Author Topic: Custom / DIY trackpads  (Read 4099 times)
Offline SidusNare
  • Do, or do not; there is no try.
« on: Sat, 21 January 2012, 16:06:57 »
Hi,
Does anyone know how or where you can buy or make track pads to your own specs?
I want to make a custom hybrid track ball / touch pad, same form as a track ball but a touch pad where the ball goes.
Any ideas?
Sidus
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
Offline Input Nirvana
« Reply #1 on: Sat, 21 January 2012, 18:58:44 »
I'm not seeing it, can you describe a bit more?
Offline SidusNare
« Reply #2 on: Sun, 22 January 2012, 05:17:12 »
Imagine a Logitech M570. Where the ball should be imagine a cylinder the same diameter as the ball protruding 2-3cm with a track pad across the flat top of it. The movement would be similar to the tack ball but no ball.
« Reply #3 on: Sun, 22 January 2012, 12:49:07 »
Would this work?
http://www.ergotouchpad.com/
Or these?:
[ Attachment Invalid Or Does Not Exist ] 38283[/ATTACH]
Offline SidusNare
« Reply #4 on: Mon, 23 January 2012, 04:27:04 »
Those triangular ones with the round bit on them might if they come off the metal base. I don't see anything small or round at ergo.
