Author Topic: Happy Hacking Keyboard Lite 2 worth it?  (Read 22060 times)
Offline jooks1184
« on: Thu, 23 February 2012, 10:23:37 »
Hello again,
   So, after receiving my filco ninja majestouch 2 (white), I was in the market for a HHK. Unfortunately, it's way out of my price range, so I was hoping to settle for a HHK Lite2. I was wondering if the Lite version would be worth getting. I know that it doesn't have Topre switches but I like the layout and I figure it would give me an idea what to expect when I can get a Pro version later on. Thanks in advance for the help.
Offline MKB
« Reply #1 on: Thu, 23 February 2012, 11:06:34 »
It is a rubber dome.  And very stiff at that.  Not a good experience....
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
Offline whiskerBox
« Reply #2 on: Thu, 23 February 2012, 11:11:32 »
I had one for awhile and really liked it. Although I got mine for $69 + free overnight shipping from PFU so it was a good deal. With that being said I wish they came with red esc keys because it is a piler type keycap and you can't replace any keys. My only other complaint was the usb ports on it, they were inset so nothing I had would go all the way in which was frustrating. Other then that it was actually a cool board and the rubber domes were not that bad a little strong so if you like MX reds its probably not for you.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline jooks1184
« Reply #3 on: Thu, 23 February 2012, 11:37:39 »
Well, i went from using cherry reds to cherry browns. I like the tactile feedback. I used to use a logitech g15 so rubber domes aren't really a big deal. Also i don't mind stiff keys. The main thing tha attracted me was the price, form factor, and look. That enough to warrant purchasing one?
Offline whiskerBox
« Reply #4 on: Thu, 23 February 2012, 12:00:22 »
Well I got one just too see if I would like the layout for programming before I ordered the $300 one. I still haven't ordered the real deal but I might in the future they are really cool boards. I mean it's like a $100 so if you don't like it you probably would recoup at least half of that reselling it so I say go for it man
Offline hcry4
  • HHKB Hoarder
« Reply #5 on: Thu, 23 February 2012, 12:01:36 »
The layout is superb. I actually like it more than the standard HHKB Pro 2 layout because of the arrow keys. However, the rubber dome part really pales in comparison to any MX switch.
Offline jooks1184
« Reply #6 on: Thu, 23 February 2012, 18:52:56 »
Where would be a good place to order a hhkb lite 2
Offline hcry4
  • HHKB Hoarder
« Reply #7 on: Thu, 23 February 2012, 22:16:48 »
There's a used one on ebay. I bought mine from Amazon last year, but the price has jumped. You can buy from User Side. I bought all my HHKB Pro 2's from that seller, but you can see the prices have risen quite a bit. Over $100 for the Lite is definitely not worth it. Really though, it's probably better to just save up for the Pro 2 and buy from Elitekeyboards.
Offline hasu
  • @tmk
« Reply #8 on: Fri, 24 February 2012, 08:15:32 »
I can't find a good point on Lite2 except its layout. Even the layout is not same as a real HHKB.
The price is ridiculous for its quality.
Some people often say Pro is overpriced, but this board is more.
