Author Topic: RGB Doubleshots + Wyse doubleshots  (Read 5535 times)
Offline ReAzem
  • Trade Count: (0)
« on: Tue, 28 February 2012, 23:14:02 »
http://i.imgur.com/zVf1D.jpg
I want a White on RGB doubleshot kit. (refer to the leopold keyboard on the picture)
I also would like to buy wyse doubleshots like the ones on the picture ( leopold).
  • Trade Count: (0)
« Reply #1 on: Tue, 28 February 2012, 23:17:29 »
doesnt dont look like wyse double shots
Offline ReAzem
  • Trade Count: (0)
« Reply #2 on: Tue, 28 February 2012, 23:18:13 »
If not, what are they?
I would really like help on finding them!
Or anything that looks a little like them (I would like the ones on your avatar picture lol)
  • Trade Count: (0)
« Reply #3 on: Tue, 28 February 2012, 23:19:09 »
look like cherry corp doubleshots
yeah the ones in my avy are cherry corp doubleshots
« Last Edit: Tue, 28 February 2012, 23:23:25 by demik »
Offline pitashen
  • Trade Count: (0)
« Reply #4 on: Tue, 28 February 2012, 23:25:38 »
WYSE double -> go to ebay
RBG -> there is a group buy right now.
Offline pitashen
  • Trade Count: (0)
« Reply #5 on: Tue, 28 February 2012, 23:26:12 »
Quote from: demik;530340
legend too thin to be double
could be laser
  • Trade Count: (0)
« Reply #6 on: Tue, 28 February 2012, 23:26:55 »
Quote from: pitashen;530350
could be laser
hm, yeah, you have a point.
Offline ReAzem
  • Trade Count: (0)
« Reply #7 on: Tue, 28 February 2012, 23:28:10 »
Quote from: pitashen;530347
The groud buy is Black on RGB
Thanks
Offline pitashen
  • Trade Count: (0)
« Reply #8 on: Tue, 28 February 2012, 23:33:25 »
Quote from: ReAzem;530354
Thanks
u should grab a set or two anyway. u'll appreciate that u did. coz first the resell values are pretty good. second u might find urself needing one down the road.
OK, one thing about getting those signature plastics (i.e. RBG set) or cherry corp profile keycaps. They will be a tad shorter (lower profile) than the typical ones found on Filco, Leopold, what have you. I am not sure about the WYSE profile. lysol will probably know better.
so u'll be in a world of adventure if u go for cherry corp keys.
« Last Edit: Tue, 28 February 2012, 23:44:17 by pitashen »
Offline ReAzem
  • Trade Count: (0)
« Reply #9 on: Tue, 28 February 2012, 23:39:05 »
Quote from: pitashen;530361
You just made me order haha.
Geekhack is bad for my wallet already.
  • Trade Count: (0)
« Reply #10 on: Tue, 28 February 2012, 23:42:05 »
honestly, i'd sell you one of my extra sets but i REALLY like them lol.
Offline ReAzem
  • Trade Count: (0)
« Reply #11 on: Tue, 28 February 2012, 23:43:15 »
Quote from: demik;530374
Why are you teasing me!?
I can pay! haha
Offline pitashen
  • Trade Count: (0)
« Reply #12 on: Tue, 28 February 2012, 23:45:58 »
Offline ReAzem
  • Trade Count: (0)
« Reply #13 on: Tue, 28 February 2012, 23:48:43 »
Quote from: pitashen;530380
Would you suggest any equivalent looking keys to replace the cherrycorp/wyse?
Offline pitashen
  • Trade Count: (0)
« Reply #14 on: Tue, 28 February 2012, 23:49:51 »
Quote from: ReAzem;530385
unfortunately cherry corp is the best in the world of ABS double shots for modern keyboards
this is what people are willing to do just to get a compatible caps lock key for their modern keyboard:
http://geekhack.org/showthread.php?27986-Who-bid
« Last Edit: Tue, 28 February 2012, 23:52:32 by pitashen »
Offline ReAzem
  • Trade Count: (0)
« Reply #15 on: Tue, 28 February 2012, 23:50:47 »
Quote from: pitashen;530386
unfortunately cherry corp is the best in the world of ABS double shots.
And where are they even sold?
  • Trade Count: (0)
« Reply #16 on: Tue, 28 February 2012, 23:51:05 »
the thinner wyse DS were made by SP so their profile should be the same
they aren't sold, unless a member here sells them.
you'd have to buy a donor cherry board to get the keycaps.
or wait for ascaii to run his gb again
Offline pitashen
  • Trade Count: (0)
« Reply #17 on: Tue, 28 February 2012, 23:53:31 »
Offline ReAzem
  • Trade Count: (0)
« Reply #18 on: Tue, 28 February 2012, 23:56:19 »
Hopefully I can find a cheap donor board.
Offline pitashen
  • Trade Count: (0)
« Reply #19 on: Wed, 29 February 2012, 00:05:04 »
OK i know this is going to break ur bank. But like i said, GH is only bad for your wallet if you are bad at controlling your spending :P
First get this,
http://www.ebay.com/itm/Cherry-MY1900-PS-2-POS-Keyboard-TESTED-/150697379982?pt=PCA_Mice_Trackballs&hash=item231643888e
 decent price, except u'll need to clean it and hopefully it is not too worn out. If you have problem with the PF1 2 3 key whatever... then maybe it is not for you. But if u are only going after the alphas then u should be good.
Second, depending on what you want to do... it seems u want to have a black surround to your white keys... then u'll need to spend more or a lot more to match the profile of ur cherry keys. U'll need to find a black donor board on ebay, which is easier than finding a white one. or u can ask around here
If u just want to replicate white beige cherry double shot, ur life is a lot easier. go to moogle kit group buy and order a kit to replace the incompatible keys from cherry corp. The incompatible keys include:  modifiers (alt ctrl etc), space bar and caps lock or more depending on where u harvest them from.
Regarding to the key compatibility, If you go for a full size G80 POS black board then u'll only have space bar that is not compatible. However u'll spend a lot more to get a hand on those. If u go for G81 black double shots, again u'll need to get a black moogle kit to make things close to perfect.
« Last Edit: Wed, 29 February 2012, 00:07:42 by pitashen »
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #20 on: Wed, 29 February 2012, 00:16:11 »
for $35 wait for ascaii to run Round 3 of his Beige Cherry GB its cheaper and its in better condition.
Keyboardless
Offline pitashen
  • Trade Count: (0)
« Reply #21 on: Wed, 29 February 2012, 00:17:47 »
Quote from: tsangan;530411
27 Euro + 5Euro shipping that is a bit more than 35USD. Plus ascaii  mentioned there might be a slight price increase. but u are right, the condition will probably be better.
Offline ReAzem
  • Trade Count: (0)
« Reply #22 on: Wed, 29 February 2012, 00:21:07 »
Quote from: pitashen;530401
First get this,
ascaii's Beige Cherry keys won't match with my Leopold surround?
Thanks for the help btw!
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #23 on: Wed, 29 February 2012, 00:23:36 »
Those just look pretty bad that's all and also the home cluster business.
At least with ascaii you know it's decent :D
Keyboardless
Offline pitashen
  • Trade Count: (0)
« Reply #24 on: Wed, 29 February 2012, 00:25:03 »
Quote from: ReAzem;530421
if u don't mind alphas being sunk down a bit, then u are all good.
Offline RColinTaylor
  • Trade Count: (0)
« Reply #25 on: Wed, 29 February 2012, 00:26:36 »
If there is one thing that is bad for your wallet is Geekhack.
If there are two things that are bad for your wallet its me on Geekhack.
I like my Browns more than my Blues.
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
  • Still around, sometimes.
« Reply #26 on: Wed, 29 February 2012, 15:09:13 »
If you end up buying a WYSE set, check out the Group Buy I'm running to get keys that you will likely need for a full set.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline ReAzem
  • Trade Count: (0)
« Reply #27 on: Wed, 29 February 2012, 17:39:46 »
Quote from: Quarzac;531132
Will do
