Author Topic: Noppoo Choc questions.  (Read 2662 times)
Offline Deadly55
« on: Sat, 28 January 2012, 03:03:36 »
What's the build quality of the choco pro and mini compared to the good old widow. there's no real big issues  with them either right?
Offline stingrae
« Reply #1 on: Sat, 28 January 2012, 04:18:04 »
Quote from: Deadly55;501391
Good old widow? xD
There are a lot more people buying widows and thus a lot more manufacturing faults found with it. On the one hand it has a more standard layout on the other the most common issue is keypresses hitting neighbouring keys. In my honest opinion razer is not the most reliable when it comes to manufacturing.
The choc mini isn't without fault but it does come with pom keycaps and is a portable format. The faults tend to be keys not working (which can be fixed if you have some electrical experience) or keys breaking which can also happen to the widow and even Filcos.
I'd choose the noppoo (or race perhaps) again over any widow. It is also available with more variety. The following is my impressions based on what i've read here and based that you don't want to spend the extra for a filco, wasd or das(which would all be good solid choices): I'd probably say if backlighting is something you want go with the Race, if full size is what you want go with a Rosewill then choc pro (if you are on a budget). If you don't mind replacing keycaps (as the raised lettering isn't all that nice but you can live with it) and want a tkl go with a cm storm. Otherwise choc mini is a good choice if you want a niche style keyboard, my biggest gripe is the fact that the right shift causes me problems when I want to use | just annoys my hand.
I have not actually had the chance to physically hold a blackwidow out of it's box but it did seem pretty heavy. I think you will find the information you want by reading the posts in this forum and in the wiki :). Please realise the information i've got is only personal opinion with a little bit of fact, im not trying to write an academic paper on the subject :).
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #2 on: Sat, 28 January 2012, 08:34:05 »
Choc (Mini)  > Blackwidow
My friends Blackwidow feels like it has a fisherprice shell. My Mini feels like it's got a keyboard's case.
Fight For Freedom. Stand with Hong Kongers
Offline Deadly55
« Reply #3 on: Sat, 28 January 2012, 12:45:05 »
Well I'd be going with the a white mini and the led pro, so no pom keys here :P I'm a lefty gamer so the race's shift key is a no go.
edit: I've also seen a green right shift on a mini, where do people find them?
« Last Edit: Sat, 28 January 2012, 14:14:11 by Deadly55 »
Offline Gawkbasher
« Reply #4 on: Sat, 28 January 2012, 15:08:13 »
Not enough love for leopolds when we talk about TKL boards.
However, my friend had to RMA his widow twice.  His first one was DoA new in box.  The second had some of the problems described above.
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Deadly55
« Reply #5 on: Sat, 28 January 2012, 15:41:12 »
well i  prefer costar stabilizers over cherry style by far.
Offline stingrae
« Reply #6 on: Sat, 28 January 2012, 18:04:43 »
Quote from: Deadly55;501777
cm storm quick fire then?
Offline Deadly55
« Reply #7 on: Sat, 28 January 2012, 18:55:04 »
only mx blues  locally, and that  ammount of branding -.-
Offline LastDance
« Reply #8 on: Sun, 29 January 2012, 01:15:39 »
The Noppoo Choc series are far superior to the any of the Razer keyboards. You won't be disappointed.
Like many others have mentioned. the Razer boards feel very cheap and plasticy in comparison.
Offline kikkobots
« Reply #9 on: Mon, 30 January 2012, 14:52:35 »
i <3 choc mini! (its on their box)
Offline blebs
« Reply #10 on: Tue, 31 January 2012, 15:07:49 »
the white choc mini comes with PBT keys. its nice
Offline kikkobots
« Reply #11 on: Tue, 31 January 2012, 15:38:23 »
pbt keys for only $110 sounds good to me
Offline kikkobots
« Reply #12 on: Tue, 31 January 2012, 15:38:58 »
pbt for only $110 on a keyboard sounds good to me.
i also like hte F keys right on top of hte number keys
Offline kikkobots
« Reply #13 on: Wed, 01 February 2012, 15:15:35 »
the white choc mini come with PBT keys for only like $10 more
