Author Topic: Found this today and grabbed it: FK-2001  (Read 2583 times)
Offline GanjaSMK
« on: Wed, 18 January 2012, 23:28:31 »
I found this today and bought it because it was brand-new-in-box-all-original-packaging-etc!
[ Attachment Invalid Or Does Not Exist ] 37901[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 37902[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 37903[/ATTACH]
Just looking for information about this keyboard if anyone has it!  Haven't given it a typing yet, but plan to in just a little while.  Also, is it worth anything (being BNIB?)?
I'm really diggin the integrated keyboard cover, super sweet!
Offline himynameisbunny
« Reply #1 on: Wed, 18 January 2012, 23:47:17 »
You know, a quick search could have wielded a lot of results!
NIB ones are fetching about $50 by the looks of it. But with that cover...it might fetch more!
Apparently its' pot luck when it comes to what switch you get though:
Quote from: chimera15;193631
Really old ones use blues, older ones use white complicated, the newest ones use fakes, some are fake blues some are fake whites.  It's pot luck.  You can usually tell fakes because they have windows keys, but there are fakes in no windows key ones too.
Guess you better get to popping those keys off for us!
Quote from: chimera15;137393
No windows key, so it likely uses real complicated alps.  You can tell without even taking the switch apart, if they say alps on them they're complicated.
ripsters' small review of it here.
« Last Edit: Wed, 18 January 2012, 23:57:08 by himynameisbunny »
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline GanjaSMK
« Reply #2 on: Thu, 19 January 2012, 00:07:14 »
I'll admit I did do a really simple quick search here and on OCN and eBay - but nothing too in depth. :p I was just hoping that some brilliant keyboard wiz would drop the bomb with info, and I thank you so very much for the link.  I certainly will take a keycap off and get to photos!
The keycap is (obviously) easy to remove, what would you recommend for the switch?
« Reply #3 on: Thu, 19 January 2012, 01:37:10 »
Quote from: GanjaSMK;493819
Just pop the key off. Blue switch? Cherry blues. White switch? White ALPS. Does it say ALPS on it? If yes, complicated white ALPS. If no, simplified/fake white ALPS :-)
Sent from my GT-I9100 using Tapatalk
[SIGPIC][/SIGPIC]
Offline eagleeye
« Reply #4 on: Thu, 19 January 2012, 02:25:39 »
Huh?  You don't take the switch off if that's why you're saying.
Offline bbbbqq
« Reply #5 on: Thu, 19 January 2012, 03:30:50 »
maybe 2 piece keycap ?
Offline captain
« Reply #6 on: Thu, 19 January 2012, 09:26:16 »
This makes me miss my Focus FK-9000...  But the Filco TKL is pretty nice, and very much better than all the crap that's been foisted on us over the past 15 years.  Hooray for the era of the return of the mechanical keyboard!
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline flyball
« Reply #7 on: Thu, 19 January 2012, 09:28:27 »
Quote from: himynameisbunny;493863
blue alps
[SIGPIC][/SIGPIC]
Offline False_Dmitry_II
« Reply #8 on: Thu, 19 January 2012, 09:39:34 »
And alps is written on some simplifieds...
Offline Magna224
« Reply #9 on: Thu, 19 January 2012, 10:35:55 »
And complicateds don't always say ALPS! What a mindf**k. My bet is complicated white ALPS (but it just as well could be simplified).
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
« Reply #10 on: Thu, 19 January 2012, 14:41:10 »
Quote from: flyball;494029
blue alps
My bad :p
[SIGPIC][/SIGPIC]
Offline Hak Foo
  • Make America Clicky Again!
« Reply #11 on: Thu, 19 January 2012, 18:46:12 »
That must be a very late '2001.  I've never seen one with power management keys.
Overton130, Box Pale Blues.
Offline mbc
  • -delete-
« Reply #12 on: Thu, 19 January 2012, 19:44:37 »
Windows keys = simplified Alps
