Author Topic: Keyboard shortcut to increase/decrease system volume in Windows 7  (Read 18829 times)
Offline afton
Is there any way to create a keyboard shortcut to increase/decrease system volume in Windows 7?
eg. bind F11 to decrease volume and F12 to increase volume.
using: Filco Majestouch Tenkeyless MX Brown switch
Offline Human
« Reply #1 on: Sun, 08 January 2012, 00:29:13 »
Quote from: afton;485790
Try AutoHotKey? For details go to the script sharing thread.
Offline startacked
« Reply #2 on: Sun, 08 January 2012, 01:33:10 »
Offline TheProfosist
  • Custom Layouts Only!
« Reply #3 on: Sun, 08 January 2012, 04:59:11 »
Quote from: Human;485806
I second autohotkey
Offline Spharx
« Reply #4 on: Sun, 08 January 2012, 06:00:14 »
You could also use autoit and mod this script:
Code: [Select]
#AutoIt3Wrapper_Compression=4
#AutoIt3Wrapper_Res_Language=1031
#AutoIt3Wrapper_Add_Constants=n
#AutoIt3Wrapper_Run_Tidy=y
Func MEDIA_next()
Send("{MEDIA_NEXT}");
Beep(50, 500)
EndFunc   ;==>MEDIA_next
Func MEDIA_pause()
Send("{MEDIA_PLAY_PAUSE}");
EndFunc   ;==>MEDIA_pause
Func MEDIA_prev()
Send("{MEDIA_PREV}");
EndFunc   ;==>MEDIA_prev
Func MEDIA_up()
Send("{VOLUME_UP}");
Beep(200, 10)
EndFunc   ;==>MEDIA_up
Func MEDIA_down()
Send("{VOLUME_DOWN}");
Beep(50, 10)
EndFunc   ;==>MEDIA_down
Func MEDIA_mute()
Send("{VOLUME_MUTE}");
EndFunc   ;==>MEDIA_mute
HotKeySet("#{F8}", "MEDIA_next")
HotKeySet("#{F7}", "MEDIA_pause")
HotKeySet("#{F6}", "MEDIA_prev")
HotKeySet("#{F9}", "MEDIA_up")
HotKeySet("#{F10}", "MEDIA_down")
HotKeySet("#{F11}", "MEDIA_mute")
While 1
Sleep(100)
WEnd
Why is the hide content button missing here at geekhack ??
Offline limmy
« Reply #5 on: Sun, 08 January 2012, 06:26:57 »
It is easy to do in autohotkey. If you simply want F11 and F12 to behave as Vol Down and Up, just add the following two lines in the script.
F11::Volume_Up
F12::Volume_Down
Offline Rajagra
« Reply #6 on: Sun, 08 January 2012, 07:10:42 »
Does Win 7 have the same problem as Vista? Each app has its own volume setting. If you use autohotkey to change the volume ... you only change autohotkey's volume!!!
F*^@ you, Microsoft!
If there are 2 keys you are willing to lose, you could map them to volume up/down using KeyTweak or Sharpkeys or similar.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Sun, 08 January 2012, 08:32:17 »
Win7 does maintain separate volumes for apps, however I've never had an AHK script change anything but the master volume.  How odd.
Filco w/ Imsto thick PBT
« Reply #8 on: Sun, 08 January 2012, 09:32:02 »
I have used Key Tweak and it works pretty well, most of the time, but in XP, at least once a week, I have no sound and have to jump through a lot of hoops to get it back.
Sometimes making changes to "Sounds" in the Control Panel works, sometimes it inexplicably goes back to Mute when I close the Control Panel.
Occasionally I find the volume turned all the way down, as opposed to muted.
I am not doing any of this myself. I had just pegged it up to a "ghost in the machine" and assumed I would have to live with it.
- Oliver Willis 2026-08-01
