Author Topic: Best keys?  (Read 6867 times)
Offline Danny356
Best keys?
« on: Sat, 14 January 2012, 23:23:05 »
what keys would last the longest without that greasy look? I ask this because after a year all my das keys have that shinny greasy look and its really bothering me. They also need to be blank
Best keys?
« Reply #1 on: Sun, 15 January 2012, 01:06:42 »
Quote from: Danny356;490845
Quote from: ripster;490847
IBM Model M followed by Topre.
IBM doesn't make keyboards anymore, and I'm not certain that they ever made ones with blank keys.
You can get unprinted PBT keys for IBM from unicomp for like $20/set (super cheap). If you want to get a new keyboard from them with blank keys, I'm sure they will help you out.
PBT keys are very wear-resistant. The IBM/unicomp ones are a little more "rough" than (for example) the signature plastics PBT. I feel like it'd take them longer to smooth out, but I haven't verified this.
If you don't want a new keyboard, it's pretty easy to get blank PBT keys for your DAS.
Offline Danny356
Best keys?
« Reply #2 on: Sun, 15 January 2012, 01:12:16 »
isnt the spacebar pbt tho T_T
and i meant what is the most durable for cherrys
Best keys?
« Reply #3 on: Sun, 15 January 2012, 03:45:40 »
Quote from: Danny356;490888
IBM/unicomp have PBT spacebars: Topre have ABS (oh no!)
I'd recommend (as I said) some blank PBT keycaps, for example at the URL below:
http://geekhack.org/showthread.php?24621-Interest-Check-KBC-104-PBT-Cherry-MX-Key-Caps-UPDATE
Offline Danny356
Best keys?
« Reply #4 on: Sun, 15 January 2012, 17:25:01 »
what im asking is, is PBT the only option i have to replace my daskeyboard keys or is there a higher quality plastic
Offline Pylon
Best keys?
« Reply #5 on: Sun, 15 January 2012, 17:46:34 »
Generally PBT is your best option. Generally ABS, POM, and PBT are used to make keycaps, though I reckon some really cheap rubber domes use polystyrene (PS).
Best keys?
« Reply #6 on: Mon, 16 January 2012, 00:42:46 »
Quote from: Danny356;491232
I liken this to asking "Is titanium the only option, or is there a better metal for my chair?" I really like PBT, as it's much harder than ABS. Generally speaknig there are some ways you can "upgrade" from ABS: PBT is my favourite. Other common ones are Doubleshots (preferably thick ones), POM (which I haven't tried, but don't think I'd prefer) or metal.
Quote from: Pylon;491245
There's also one keyboard that uses Nylon (zowie celeritas) if the wiki can be believed.
If you want cold keycaps, there are blank silver and gold metal sets for sale in the GB forum, though I hear qtan will start carrying them in his store soon as well.
Offline vortex
Best keys?
« Reply #7 on: Mon, 16 January 2012, 07:50:07 »
you can search Vortex Keyboard in FackBook ,
you can find PBT keycaps with Sublimation printing
Offline keyboardlover
Best keys?
« Reply #8 on: Mon, 16 January 2012, 07:50:46 »
Welcome to GeekHack vortex! How were you guys able to sublimate black keys?
Offline vortex
Best keys?
« Reply #9 on: Mon, 16 January 2012, 07:57:00 »
Yes, You got it !!
104/105 sublimation printing in Cherry MX switch,
BTW, I want post some picture in geekhack , But I can't do that ,
anyone can tell me , how I can do that ?
Post denied. New posts are limited by number of URLs it may contain and checked if it doesn't contain forbidden words.
Thanks
Quote from: keyboardlover;491594
Best keys?
« Reply #10 on: Mon, 16 January 2012, 08:05:15 »
Sorry there's a rule that you have to get to a certain post count to post images. PM iMav (the admin) for more info.
Nice work on the keys.
