Author Topic: Open cherry switch on a plate mounted board?  (Read 4151 times)
Offline bavman
« on: Thu, 01 March 2012, 15:10:39 »
I want to mod my cmstorm /w red to browns. I have all the stuff i need but I dont want to go through the whole process of desoldering and soldering every single switch for the reasons that it takes forever and I dont exactly trust myself with that.
I watched lister's video here about removing the tops of plate mounted switches but I've had no luck.
http://www.youtube.com/watch?v=HysRQnJiupQ
I placed my screwdriver in 1 of the 4 notches on the side and pressed outwards with another little screwdriver to help open it but it doesnt work. Im pretty sure I'm doing it right because when I open the switches on a PCB mounted board it works perfectly...im guessing cause theyre no plate to get in the way.
Is there a special tool I can get that does this? Or am i doing something wrong?
Offline bavman
« Reply #1 on: Thu, 01 March 2012, 15:23:26 »
so desoldering them off is probably the best idea for me then?
will switches from a PCB board work? I think those extra 2 prongs they have are for resistors or something...can I just pull them off and not use them?
Offline bavman
« Reply #2 on: Thu, 01 March 2012, 20:13:40 »
Success!!
[ Attachment Invalid Or Does Not Exist ] 42380[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 42381[/ATTACH]
I ended up just desoldering the switches off then swapping spring and stem from the brown PCB board
« Last Edit: Thu, 01 March 2012, 20:17:33 by bavman »
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #3 on: Thu, 01 March 2012, 20:22:13 »
Looks good! Nice R3 set!
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline bavman
« Reply #4 on: Thu, 01 March 2012, 20:54:33 »
Does it count as a limited board if I put those red switches in my filco now?
Offline zirb
« Reply #5 on: Fri, 02 March 2012, 03:13:50 »
Quote from: bavman;532700
I would call it fimited, since it's kind of fake.
Awesome job, btw! Have you de-/soldered something before or was this your first time? :)
Offline bavman
« Reply #6 on: Fri, 02 March 2012, 10:58:15 »
First time doing keyboard stuff...actually anything, ive never really soldered stuff before...i freaked out because my up arrow wouldnt work when i put it back together. So i opened it up and saw that I forgot to solder that switch lol. This is pretty easy stuff though since the joints your soldering are fairly large and compared to most electronics and dont require a super steady hand or a large amount of experience/skill
But now all is good and it works perfectly.
Offline ryan92084
  • Consumer ****
« Reply #7 on: Fri, 02 March 2012, 14:03:55 »
About how long did it take?  Just asking for future reference as i may be switching to clear/ergo clear when that switch GB ships out.
RiP *ucky Shine(ing)
Offline bavman
« Reply #8 on: Fri, 02 March 2012, 14:17:55 »
about 2-3 hours. desoldering/soldering is fast, but in my case i had to pop open switches to swap their stems, thats why it took me a long time.
Offline ryan92084
  • Consumer ****
« Reply #9 on: Fri, 02 March 2012, 14:51:50 »
That isn't bad at all hopefully my soldering skills haven't gone too rusty.
Offline Roguemaster8
« Reply #10 on: Fri, 02 March 2012, 20:21:56 »
Nice job, I was going to wait until Quickfire Rapid with browns shipped to NA, but I'm afraid just how branded it will be.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
