Author Topic: Leopold Keycap Question  (Read 3184 times)
Offline Waambulance
« on: Mon, 30 January 2012, 22:05:07 »
I'm looking to purchase some key caps for my Otaku Tenkeyless keyboard and I'm curious as to what "family" the row 1 keys are? I'd hate to buy keys that don't match the original shape/angle.
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Mon, 30 January 2012, 22:07:45 »
What caps are you looking at? It's easier for us to just tell you whether or not the set will match. If you're looking at a custom set from SP, then I THINK it's DCS, but I am in no way certain about that. But whatever the SP profile is, it doesn't match perfectly. Ripster will tell you all about that.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Waambulance
« Reply #2 on: Mon, 30 January 2012, 22:21:19 »
Well, I'm wanting to get 10 caps, numbered 0-9 from SP; Just want the closest match possible. I would hate to have 10 keys that are grossly different than the others.
Thanks for answering my questions.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #3 on: Mon, 30 January 2012, 22:23:01 »
Most stuff we make from SP is DCS "Family". But I'm not sure if OP is asking about profile or family.
Fight For Freedom. Stand with Hong Kongers
Offline Waambulance
« Reply #4 on: Mon, 30 January 2012, 22:29:37 »
http://www.keycapsdirect.com/images/faq/FamilyProfilesLG.jpg
DCS looks right, but I wasn't quite sure.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Mon, 30 January 2012, 22:31:47 »
SP keys will be about 1mm lower on the numeric row than stock keys. If you want the height and shape to match, better off with keys from WASD.
Offline Waambulance
« Reply #6 on: Mon, 30 January 2012, 22:35:00 »
Would that 1mm be a noticeable difference? I think I'll be OK with that height difference if they're still higher than the key row below them. Also, I'm not interested in buying an entire keycap set, which is why SP seems to be the best place, unless you have any recommendations?
« Reply #7 on: Mon, 30 January 2012, 22:42:00 »
You can buy single keys at WASDkeyboards. Cheaper than Sp too. I find it noticeable and annoying to have different profiles, but some don't.
Offline Waambulance
« Reply #8 on: Mon, 30 January 2012, 22:48:29 »
Ah, I forgot to mention that I want these 10 keys to be labelled. :(
EDIT:
Just noticed that I can get them with labels, derp.
Thanks for the help!
Offline Waambulance
« Reply #9 on: Tue, 31 January 2012, 14:45:45 »
SP quoted me $93 for 10 blue keycaps numbered 0-9... ridiculous.
Offline Gawkbasher
« Reply #10 on: Tue, 31 January 2012, 14:47:12 »
Quote from: Waambulance;504535
Machine time.
Small orders are always expensive.
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Waambulance
« Reply #11 on: Tue, 31 January 2012, 14:57:32 »
Quote from: Gawkbasher;504537
Machine time.
So I basically have to buy an entire set from WASD? ;(
Offline Gawkbasher
« Reply #12 on: Tue, 31 January 2012, 15:02:40 »
Quote from: Waambulance;504550
On the upside, they'll be QC'd a hell of a lot better.
ABS though :(
The economics of producing these things just isn't well suited to hobbyists who want small batches of specific keys, unfortunately.  Pretty much the only way to work with these plastics is injection molding and it's expensive.
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Waambulance
« Reply #13 on: Tue, 31 January 2012, 15:20:34 »
Gahhh, this is going to get expensive if I want a quality keycap set. :P
What's the difference between ABS and the other types, in terms of feel, weight, etc? I'm a newbie when it comes to Mechanical Keyboards.
Offline Gawkbasher
« Reply #14 on: Tue, 31 January 2012, 15:25:01 »
ABS keys are easier to manufacture and thus are generally cheaper but they develop a "shine" over time with use.
Feel, weight, etc, I can't say much more (I don't have/use any abs keys except for this spacebar).  There are pretty detailed explanations of keycap types/materials in the wiki, IIRC.
« Last Edit: Tue, 31 January 2012, 15:28:17 by Gawkbasher »
KBC Poker X (Blue)
/ KBC Poker X (Red)
