Author Topic: Building Phantom Hardware and Firmware Mods  (Read 228302 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Mon, 30 January 2012, 04:18:29 »
If you are new to soldering, here is something that might help, available in many different languages:  http://mightyohm.com/blog/2011/04/soldering-is-easy-comic-book/
This is a dedicated thread for Phantom soldering discussion and firmware discussion, a repository of all Phantom related files and information, one stop shop for all your Phantom technical needs.  This page should be open for editing so everyone can update this page with latest information.
Please use the discussion section for continuous discussions, ask questions, and provide help to others if you can.
Original Phantom Group Buy Order thread
Phantom soldering instruction wiki
Phantom Firmware from PrinsValium
How to change LED brightness in firmware
Phantom PCB:
2116-0
Phantom Features:
  • Supports vintage Cherry double shot, laser, and dye sub keycaps
    • 1.5x Ctrl and Alt vintage Cherry keycaps (PHANSI and PHISO plate options)
    • With 1.5x modifiers, you can also use Cherry’s 7x spacebars
    • Supports centered-stem and offset-stem Capslock (also from vintage Cherry Keyboards)
    • Also support modern keyboard layout with 1.25x Ctrl and Alt modifiers (PHANSIWIN and PHISOWIN plate options)
  • Supports both Costar and Cherry stabilizers
  • Supports in-switch LED at Capslock and Scroll Lock locations, as well as Filco style LED locations between PrintScrn-ScrollLock-Break and Insert-Home-PageUp
  • Plate design allows Cherry MX switch top removal without de-soldering the switch first
    • Perfect for easy switch lubing, repair, or modding
      Excluding switches with in-switch LED
  • Supports 5 extra keys between 6-pack and arrow keys (case modification required)
  • Supports 6KRO over USB with current Teensy firmware
    • potentially NKRO over USB in the future with new Teensy firmware
  • All keys can be remapped via firmware source code changes (currently a recompile of source is required)
  • LED brightness adjustable in firmware source code
  • Fits inside Filco Tenkeyless cases
    • PLU cases could also work
  • Community support on Geekhack.org and Deskthority.net
Kits include the following:
 1 PCB (includes 2 white LEDs and2 resistors)
 1 Plate
 1 Teensy (includes 1 40-pin pin header)
 100 switches
 100 diodes
 4 2x stabilizers for ANSI or 3 2x stabilizers for ISO or 0 for PH7BIT
 1 7x or 1 6.25x stabilizer set for spacebar or 0 for PH7BIT
Interesting locations on PCB to watch out for:
[ Specified attachment is not available ]39094[/ATTACH]
Here is a video that demostrates how to make a costar stabilizer bar by hand.  You need a Du-Bro E/Z Bender (0-90 degrees and Z bend). Wire need to be 3/64 inch music wire that you can find at hobby shops. I found the ones I use at Hobby Town USA. It is called K&S Precision Metals Stock # 502 0.047 Music Wire (1.19mm).
Schematic:
[ Specified attachment is not available ]39096[/ATTACH]
Removing switches without desoldering:
Future Firmware Feature List:
  • NKRO over USB while maintaining BIOS boot compatibility
  • multiple layers
  • media keys
  • programmable macros
  • reset with key combos without opening up the case to push the reset button on Teensy for easy flashing
  • re-program keymaps without loading new firmware like AIKON.
« Last Edit: Tue, 14 August 2012, 17:29:29 by litster »
Offline RiGS
« Reply #1 on: Mon, 30 January 2012, 04:20:24 »
Could you take a picture of that area of the plate we discussed?
Offline litster
« Reply #2 on: Mon, 30 January 2012, 04:20:59 »
Oh right, I will do that tomorrow.  Sorry about that.
Offline RiGS
« Reply #3 on: Mon, 30 January 2012, 04:27:51 »
Thanks.
Is it possible to use the Aikon instead of the Teensy?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Mon, 30 January 2012, 08:07:22 »
The board is designed around the footprint and pin count of the teensy.  The Aikon should be capable of controlling the matrix, making it pretty and fit in a case is another matter entirely.
Filco w/ Imsto thick PBT
Offline bpiphany
« Reply #5 on: Mon, 30 January 2012, 08:55:06 »
One nit pick... The firmware is BIOS compatible as it is. One of my friends says it sometimes doesn't some "online" quickly enough to be able to hit F2 or Del or whatever to access the BIOS. There is a _delay_ms(2000) (originally from the pjrc code) when initiating. This delay could probably be shortened, I'm not entirely sure why it is needed.
Offline alaricljs
« Reply #6 on: Mon, 30 January 2012, 08:59:16 »
The delay is needed to wait for initialization of the host end of the USB protocol because power is applied immediately on power-on and the host end  needs to boot its firmware.  2 seconds is on the very large side, I'd expect 500ms to be sufficient in 99% of systems.  If you cascade several hubs between the KB and system then 2 seconds may be needed, but then you won't be hitting the BIOS in that case anyway.
Offline litster
« Reply #7 on: Mon, 30 January 2012, 11:21:10 »
Quote from: PrinsValium;503128
Sorry, my mistake.  While copy and pasting that chunk of text, formatting was lost, and when I reformatted the lines, I added an CR to split that line.  I think the correct description should be NKRO over USB while maintaining BIOS boot compatibility.  I think there is a Teensy firmware version from Soarer that has NKRO but without BIOS boot compatibility, but he later said that it is possible to do both in the same firmware, he just had done it yet.
I updated the firmware feature list.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #8 on: Mon, 30 January 2012, 12:39:45 »
can we have some kind of precise specifications here? ie, schematic, pcb design file, etc. etc.?
eta: a-ha, i see the plates! thanks! now for mounting hole and board dimensions?
« Last Edit: Mon, 30 January 2012, 23:54:51 by mkawa »
Offline litster
« Reply #9 on: Mon, 30 January 2012, 23:30:02 »
Here you go RiGS.
Offline Tarkoon
« Reply #10 on: Tue, 31 January 2012, 01:59:35 »
Ähm, if I look at your pictures and remember the discussion about "normal" vs. vintage Cherry MX switches...
The two switches at the lower end of your picture are from the same source???
Their Cherry logos look different!
Offline litster
« Reply #11 on: Tue, 31 January 2012, 02:21:53 »
All my switches came from very old Wyse and Cherry POS keyboards.  The switch bottoms came from old Wyse plate-mounted switches.  The stems and springs came from an old Cherry POS keyboard with browns.  Since I have mixed all the parts together, I don't remember if the switch tops were from the Wyse blacks, or Cherry POS browns.  But they are all pretty old.  The feel of the Phantom is different than my Filco browns, in a very good way IMO.  I love typing on the Phantom now.  I don't know if it is the switches, the aluminum plate, the PCB, or a combination of all.
Offline bpiphany
« Reply #12 on: Tue, 31 January 2012, 02:22:59 »
Here is the schematic too, if you want to add that to the main wiki post, litster.
[ Attachment Invalid Or Does Not Exist ] 39092[/ATTACH]
Offline litster
« Reply #13 on: Tue, 31 January 2012, 02:31:59 »
Quote from: PrinsValium;504011
Added to the wiki post.  Thanks.
Offline RiGS
« Reply #14 on: Tue, 31 January 2012, 03:11:38 »
Thanks for the picture. Honestly I think the idea of that plate design is pure genius, yet I'm not sure if I prefer it over the regular one.
You can certainly open those switches without soldering, but desoldering a whole board takes less than half hour when you have a little experience with the soldering iron, and even if you don't have any experience at all, it is still very basic skill that worth learning.
My concern is that design could potentially further increase the wobble of the upper switch case(Koreans even developed special stickers to minimize and reduce this effect). You can easily verify this by putting a keycap on a single switch and shake the top of the keycap.
Also one could accidentally open the switches while removing the keycaps, and those little gaps could trap a lot of dirt, dust and hair.
The switches could be cleaned, lubed and modded prior assembly. If you use a good lubricant like the RO-59, you are probably good for life, and you don't need to open those switches anymore.
« Last Edit: Tue, 31 January 2012, 03:44:11 by RiGS »
Offline RiGS
« Reply #15 on: Tue, 31 January 2012, 03:22:00 »
Quote from: litster;504009
Judging by that new Cherry logo, the switch tops are from the Cherry POS. The WYSE has an older logo.
Offline litster
« Reply #16 on: Tue, 31 January 2012, 09:54:55 »
I think the plate design is awesome.  I was amazed again when I just popped open the switch top with 2 tiny screw drivers in a few seconds to take the picture.  I am using Cherry keycaps on it now, so they are not tight as Filco keycaps.  I have switched keycaps a few times already and no switch tops popped off when I pulled keycaps off.  From reading DragonBro's post on a Chinese forum, he mentioned the stckers from Korea is for covering the open gaps around the switch so no dust and crap can fall into the switch or let the lube dry out.  But maybe there are different stickers for different effects. Or the stickers can do what you said as well.
I will give the switches a shake test.  From using it the last couple of weeks, I haven't felt any shakiness with the keys and switches.
Also, you can't just keep soldering and desoldering over and over again if you keep modding your switches.  You can, but you will soon damage the PCB.  With the phantom plate, you can do it without desoldering and soldering, and you don't even need to open up the case.  And you don't need the tools and skills to solder and desolder to swap switches.
« Last Edit: Tue, 31 January 2012, 10:08:58 by litster »
Offline kaiserreich
  • HHKB Elite
« Reply #17 on: Tue, 31 January 2012, 12:04:09 »
Do you think it is possible for us to get some Group buy for vinyl stickers?
Offline alaricljs
« Reply #18 on: Tue, 31 January 2012, 12:05:01 »
Vinyl stickers for what?
Offline RiGS
« Reply #19 on: Tue, 31 January 2012, 12:55:35 »
I have those stickers, and they don't cover those open gaps around the switches, but indeed they can help keeping the dust outside of the switches. Maybe I can ask a local company to replicate my stickers and organize a group buy.
Like I said the stickers are designed to fill up the space between the lower and upper switch case in order to reduce the play and minimize the switch wobble. If you remove the keycap next to the switch you want test for wiggle, you will notice that the upper switch case is having a tendency to move.
I suspect the Phantom plate design is prone to emphasize this little issue even more. I don't try to bash it. All I'm saying that while it is very convinient, but it definitely has its down sides.
No disrespect, but in case of the FR4 PCB it is very unlikely that you will ever damage it. The switches could be cleaned, lubed and modded prior assembly, and there is no need to open them after that. Also I don't think that a $10 soldering iron and a wick are such a big investments. After all this is geekhack.
Offline alaricljs
« Reply #20 on: Tue, 31 January 2012, 12:59:28 »
Quote from: RiGS;504366
I can see it wobble on my Filco, compared to the massive stem/keycap wobble I'd be hard pressed to notice it when typing.
Offline alaricljs
« Reply #21 on: Tue, 31 January 2012, 13:01:17 »
Quote from: kaiserreich;504282
Quote from: alaricljs;504285
So presuming that you are talking about the cherry switch stickers, vinyl is the wrong choice.  The real deal I believe are made of paper, possibly some fiber reinforced stuff but definitely not vinyl.  Vinyl is far too easily deformed for that to work.
Offline RiGS
« Reply #22 on: Tue, 31 January 2012, 13:01:51 »
It is not as major as lubing, but it is definitely there. Btw my vintage blacks do not wobble nearly as much as my recent cherries.
Offline litster
« Reply #23 on: Tue, 31 January 2012, 19:51:05 »
I see what you mean, RiGS.  I suspect that the cut out isn't too big of a problem since the switch top isn't resting on the area where the extra cutout is.  But I could see it could be less structually stable by a little bit.  Hard to say.  If I have time I will take close up HD movie of shaking a switch on phantom and on a Filco to see if there is any difference.  Wish I still have the high speed 600fps Casio camera to take super slow mo movie of the switch while shaking it.  That would be cool.
Offline kaiserreich
  • HHKB Elite
« Reply #24 on: Tue, 31 January 2012, 20:44:24 »
Quote from: litster;504802
Kinda getting more hardcore than the koreans :cheer2:
Offline litster
« Reply #25 on: Wed, 01 February 2012, 00:36:12 »
Anybody has any idea where I can find a USB cable that is similar to the original Filco cable where there is cable gland that hooks to the case?  I haven't been able to find anything like that.
Offline RiGS
« Reply #26 on: Wed, 01 February 2012, 03:02:18 »
Indeed, that would be cool.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #27 on: Wed, 01 February 2012, 06:28:17 »
Quote from: litster;505006
I have a spare from my Choc Mini since I did a detachable cable mod. But I'm not sure If I'd part with it.
Can you find just USB cables with the connector without the gland? Because I think you can add glands yourself.
Fight For Freedom. Stand with Hong Kongers
Offline litster
« Reply #28 on: Wed, 01 February 2012, 10:34:39 »
Hehe, I also haven't been able to find a gland that I could pass through a USB cable that already has connectors soldered on both ends.  I found some picture on the 'net previously that looks like a gland that you could pop onto a cable without removing connectors on the ends, but I haven't found a shop that actually sells them.
Offline mtl
« Reply #29 on: Wed, 01 February 2012, 12:04:02 »
Does anyone know of a good color anodizing service based in the US? Was thinking of coloring the plates.
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
Offline tsangan
  • 1000/600
« Reply #30 on: Wed, 01 February 2012, 13:05:04 »
Keyboardless
Offline alaricljs
« Reply #31 on: Wed, 01 February 2012, 13:07:18 »
Those look overly fine-pointed and dainty.  A set of micro screwdrivers would give you a couple good straight blade screwdrivers to pry the latch fingers and pop the top off.
Something along the lines of these
« Last Edit: Wed, 01 February 2012, 13:10:12 by alaricljs »
Offline tsangan
  • 1000/600
« Reply #32 on: Wed, 01 February 2012, 13:13:12 »
Awesome, I picked up a set of those already today but I watched squarebox's video and his tweezers looks like it was really useful, I guess I'll try out just the micro screwdrivers first
[video=youtube;bLBXxzmuA_Q]http://www.youtube.com/watch?v=bLBXxzmuA_Q[/video]
Keyboardless
Offline digitalleftovers
« Reply #33 on: Wed, 01 February 2012, 13:33:26 »
I like the tweezers idea for the sake of using one hand.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline alaricljs
« Reply #34 on: Wed, 01 February 2012, 13:53:10 »
Those in the video are a lot more blunt than the ones you linked... here  is the Tamiya model I would suggest, although they might even be too blunt.  There's tons of different tweezers tho.  Something more blunt than what you linked, perhaps less blunt than mine :)
Offline tsangan
  • 1000/600
« Reply #35 on: Wed, 01 February 2012, 14:01:43 »
Quote from: alaricljs;505447
That should be good then, thanks for the link!
The tips look kind of wide in the picture, wonder if it will slide into the holes in the switch
« Last Edit: Wed, 01 February 2012, 14:04:26 by tsangan »
Keyboardless
« Reply #36 on: Wed, 01 February 2012, 16:57:02 »
This electronics/micro-controller stuff is all quite new to me.  I've done a little soldering practice now, but really wanted to dive into the controller programming and circuit testing before I get into my keyboard project.  pjrc (the company that makes the teensy) offers some starter kits.  It turns out that they are based in Sherwood, which is just outside of Portland, OR (where I am).  So my order was effectively next day!
Teensy's are SMALL!  Going to hook it up tonight and start playing with it.  I've got a breadboard and some components too.
Keyboards:
Offline litster
« Reply #37 on: Wed, 01 February 2012, 23:11:10 »
Quote from: RiGS;505072
You guys are making me pulling out all the stops...
I give you... 1080p goodness!  (well, you have to manually switch to 1080p :-))
Keep in mind that the browns on the Phantom are at least 15 years old, while the Filco is less than a year old.
Filco:
Phantom:
EDIT:
Yes, I had to sack a perfectly good blank yellow PBT keycap to shoot these videos.  LOL!
EDIT:
Fixed youtube links after forum migration
« Last Edit: Tue, 14 August 2012, 12:08:25 by litster »
Offline mkawa
« Reply #38 on: Wed, 01 February 2012, 23:31:54 »
local machine shops are probably the way to go afaik. krylon ok too i'm guessing (unless tolerances too tight?)
Offline Sojik
« Reply #39 on: Wed, 01 February 2012, 23:38:34 »
I'm thinking about making a case out of fiberglass. I don't own a Filco and it's much cheaper for me to make my own case (free actually since I'm an automotive painter with free supplies). I've worked with fiberglass on automotive paint repair before so I think I have what it takes. I'll probably fabricate the case out of clay or foam or something and then make a mold. Anyone else done something like this? I wonder how hard carbon fiber would be to work with, on second thought. There are so many car modification blogs and forums with DIY instructions for making custom carbon fiber parts...
If someone has a Filco case who would like to take on a project like this too, don't throw away your mold if you make one. :)
« Last Edit: Wed, 01 February 2012, 23:41:54 by Sojik »
Offline mkawa
« Reply #40 on: Thu, 02 February 2012, 00:07:30 »
are we still debating wobblilililiity? seriously guys, it's a keyboard.
question for litster: how did you get usb out on your plexi cases? did you do a small l-style cable from the teensy?
Offline litster
« Reply #41 on: Thu, 02 February 2012, 00:15:22 »
Quote from: mkawa;506079
I don't think we are debating.  We just want to know what really is going on under the keycaps.  It is all for good fun.  It was the first time I shot videos with my 100mm macro lens on my 5D Mark II.  That was pretty fun.
What is an I-style cable?  I am just using a regular USB to mini USB cable.  One of the lower layers has a cut out that fits the Filco keyboard's USB cable's gland.  I am still looking for glands that can be popped onto and existing USB cable or a USB cable with a built-in gland.
Offline mkawa
« Reply #42 on: Thu, 02 February 2012, 00:26:05 »
i went off searching for the thing i was talking about, but alas it was stupid; what i mean is "really tiny usb mini-mini extension cable whose female end terminates at the case edge"
i'm not sure what a cable gland is, but damned if it doesn't sound sexy
Offline litster
« Reply #43 on: Thu, 02 February 2012, 00:39:02 »
I was going to say something smart ass, went to wikipedia.org to look for gland, and burst out laughing when I read the first paragraph http://en.wikipedia.org/wiki/Gland:
A gland is an organ in an animal's body that synthesizes a substance for release of substances such as hormones or breast milk, often into the bloodstream (endocrine gland) or into cavities inside the body or its outer surface (exocrine gland).
I just learned about cable glands last week or so from the Phantom group buy thread.  There are a couple pictures there.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #44 on: Thu, 02 February 2012, 00:54:17 »
Quote from: Sojik;506044
You could buy a PLU for 1/3-1/2 the cost of a Filco that would probably be your best bet.
Offline Sojik
« Reply #45 on: Thu, 02 February 2012, 02:12:06 »
Quote from: TheProfosist;506125
Really? The only ones I saw on eBay when I looked were about the price I found the Filco TKLs ($100ish).
Offline litster
« Reply #46 on: Thu, 02 February 2012, 02:15:37 »
You can get a PLU for pretty good price from qtan.  I think TheProfosist bought 3 from qtan and qtan told him that he would give others similar pricing.  You get switches from a PLU as well, you just have to desolder them off of the PCB.
Offline mkawa
« Reply #47 on: Thu, 02 February 2012, 02:20:34 »
soo... any chance of getting the dimensions for case design anytime soon?
« Reply #48 on: Thu, 02 February 2012, 02:34:26 »
Quote from: litster;506159
Yea the price was $68 before shipping. Was a white one with blues pm or post in his forum for a quote for the case color and switch type that you want.
Offline RiGS
« Reply #49 on: Thu, 02 February 2012, 02:35:28 »
Quote from: litster;505991
Filco:
[video=youtube;BNMmwvvwZso]http://www.youtube.com/watch?v=BNMmwvvwZso[/video]
Phantom:
[video=youtube;vH4OvhTzid4]http://www.youtube.com/watch?v=vH4OvhTzid4[/video]
EDIT:
Haha. Amazing video, it seems the plate doesn't affect the wobblility. Now I want a Phantom as well.
