Author Topic: Reversible inline USB conversion  (Read 4921 times)
Offline yifanzhang
« on: Thu, 05 January 2012, 19:06:43 »
Bought a PS/2 -> USB converter today, and the keyboard plug was broken, rendering it useless.  Or did it?  It quickly went under the knife.
The plastic was soft and easily cut with a box cutter.
[ Guests cannot view attachments ] 36658[/ATTACH]
[ Guests cannot view attachments ] 36659[/ATTACH]
The controller on a 42H1292 (fixed, straight cable).  There have been a lot of size reductions in the controller over the production of these boards.
[ Guests cannot view attachments ] 36660[/ATTACH]
Precrimped USB cable from another IBM 'board.  Connectors have been backed out of their housing.
[ Guests cannot view attachments ] 36661[/ATTACH]
Converter's been soldered on and potted in epoxy (to compensate for poor soldering).
[ Guests cannot view attachments ] 36662[/ATTACH]
Wrapped in electrical tape.
[ Guests cannot view attachments ] 36663[/ATTACH]
Each individual connector you saw before has been wrapped in electrical tape and plugged in.  Afterwards, a strip of epoxy was added to keep them together.
[ Guests cannot view attachments ] 36664[/ATTACH]
The line installed.  Note that the lines aren't color coded correctly.  Sorry.
[ Guests cannot view attachments ] 36665[/ATTACH]
This little "mod" took about 20 minutes, and is fully reversible.  You can swap between PS/2 and USB cables at your heart's desire.  This could very easily be done instead in a ferrite housing for external cables (SDL connectored M's) if you don't have a fixed cord model.
