Author Topic: Disabling Windows Key on Keyboard connected by PS/2?  (Read 1270 times)
Offline Anyguy4321
« on: Fri, 06 January 2012, 13:24:05 »
Hi, I just got the Leopold Red tenkeyless keyboard from Elitekeyboards and for some reason all the registry fixes to disable the windows key that I've used successfully on previous keyboards do not work and I can't find an answer for this problem.  Does anyone know if its a unique feature of the ps/2 port that you cannot disable the windows key?  I would prefer to keep my full n-rollover.
Thanks in advance and if this is the wrong place to post this, I apologize to the mods.  I did not see another forum area where this seemed appropriate.
Offline Anyguy4321
« Reply #1 on: Fri, 06 January 2012, 13:35:26 »
**edit** Whoops, figured it out.  Sorry for the seeming spam.
