Author Topic: FPS Keyboards?  (Read 3125 times)
Offline turboRush
FPS Keyboards?
« on: Sat, 14 January 2012, 10:15:40 »
Hi GH,
I was wondering if there was any benefit of buying a keyboard specifically for FPS gaming? Is there any real benefit with mechanical, membrane, or anything other types of keyboards for FPS specific gaming?
I have a wireless keyboard that I am looking to replace for obvious reasons so if anyone could help that would be awesome!
Thanks,
turbo
Offline Lolcakes
FPS Keyboards?
« Reply #1 on: Sat, 14 January 2012, 10:30:00 »
Its just feels nice on your fingers. This is the benefit you get from it (:
Its like having a comfortable chair... is this going to make game better? Probably not but you will feel more comfy :3
Offline False_Dmitry_II
FPS Keyboards?
« Reply #2 on: Sat, 14 January 2012, 10:50:22 »
I have a bunch of different types. I play games on any of them. Though I don't particularly do so competitively.
Offline pagonda
FPS Keyboards?
« Reply #3 on: Sat, 14 January 2012, 13:27:12 »
keyboards won't improve your gaming performance IMO. I bought my mechanicals because they are better ergonomically for me(i have a tenkeyless so my hands are closer together) and because they feel way better than rubber domes.
[SIGPIC][/SIGPIC]
Offline rhalle
FPS Keyboards?
« Reply #4 on: Sat, 14 January 2012, 13:39:52 »
I recently got a mechanical, and I play a fair amount of FPSs.
It has browns in it.  I like it; it feels a bit more responsive and "sure".
They aren't the same as rubber domes.
Offline Reptile
FPS Keyboards?
« Reply #5 on: Sat, 14 January 2012, 13:41:19 »
Used my filco with reds last night playing battlefield. Vast improvement over my other boards. Just felt better doesn't mean I played better! :)
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline shogrran
FPS Keyboards?
« Reply #6 on: Sat, 14 January 2012, 13:59:20 »
Quote from: Lolcakes;490254
This pretty much describes the feeling.
Several posts may say that it won't improve your gaming. I don't quite agree that it won't improve your game, or at least not directly.
Long practice sessions are required to improve. And If you're sitting in an uncomfortable stool like I am right now, you'll last probably just last a few hours using your computer. Using a better chair will help make you last in practice sessions. The analogy goes for your keyboard although you might not notice it.
(edit: hmm.. maybe I should get a chair instead of a keyboard then)
« Last Edit: Sat, 14 January 2012, 14:01:50 by shogrran »
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline TopazPie
FPS Keyboards?
« Reply #7 on: Sat, 14 January 2012, 15:24:21 »
I like to play fps games the most on browns. The main thing for me is the non ghosting though, not the switch type.
FPS Keyboards?
« Reply #8 on: Sat, 14 January 2012, 17:20:49 »
I think you mean non-blocking
Offline TopazPie
FPS Keyboards?
« Reply #9 on: Sat, 14 January 2012, 18:47:17 »
Quote from: False_Dmitry_II;490508
I meant non ghosting. I really hadn't ran into problems with key blocking, because the old keyboard I used to use didn't have key blocking.
FPS Keyboards?
« Reply #10 on: Sat, 14 January 2012, 19:09:12 »
Even my model M has blocking. I have never actually seen a ghosting board. Just running into what it stops you from doing.
Offline quake4mhg
FPS Keyboards?
« Reply #11 on: Sun, 15 January 2012, 01:12:57 »
After play some games with mechanical keyboard, you feel kinda delay when using membrane keyboard. :biggrin:
Offline Culinia
FPS Keyboards?
« Reply #12 on: Sun, 15 January 2012, 05:06:31 »
Just to add - don't feel restricted by the switch type you choose. I play mainly FPS on MX Blues and that's been rated as 'bad' for gaming although I find there is no trouble at all in terms of performance K/D ratio etc is concerned. In terms of noise I don't find them noisy when playing since I use headphones and they seem to muffle the sound. Although if you on skype or teamspeak just be aware that your teammates will hear the clicking of the keys, that seems to be the no 1 complaint. I also came from a wireless board and will never go back to one, I don't think wireless or at least the one I had did not have 6KRO so when I got my Filco I could now move everywhere - the freedom was amazing plus I didn't have to faff about with any batteries!
Offline davkol
  •  Post Editing Timeout
FPS Keyboards?
« Reply #13 on: Sun, 15 January 2012, 05:33:24 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Tue, 03 July 2018, 08:08:01 by davkol »
Offline Shinx
FPS Keyboards?
« Reply #14 on: Tue, 17 January 2012, 20:08:22 »
Quote from: Culinia;490946
I use this as an opportunity to brag about my keyboard and make everyone supremely jealous. Everyone seems IMPRESSED that you can still buy keyboards that click.
Offline keyboardlover
FPS Keyboards?
« Reply #15 on: Wed, 18 January 2012, 07:01:17 »
I use ALL my keyboards for FPS gaming and they are ALL superb for it.
See my sig for details.
Offline OPR8R
FPS Keyboards?
« Reply #16 on: Thu, 19 January 2012, 12:37:41 »
I've used a lot of keyboards over the years trying to find "the right one" for (FPS) gaming.  I switched from non-mech keyboards to one with Cherry blacks a few years ago.  It was an improvement, but I didn't settle until recently, when I got a Leopold with red switches.  I've customized it with key caps from elitekeyboards and WASD, along with dampener rings from the latter (which are awesome).  I consider it to be my ideal (FPS) gaming set up.
