Author Topic: Carbon fibre keycaps.. possible EOI for a GB  (Read 23037 times)
Offline Tricks
« Reply #50 on: Sun, 19 February 2012, 22:27:29 »
hmm 316Ti easy to clean :D
also a little lol:
http://us-tech.com/RelId/725844/ISvars/default/InduKey_Intros_First_Carbon-Fiber_Keyboard.htm
CF with stainless keycaps .. haha
« Last Edit: Sun, 19 February 2012, 22:29:30 by Tricks »
Offline foureight84
« Reply #51 on: Mon, 20 February 2012, 21:05:52 »
gonna be some expensive key caps. i saw some zinc cherry mx compat keys on ebay for $99 crazy expensive
« Reply #52 on: Mon, 20 February 2012, 23:21:39 »
Quote from: foureight84;520103
I saw them on Geekhack for less.
The CF ones would be expensive, sure. But it would be well worth it.
Offline foureight84
« Reply #53 on: Tue, 21 February 2012, 01:57:48 »
Quote from: dorkvader;520328
yea i don't doubt that. i would love to replace all of my keys with cf caps. they would last a long long time.
« Reply #54 on: Tue, 21 February 2012, 08:22:05 »
Last a long time...? I'm not so sure. See, the carbon and resin composites aren't really that wear resistant, it's just super-amazing in tension. The weave makes it good in tension in multiple directions, so i you dropped them, they likely wouldn't break. I suspect we'd wear through the resin like normal plastic (Depending on what was used).
Now what would last a really long time: ceramic keycaps. I want to get an oven (or overvolt a toaster) and DIY some AL2O3 (alumina) keycaps. You can keep the temperature relatively "low" by sintering for a long time. Unfortunately, I still need an oven that can do 800C or higher.
Offline useless_people
« Reply #55 on: Tue, 21 February 2012, 19:11:17 »
I think it would look really cool but I feel like the resin would wear down too easily. And possibly become a little sticky. But I don't know. I would definitely be interested if it was really durable though.
[SIGPIC]
[/SIGPIC]
CM Storm Quickfire Rapid
WASD VP3
"Custom" TOFU 60% with Kailh Box Whites
« Reply #56 on: Tue, 21 February 2012, 21:09:46 »
Quote from: useless_people;521214
Think of it as clear epoxy. It shouldn't get sticky.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #57 on: Tue, 21 February 2012, 21:16:02 »
Quote from: dorkvader;521332
Any keycap can become sticky after a while, even epoxy. ; p
Fight For Freedom. Stand with Hong Kongers
