap design actually!
Offline do_Og@n
« Reply #910 on: Wed, 08 April 2015, 07:48:41 »
I second this motion!!! And any that appose better have guts. ;)
Offline ttzhou
« Reply #911 on: Wed, 08 April 2015, 23:47:18 »
i actually have an image of this on a GON NS87 with black housing, white or skyblue side leds, and black otaku keycaps. it would look like the dragonslayer...
gonna go buy some lottery tickets now and pray.
Offline andCoffee
« Reply #912 on: Mon, 13 April 2015, 14:58:46 »
I'm new to the mechanical keyboard thing, and I've really taken a liking to it.  I decided to mess around a bit and create my own mockup of a keycap layout.
I call it PRESTIDIGITATION, and it would be a curved profile SA set, made with doubleshot ABS (all of the colors used on the top of the keys are based on ABS samples.  The sides of the keys are just darkened to give depth to the image).
I think it would be best with symbols for the modifiers, but I didn't have the resources available to create symbols.   Also, I use a TKL on a Mac, hence the layout.
It's based on this typewriter that I like (but know nothing about):
I'll try to finish it up if people seem to like it enough.
« Reply #913 on: Mon, 13 April 2015, 15:54:31 »
Looks like Commando or Commando with Penumbra alphas.
Offline Giorgio
« Reply #914 on: Fri, 24 April 2015, 01:54:56 »
What about a green vim keycap in cherry profile?
I would like it to be made by gmk, but in that case it would have a text only legend. Alternatively we could use a Taiwanese maker and have a dye sub legend with the vim icon.
I suggest the esc and the caps lock key.
There have been many successful gb in spherical profiles made by sp.
Offline Nai_Calus
  • CLACK
« Reply #915 on: Tue, 28 April 2015, 22:51:59 »
Anyone have any thoughts on this?
http://www.keyboard-layout-editor.com/#/layouts/2e031b67aa1e70f80395ed5f01f598bb
(The colours look better together IRL, they were picked by a window getting natural daylight using a color ring.)
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline Bloo
« Reply #916 on: Thu, 30 April 2015, 14:56:31 »
WIDE AWAKE
Using primaries and their compliments to keep people fom falling asleep at their machines:
ON on BO
RDA on YCE
VCS on RR
You would buy separate alpha, mod, and esc/return sets so that people could mix and match them.
Offline Snarfangel
« Reply #917 on: Thu, 07 May 2015, 14:57:42 »
I don't know if it's already been suggested (only to page 18 of the thread  :p ) but how about:
That way, when it says "Press CTRL-ALT-DEL" I can hit just one button.
Offline Dihedral
  • Mostly Harmless
« Reply #918 on: Fri, 08 May 2015, 12:16:14 »
Sort of like danger zone colour - I call it Ocean Basalt. I think the label colour could be changed - if you want to play around with it then look at this link.
Offline Dihedral
  • Mostly Harmless
« Reply #919 on: Tue, 12 May 2015, 10:47:23 »
Anyone :P
Offline andCoffee
« Reply #920 on: Mon, 25 May 2015, 21:19:40 »
Any F1 fans?
Got bored and threw this together:
Based on:
With the rev lights from the new screens for this season:
Offline TalkingTree
    • My projects
« Reply #921 on: Tue, 26 May 2015, 02:36:34 »
That's a nice one, althought there are a few things you should consider.
1) The Ferrari logo is copyrighted.
2) Most layouts include up to TLK keys.
3) You should *really* consider a checkered flag keycap, maybe the Esc key.
Offline andCoffee
« Reply #922 on: Tue, 26 May 2015, 05:02:12 »
Thanks, and yeah, I didn't really plan on actually carrying it all the way to GB status myself, so what were originally Apple keys were changed to Ferrari logos and the rest of the TKL was removed just for ease of design.
Thanks for the feedback though.  Checkered flag would be great.
Offline lucaslink
« Reply #923 on: Wed, 27 May 2015, 20:58:34 »
discovered keyboard layout editor and had some fun.
can't stand 98% of the typefaces on keyboards so i stuck in some of my own.
this is 'karla'. a font from googlefonts, similar to some of my paid favourites.
front printing cause its rad.
pastelled row 1 for quicker home row repositioning.
discovered skull squadron. skull squadron envy.
DSA w/ the standard engravers gothic typeface.
more envy.
and last but not least DSA w/ Karla. i want these ones. bad.
Offline Heliobb
« Reply #924 on: Sat, 30 May 2015, 05:59:09 »
  <- nice one
Novatouch TKL - Leopold FC660C - PBT my life.
Offline Snarfangel
« Reply #925 on: Sat, 30 May 2015, 12:00:40 »
I think that uniform profile keysets should offer a child deal option of 1U keys for every keycap that is normally larger (tab, shift, enter, \|, ctrl, etc). That way, people who are into extreme reordering of their keyboard can pop one of these anywhere.
And I'm not just saying this because I want to outfit my Maltron with some snazzy colors.
Offline Skedader
« Reply #926 on: Sat, 06 June 2015, 00:13:34 »
Alright here it is. The most slickest keycaps you'll ever lay your eyes on.
PBT: You know of it, you've heard of it, you've read the reviews of it, a keyboard can't be slick without this material.
OED OEM profile: Its the simple touch that instead of having others think you're insane will have them be insane for you.
Cherry MX: The top of the line, you can't be seen without it.
Double shot: The new mysterious craze that everyone is talking about.
Black Color: The same color as a tuxedo, it's just that classic jet black color that makes others say that's a man who knows what's up.
Translucent backlit characters: This is where you fluff your feathers and release your inner peacock.
Oh, you think this is sick?
BAM
Side-printed characters: watch the ladies line up.
And there you have it! The slickest keycaps around. Now if only someone made these and I could purchase them :(
« Last Edit: Sat, 06 June 2015, 00:44:37 by Skedader »
« Reply #927 on: Sat, 06 June 2015, 00:21:17 »
OED profile: Its the simple touch that instead of having others think you're insane will have them be insane for you.
Oxford English Dictionary Profile?
Offline Skedader
« Reply #928 on: Sat, 06 June 2015, 00:45:29 »
...yes
Offline zarrx
« Reply #929 on: Mon, 08 June 2015, 09:25:52 »
My buddy was interested in getting a group started for winky key set of black arch linux keys that are for back lighting. I was also thinking of a child deal with an escape key. SP is probably the best place to outsource if I did a group buy... not really where to start but if someone thinks this sounds like an interesting idea I'd love to know.
Offline zarrx
« Reply #930 on: Mon, 08 June 2015, 09:42:46 »
sounds sick with just that, I wanna see backlit side printed keycaps
Offline MAR82
  • Keyboard Addict
« Reply #931 on: Mon, 08 June 2015, 09:45:41 »
The problem is that it would only work if the LEDs are towards you and not towards the "top" of the switch
Offline zarrx
« Reply #932 on: Mon, 08 June 2015, 10:09:51 »
True. you could reverse switches, and it seems cherry is going to switch to clear housing same with kailh (i believe they have there made to buy already).
Edit: with the work needed to make the set work on most keyboards it would be pretty niche
« Last Edit: Mon, 08 June 2015, 10:18:53 by zarrx »
Offline Skedader
« Reply #933 on: Wed, 10 June 2015, 19:26:36 »
So I got the keycaps idea from the CM Storm Quick Fire Rapid-Si
http://gaming.coolermaster.com/en/products/keyboards/rapid-si/
The only thing though is that these aren't PBT :/
Offline Lepidus
« Reply #934 on: Fri, 12 June 2015, 23:52:26 »
I thought DSA profile, not very sure thou. They kinda look like this Jukebox set, just a little more blue/green.
Offline do_Og@n
« Reply #935 on: Sat, 13 June 2015, 16:03:00 »
I dig it!
Offline Bloo
« Reply #936 on: Mon, 15 June 2015, 10:29:50 »
I dig it!
Seconded
Offline EscapeVelocity
  • Antiquarian
« Reply #937 on: Wed, 17 June 2015, 10:45:18 »
How about a "Bakelite" set? or a "Bakelite" & Ivory set?
Old school typewriter style.
Bakelite has a dark brown black appearance, usually with high polish (glossy)
Offline rsbseb
  • -Horned Rabbit-
« Reply #938 on: Sun, 21 June 2015, 21:49:47 »
WIDE AWAKE
ON on BO
RDA on YCE
VCS on RR
Colorful yes! but it makes me want to go eat some paste and take a nap. I'm sure there are plenty who would love this scheme and it certainly has a "fun" childish vibe to it but it would have me rattled.
Offline rsbseb
  • -Horned Rabbit-
« Reply #939 on: Sun, 21 June 2015, 21:54:00 »
Absolutely! the ultimate in vintage. I personally like shiny keys especially very dark brown ones. Ivory wold be the perfect compliment.
Offline baldgye
  • Will Smith Disciple
« Reply #940 on: Sat, 11 July 2015, 03:55:44 »
Any F1 fans?
Based on:
Huge F1 fan here, but that looks awful lol
Offline turboloser
« Reply #941 on: Thu, 06 August 2015, 16:49:18 »
I had an idea for a set, but I need a little information.
Does anyone know what SP color codes were used for Miami Twice?
Offline MAR82
  • Keyboard Addict
« Reply #942 on: Fri, 07 August 2015, 04:26:58 »
I'm not sure, but if I had to guess it would be BFQ for blue and RCR for pink.
You can always share you idea now and readjust the colors later on.
Offline turboloser
« Reply #943 on: Fri, 07 August 2015, 06:26:25 »
Thank you.
Not sure what to call this, but it was just a quick idea I had.
Offline MAR82
  • Keyboard Addict
« Reply #944 on: Fri, 07 August 2015, 07:16:36 »
Thank you.
The first name that came to mind was something like "Chocolate Valentine". But after thinking about it, I think "The Shocker" would also be very fitting
« Last Edit: Fri, 07 August 2015, 07:18:16 by MAR82 »
Offline Raptorsatan
  • What's that noise?
« Reply #945 on: Mon, 10 August 2015, 14:36:11 »
Why not a set of laser engraved/embosed keycaps with a 1914 engravers script. Something for the Fountain Pen Enthusiasts among us as well.
CM Quickfire Mx Blue // Filco MJ1 NKRO 104 Mx Blue
Clakcity Clackity Clackity....
Offline apolotary
  • Кто-нибудь купите мои клавиатуры ;__;
« Reply #946 on: Thu, 20 August 2015, 12:14:37 »
Has anyone tried to incorporate real/fake gems in their keycaps?
« Reply #947 on: Sat, 22 August 2015, 00:15:54 »
Not keycaps, but it was one of tp4's more artistic moments: https://geekhack.org/index.php?topic=35288.35
Offline krbuck
« Reply #948 on: Thu, 27 August 2015, 16:29:46 »
I'm a huge formula 1 fan; I'd love to see Williams Martini themed caps. I'd think it would be fairly easy to avoid the copyright issue.
POK3R - Brown Cherry MX
Offline jaffers
Re: Verbose Blank
« Reply #949 on: Thu, 03 September 2015, 05:00:59 »
Verbose Blank.
Looks cool, probably a little busy but still cool
