Author Topic: [Interest check] Used black on white cherry doubleshots  (Read 18606 times)
Offline tsangan
  • 1000/600
« Reply #50 on: Wed, 18 January 2012, 00:15:34 »
Quote from: dorkvader;493172
Hmm, on my WYSE 50 set, I'm comparing a F1 key to a SP shamrock (I only have two SP doubleshots) The outside profile looks the same, but the inside is a bit different, the WYSE looks a little thicker, and the inside corners are different. The doubleshot area internally is pretty different (also the old stem doesn't have those flutes), Sprue mark is on the back, and the stem is stablized. I imagine it'd be pretty easy to "update" the process, and the similarity is really surprising!
Thanks for the info, tsangan, I'd not noticed that. Now I know what the cherry doubleshot profile is. :)
I should have wrote most 50 terminal series, there is a lot of discrepancy when it comes to Wyse keys some are really thick, some are thinner then some are said to be SP thin and those are the ones I was talking about.
If you go buy a 50 terminal board on eBay there are chances you will get a board with both thick and thin caps, finding thick ones are really hard and all comes down to luck of the draw.
Keyboardless
Offline bavman
« Reply #51 on: Thu, 19 January 2012, 10:05:15 »
OP has been updated. If no one objects I'll send out pms with how to pay me after I'm back from school. If we can get money collected by the end of this weekend he'll be able to ship on monday.
Offline rainb1ood
  • so pretty so plastic
« Reply #52 on: Thu, 19 January 2012, 10:08:35 »
I'm interested in 1 set
Offline pitashen
« Reply #53 on: Thu, 19 January 2012, 10:43:06 »
one set for me
Offline lightsout714
« Reply #54 on: Thu, 19 January 2012, 10:59:22 »
Hey count me out I just picked up a set elsewhere.
Sent from my Galaxy Nexus using Tapatalk
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #55 on: Thu, 19 January 2012, 11:20:58 »
Do we have any more info about those PF1-4 keys?  If there's no PgDown, Delete, or End keys, I'm out.
Offline 1uckyNumb3r7
« Reply #56 on: Thu, 19 January 2012, 14:56:56 »
I'm going to duck out too
Offline DaemonRaccoon
« Reply #57 on: Fri, 20 January 2012, 22:46:33 »
Any movement yet? I want thick double shots.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline bavman
« Reply #58 on: Mon, 23 January 2012, 17:35:22 »
OP updated, but it looks like the GB is dead. I left the link in the op so you can still buy a single keyboard for $35 shipped, and harvest for the keys. The board is a G81 though so the switches aren't really desirable unless you want MY switches for something.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #59 on: Mon, 23 January 2012, 17:47:47 »
Shame. = (
Someones bound to come out later with more boards. And we shall be there to buy them all = 3
Fight For Freedom. Stand with Hong Kongers
Offline scrubadub
« Reply #60 on: Mon, 23 January 2012, 18:19:17 »
Hey, thanks for taking the time to try and organize a GB!
Realforce 87UB45 & 87UW45, Leopold FC200 Red
