Author Topic: [MO] Cherry MX Switch group buy (ended)  (Read 77977 times)
[MO] Cherry MX Switch group buy (no day left)!!!
« Reply #100 on: Sun, 04 March 2012, 21:50:14 »
Is it still available to order just a few (like 1-3x) of the switches? I wanted to add some for a full cherry keychain set I have planned.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #101 on: Sun, 04 March 2012, 21:54:32 »
Quote from: dorkvader;535325
WASD sells switches now, if that helps.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #102 on: Sun, 04 March 2012, 21:56:51 »
for volumes of 1-3x, mouser/digikey/wasd are probably the way to go.
Offline sordna
« Reply #103 on: Sun, 04 March 2012, 23:31:01 »
WASD has a volume discount too (lowest it goes is 80 cents per switch)
Offline 7bit
  • MX1A-G1DW
« Reply #104 on: Mon, 05 March 2012, 02:12:02 »
Just send an order!
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline 7bit
  • MX1A-G1DW
« Reply #105 on: Mon, 05 March 2012, 02:18:21 »
Quote from: hashbaz;535331
WASD:Buy 100 for $0.80 each and save 55%
Phantom: any quantity for $0.90-0.57 each.
Also, they only have PCB-mount switches.
« Last Edit: Mon, 05 March 2012, 05:21:45 by 7bit »
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #106 on: Mon, 05 March 2012, 02:59:39 »
Quote from: 7bit;535504
Also, they only have platemount switches.
The only PCB mount switch you're selling are the locking ones... 1/10 isn't lying, but still misleading.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline transcend3nt
« Reply #107 on: Mon, 05 March 2012, 04:20:25 »
im just curious. i have a KBT RACE keyboard which has LED attached to each switch. can i desolder that switch and change it to the MXLOCK switch and still retain the LED for the caps lock?
Offline The_Ed
« Reply #108 on: Mon, 05 March 2012, 04:22:54 »
You will have to change the firmware. The lock switch is ON-OFF instead of momentary ON.
R.I.P.ster
Offline bpiphany
« Reply #109 on: Mon, 05 March 2012, 04:53:07 »
The LED is not in the exact same location on the lock switches as on the regular ones (I'm quite sure at least). You might be able to trick it into working by bending the LED leads. I don't think you would want to make the caps lock into a locking switch though, without remapping it to something else. I'm not sure it would behave any well. And besides that the caps lock led lights up from the caps lock "state" being on, not holding shift (which would be the roughly similar thing). It is controlled through the keyboard controller, which will know nothing of your changing of switches...
« Reply #110 on: Mon, 05 March 2012, 04:59:52 »
oh no i'm lost already.
i thought if you press the MXLOCK switch, the switch will lock into a pressed position (thus sending one keystroke to the computer) and returns to the default position if pressed again (thus sending another keystroke to the computer).
from my point of logic, what is different from the actual usage?
thank you..
Offline balanar
« Reply #111 on: Mon, 05 March 2012, 05:13:09 »
Hi I've tried to edit my order like 3 times now but the bot keeps sending my old order to my email. Anyway reset everything and make my order again? I don't think I'm doing anything wrong cos I managed to edit my order before now.
Offline The_Ed
« Reply #112 on: Mon, 05 March 2012, 05:14:20 »
The lock switch is ON-OFF, a regular mx switch is momentary ON.
When you press the lock switch it stays down and continually sends signal. When you press it again it comes back up.
When you press a regular mx switch it sends the signal once and comes back up.
The keyboard controllers firmware would have to be changed to go into capslock state when there is continuous signal. Because normally a single signal toggles the capslock state.
The LED would already have to be desoldered to install the lock switch. The holes look to be in the same place as a regular mx switch so you shouldn't have a problem resoldering it.
R.I.P.ster
Offline 7bit
  • MX1A-G1DW
« Reply #113 on: Mon, 05 March 2012, 05:22:56 »
Quote from: The_Ed;535530
Fixed my post: they sell only PCB-mount versions.
Offline 7bit
  • MX1A-G1DW
« Reply #114 on: Mon, 05 March 2012, 05:27:18 »
Quote from: PrinsValium;535570
Just pressed my Caps lock key down for a while. It stays on. To switch it off with the lock switch, you have to press it once more to release and then once again to set the Caps Lock state to off. Not exactly the effect it should have. It would be better to map it to a modifier key (like Shift) or really change the firmware.
Offline 7bit
  • MX1A-G1DW
« Reply #115 on: Mon, 05 March 2012, 05:30:35 »
Quote from: balanar;535573
You can only add stuff, not remove it amore. Not that we ordered everything and pople jump off!
But I can remove it for you, just write m a message what you want to get rid of.
Offline The_Ed
« Reply #116 on: Mon, 05 March 2012, 05:32:36 »
Quote from: 7bit;535579
wasd only sell NN (plate mount) in red, black, blue, and brown. Phantom is selling 9 plate mount and 1 PCB mount (lock). You actually made it worse...
R.I.P.ster
Offline bpiphany
« Reply #117 on: Mon, 05 March 2012, 05:46:12 »
Quote from: The_Ed;535577
I don't know what pictures you are looking at. I am looking at these, and that LED hole is not in the same location as usual. I would say it looks like they might be using both of the rightmost LED and diode holes.
Offline The_Ed
« Reply #118 on: Mon, 05 March 2012, 05:50:06 »
Looks the same to me. You just bend the pins through the middle 2 holes like normal.
« Last Edit: Mon, 05 March 2012, 05:55:17 by The_Ed »
R.I.P.ster
Offline 7bit
  • MX1A-G1DW
« Reply #119 on: Mon, 05 March 2012, 06:06:11 »
Quote from: The_Ed;535584
OK, then I read it wrong. But my prices are still cheaper!
$1 vs. $0.57 for the reds!!!
And they don't offer whites, greens, greys, locks etc.
Offline The_Ed
« Reply #120 on: Mon, 05 March 2012, 06:10:15 »
Which is why you have my money.
R.I.P.ster
Offline bpiphany
« Reply #121 on: Mon, 05 March 2012, 06:19:16 »
Quote from: The_Ed;535590
Looky, looky at that... I was under the impression that the switch housing was going to be quite different, but the bottom at least looks just the same, except it actually looks like the leftmost holes are not holes. So I guess that might work if the leads don't get in the way of something else in there.
Offline The_Ed
« Reply #122 on: Mon, 05 March 2012, 06:26:31 »
Even the right 2 holes aren't fully cleared... Quality control was on break. Lets hope the phantom latching switches have their holes cleared. Otherwise we'll have to perform an enema.
R.I.P.ster
Offline dsjbirch
« Reply #123 on: Mon, 05 March 2012, 09:21:01 »
Is there a paypal option for Europeans? I've just spoken to my bank about transfer and they're gonna charge me ~£15 or £9 plus the costs at the other end. For £35 switches, I can't afford that!
Offline mkawa
« Reply #124 on: Mon, 05 March 2012, 11:02:05 »
gah, 7bit, please submit the order, don't let this drag on forever!
Offline 7bit
  • MX1A-G1DW
« Reply #125 on: Mon, 05 March 2012, 13:31:07 »
Quote from: mkawa;535770
Switches are already ordered!
Most of them are currently colored plastic pearls, steel coils, steel wires and a gold bar.
But soon, they will be genuine Cherry MX switches!
Offline hashbaz
  • Grand Ancient One
« Reply #126 on: Mon, 05 March 2012, 14:32:10 »
Quote from: 7bit;535906
Ah, the miracle of life.
Offline mkawa
« Reply #127 on: Mon, 05 March 2012, 14:34:10 »
yay!
« Reply #128 on: Mon, 05 March 2012, 14:45:39 »
Quote from: 7bit;535502
Just send an order!
Thought I did: I'll resend the PM to phantom.
Offline 7bit
  • MX1A-G1DW
« Reply #129 on: Mon, 05 March 2012, 15:57:23 »
Quote from: dorkvader;535990
You did it the wrong way!
It is:
MXPINK 100
MXORANGE 50
etc.
Also, you must add your e-mail address, like:
domina@sm.xxx
Offline The_Ed
« Reply #130 on: Mon, 05 March 2012, 16:02:03 »
I googled "domina@sm.xxx"...
http://lmgtfy.com/?q=%22domina%40sm.xxx%22
What sites are you on 7bit?
Click images if you're not at work.
« Last Edit: Mon, 05 March 2012, 16:05:05 by The_Ed »
R.I.P.ster
Offline captain
« Reply #131 on: Mon, 05 March 2012, 16:15:50 »
Quote from: 7bit;536069
MXPINK 100
MXORANGE 50
LIAR!  Sadly, there are no pink or orange switches.
Are there any extra teensy controllers?  I put in an extra order to phantom, but he seems to have ignored me.
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline mkawa
« Reply #132 on: Mon, 05 March 2012, 21:08:13 »
captain: you can order teensies directly from pjrc for about the same price as the gb.
Offline captain
« Reply #133 on: Mon, 05 March 2012, 21:20:48 »
Quote from: mkawa;536371
Who/what is pjrc, please?
Offline The_Ed
« Reply #134 on: Mon, 05 March 2012, 21:24:55 »
R.I.P.ster
Offline snowboarder3
« Reply #135 on: Tue, 06 March 2012, 00:56:47 »
I paid a while back. Just wanting to confirm I did everything right if it's not too much work for ya! thanks!
Offline 7bit
  • MX1A-G1DW
« Reply #136 on: Tue, 06 March 2012, 10:52:41 »
Quote from: The_Ed;536070
I just thought out that domain name and e-mail address. Are these links to keyboard porn sites?
Offline The_Ed
« Reply #137 on: Tue, 06 March 2012, 15:23:29 »
domina@sm.xxx
Quote from: 7bit;536869
Not keyboard porn, just porn. I googled it out of curiosity because "domina@sm.xxx" sounded like "domination@sadomasochism.xxx".
FOR SCIENCE!
R.I.P.ster
Offline 7bit
  • MX1A-G1DW
« Reply #138 on: Tue, 06 March 2012, 15:25:47 »
Quote from: The_Ed;537107
FOR SCIENCE!
Did you find some interesting mechanical switches?
Any Cherries?
Offline The_Ed
« Reply #139 on: Tue, 06 March 2012, 15:42:58 »
Quote from: 7bit;537109
Any Cherries?
Only filthy worn out used ones. That's why I only buy NIB!
In all seriousness I still can't find anywhere that even mentions that they once sold the MXSUPERGREYs... Who put them in the wiki?
R.I.P.ster
Offline 7bit
  • MX1A-G1DW
« Reply #140 on: Tue, 06 March 2012, 15:51:34 »
Quote from: The_Ed;537120
I think that was me, but I did not want to add them because I did not want to wait any longer with the order. There should be another switch group buy along with the next keyboard project.
Offline mkawa
« Reply #141 on: Tue, 06 March 2012, 22:06:15 »
i'm going to have enough exotic switches for the end of the world once these come in -- i'm in no hurry to redo this.
Offline The_Ed
« Reply #142 on: Wed, 07 March 2012, 00:13:57 »
I'm thinking about making a full keyboard of MXSUPERGREY. That would be cool, but I'm guessing they would be considerably louder than blues. But I can always crank my klipsch speakers or HD650 to drown that out. Reds are king for videogames, but typing is still up for grabs with me. I will be filling 10 of the 15 spots on my STB (Switch Try Board) with switches from this GB. MXSUPERGREY and ML (with an ML keycap) would make that 12. What should the final 3 be?
R.I.P.ster
Offline digitalleftovers
« Reply #143 on: Wed, 07 March 2012, 09:59:46 »
I didn't get an updated invoice after payment... Am I in?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline 7bit
  • MX1A-G1DW
« Reply #144 on: Wed, 07 March 2012, 14:22:58 »
Quote from: digitalleftovers;537777
I will send out some spam in a few hours or days....
Offline tsangan
  • 1000/600
« Reply #145 on: Wed, 07 March 2012, 16:30:37 »
Still says I owe money but I paid it like 5 days ago :|
Amount Due  |                                        |     |   |   |  19.14
Keyboardless
Offline 7bit
  • MX1A-G1DW
« Reply #146 on: Wed, 07 March 2012, 16:32:45 »
Quote from: tsangan;538196
I didn't want to send this. Wrong parameter.
I'm waiting for an update on this.
Offline tsangan
  • 1000/600
« Reply #147 on: Wed, 07 March 2012, 16:34:26 »
Recall Recall Recall!!!
Keyboardless
Offline feng
« Reply #148 on: Wed, 07 March 2012, 16:43:15 »
Same here, received the same invoice today even though I paid a few days ago.
« Reply #149 on: Wed, 07 March 2012, 16:51:13 »
Glad I'm not the only one. Paid on the 29th and it's still saying that I owe full payment.
