Author Topic: $400 IPS 2560x1440 Monitor - Glossy = No AG Coating  (Read 84144 times)
Offline Blazestorm
« Reply #100 on: Mon, 12 March 2012, 14:49:42 »
Yea, some ATI cards only have a single dual-link port (One closest to the physical slot on the motherboard).
Make sure you're using a dual-link DVI cable, the one included should be one.
Offline snowboarder3
« Reply #101 on: Mon, 12 March 2012, 14:53:34 »
Quote from: Blazestorm;543534
yeah been trying to figure it out over at overclockers. I'm using the d-link port on my card now, but if I start my computer with just the shimian on that port (no other monitors), my computer doesn't boot into windows. If I try to connect after windows has started, I can see it from windows but get an error when I try to extend my display...
bummed :(
Offline Blazestorm
« Reply #102 on: Mon, 12 March 2012, 14:56:52 »
Well try it out on other machines just to verify it's the monitor.
My Catleap didn't play to well with my 5870, it works once it's in windows but not at the BIOS. I tried an Nvidia 9600gt and it worked at the BIOS (same machine otherwise).
Offline bavman
« Reply #103 on: Mon, 12 March 2012, 15:04:06 »
This is kind of bumming me out, cause I really want one of these but if im gonna run into problems with my 5850 i'll probably need another card.
It might be time to upgrade anyways
Offline BiNiaRiS
« Reply #104 on: Mon, 12 March 2012, 15:15:41 »
i got mine in today. works perfectly but i can't get it to go past 65hz which is a bummer. i'm running a 6870.
KMAC 2 w/ErgoClears
Offline turbocharged
« Reply #105 on: Mon, 12 March 2012, 15:44:37 »
Ordered mine from dream-seller on the 7th (Korea time) and it shipped/got my tracking number today the 12th.
Binaris, how long did it take you to get it from the time it was dropped off at the post office in Korea?
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline BiNiaRiS
« Reply #106 on: Mon, 12 March 2012, 16:20:53 »
Quote from: turbocharged;543597
about 4 days.
and it looks like there's some new confirmation that these are not all able to run at 85hz+
so far mine isn't. one guy bought a second one that doesn't OC, but his first one does.
KMAC 2 w/ErgoClears
Offline Kisakuku
« Reply #107 on: Mon, 12 March 2012, 16:26:14 »
Soon we will be OC'ing keyboards!
« Reply #108 on: Mon, 12 March 2012, 19:04:40 »
Tested my monitor on a friends 560ti. Black screen with backlight on still. Computer recognizes no monitor, but no video output. New dvi-d cable is in the mail to test. Hopefully it's just that and not DOA.
Offline Blazestorm
« Reply #109 on: Mon, 12 March 2012, 19:50:57 »
You might take it apart, the main video cable might have came loose during shipping.
I disassembled my Catleap and I had similar issues. It would be detected by windows but I just saw a blank screen w/ back-light. Turns out I just didn't have the internal video cable plugged in all the way. I had 3 cables internally. Power for backlight, Signal, and Buttons/Power Light.
Works now though.
« Last Edit: Mon, 12 March 2012, 20:10:58 by Blazestorm »
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #110 on: Mon, 12 March 2012, 20:09:25 »
sorry to hear it dudes :( at least it sounds like it's easily fixable.
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #111 on: Mon, 12 March 2012, 21:19:56 »
If someone else does have to do that to fix it, could they take a couple pictures detailing the job?
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #112 on: Mon, 12 March 2012, 22:29:18 »
Quote from: BiNiaRiS;543638
Hmm, sorry to hear that... what do you think of the image quality and color reproduction?  What do you have that you are comparing it to?
Filco w/ Imsto thick PBT
« Reply #113 on: Mon, 12 March 2012, 23:09:24 »
The university just threw out another FW900. I am going to take that and see if it works. Sure the resolution (1920*1200) is a bit lower, but I do like the old one I had before it died.
Hopefully I'll get it before they e-waste it. Any tips on borrowing cars from your friends?
Offline minnus
« Reply #114 on: Mon, 12 March 2012, 23:25:31 »
Mine has dead pixels :(
Offline bavman
« Reply #115 on: Mon, 12 March 2012, 23:39:09 »
Quote from: minnus;544126
Which brand did you get, and how many did you have?
Offline notnay
« Reply #116 on: Tue, 13 March 2012, 00:47:42 »
Christ these look amazing. Hopefully we won't have too many dead pixels floating around...
Offline BiNiaRiS
« Reply #117 on: Tue, 13 March 2012, 01:54:40 »
Quote from: alaricljs;544072
I'm coming from a Samsung 22" TN so it's a huge upgrade for me. I don't do any digital photography so I can't really comment on color quality. I will still I'm beyond impressed. Just go look at the new 27" Apple displays...it's the same panel from LG.
Mine had one. There's some stuff you can do to possible fix them though.
But dead pixels are really hard to see at this resolution. I had to look pretty hard to find my one.
KMAC 2 w/ErgoClears
Offline mkawa
« Reply #118 on: Tue, 13 March 2012, 05:33:00 »
you can try attempting to rapidly cycle the pixel. if it's a glossy but not glass screen, you can try rubbing the area as well, but it's pretty unlikely to do much with pixels that small, and it's just as likely to break another nearby pixel as it is to fix the stuck/dead one
Offline minnus
« Reply #119 on: Tue, 13 March 2012, 15:50:19 »
I got the Catleap Q270 SE. I have two 'dead' pixels. One is black (presumably dead), and the other one is stuck? It is white. I think it is actually more than 1 (looks to be a cluster of around 3/4) black.
Regardless ~ I'd stay away from these monitors if you must have a perfect panel. It is very evident to me at this point that these monitors are cheap because they are somewhat flawed. I think the flaws are simply less noticable for those who have 'perfect' monitors.
The seller I was interacting with basically told me that there are two models - a guarenteed flawless one, checked by the company themselves, and one that is not flawless. If they are going through the troubles of checking it, then it is obvious that those not classified as flawless...is not.
Offline Blazestorm
« Reply #120 on: Tue, 13 March 2012, 17:04:35 »
Just because it's not checked doesn't mean they're not flawless.
Mine had no dead/stuck pixels and many others have also received perfect displays.
The pixels are small enough that it's getting hard to notice them unless your face is against the screen.
Offline BiNiaRiS
« Reply #121 on: Tue, 13 March 2012, 17:26:30 »
Quote from: Blazestorm;544899
The panels have been confirmed to be A- grade. Not really sure what that means compared to A grade panels, but mine arrived with 1 dead pixel and I'm not going to complain at all. I can only see it when i use programs to check for it since it's so small. It's even close to the center of the screen and it doesn't bother me. If you want a 100% guaranteed flawless panel spend $900 and buy one in the US.
Also blaze, thanks for the inner cable tip. I just took apart my cat leap to remove the ****ty stand and add on the 3M one I got (love it by the way) and when i put it 1/2 back together to test it wasn't working. It was the cable you mentioned. It is behind tape so I hadn't noticed that it had come loose. Snapped it back in and it works perfectly now. I highly recommend this stand...spring loaded height adjustment is so nice. The monitor is too wide to use it in portrait mode though, but I never planned on using that so meh.
KMAC 2 w/ErgoClears
Offline minnus
« Reply #122 on: Tue, 13 March 2012, 17:28:37 »
You may be right. I am merely speculating. It seems that a lot of people bought these monitors because everyone else have been reporting flawless screens. Now that a wave of shipments have been received, a lot more "flawed" comments are being made. Mine was also unable to OC hertz wise. It seems that the controller has been swapped to ones with lower quality.
Offline RiGS
« Reply #123 on: Tue, 13 March 2012, 17:37:48 »
Even if they check the panel for dead or stuck pixels prior sending it, **** could still happen during shipping.
Quote from: minnus;544927
Sounds like PEBKAC.
« Last Edit: Tue, 13 March 2012, 17:40:45 by RiGS »
Offline BiNiaRiS
« Reply #124 on: Tue, 13 March 2012, 17:39:02 »
people were buying them because they are 1440p S-IPS Glossy screens with low lag for under $400 and people will continue to buy them because they are so cheap. At $400 there's really no room to complain unless you got an abnormal amount of dead pixels. One guy on OCN said he had 4-5 dead pixels and the seller is going to pay to return it and send him a new one...that blows my mind.
KMAC 2 w/ErgoClears
Offline Blazestorm
« Reply #125 on: Tue, 13 March 2012, 17:40:19 »
The A+ panels are just guaranteed by LG to be perfect, so Dell/Apple can sell them and not worry about testing them. A- is still the same panel, it's just not guaranteed to be perfect. It's not mutually exclusive is all I'm saying.
Apparently a 3007WFP-HC I used for 2 years had a stuck pixel that I never noticed even after scouring over the screen twice. The buyer saw it in person and checked himself for 5-10 minutes and gave it the OK. Then e-mailed me the next day saying he found a stuck pixel. Basically at this resolution I don't even notice it. I would go as far to say don't even bother checking your display. Just use it, and if you notice any flaws you notice them. That's how I plan to deal with the next 3 Catleaps I'm buying :)
Offline BiNiaRiS
« Reply #126 on: Tue, 13 March 2012, 18:11:34 »
Quote from: Blazestorm;544948
even the flawless ones aren't flawless 100% of the time :)
KMAC 2 w/ErgoClears
Offline alaricljs
« Reply #127 on: Tue, 13 March 2012, 20:18:50 »
I've actually had dead pixels come and go... sometimes the same pixel sometimes not.
Once you use the monitor for a while you're likely to have more dust blocking pixels than dead pixels and still not bother to clean the screen for another couple weeks at least.  (barring OCD types)
Offline Lpb45
« Reply #128 on: Tue, 13 March 2012, 23:36:40 »
People are confusing dead pixels(unfixable) and stuck pixels(fixable),  im sure someone will try and argue semantics over this.  If the pixel is dead it should be black,  any other color and and it is a stuck pixel.  As for people getting multiple stuck/dead pixels, that really sucks but the plain and simple fact is that these high res monitors just have alot more pixels that can go bad.  I went through 3 HPzr30w's before I got one without a stuck/dead pixel and it is supposedly an A+ panel,  just check some of the 30/27 inch IPS monitor threads on [H] and OCN and see how often it happens.
It still stands that these are 2560x1440 IPS no AG coating monitors for right around $400,  **** im considering selling my zr30w and getting 3 of them and paying them to bin em so I have a higher chance of no stuck/dead pixels for eyefinity(mmmm).  The fact that this deal even exists is amazing.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline elbowglue
« Reply #129 on: Wed, 14 March 2012, 03:21:59 »
So I pulled the trigged on one of these from green sum, hope I get an overclockable panel.
In terms of a stand do you guys think this one would work for it?
http://www.ebay.com/itm/MONITOR-MOUNT-LCD-Monitor-Mount-Ergotron-Monitor-33-326-055-Universal-/150692964531?pt=LH_DefaultDomain_0&hash=item23160028b3#ht_715wt_905
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline omuerte
« Reply #130 on: Wed, 14 March 2012, 03:48:08 »
I messaged green-sum and asked if there was an option to open the box and check for dead pixels before shipping. I'll have to dig up his reply but apparently there's a $60 or $65 option for the mfgr to guarantee that the screen has zero defects.
Would you guys who've bought Q(H)270's  say you're pretty damned impressed with them? I'm really close to pulling the trigger on one, then possibly a second in a month or two, but I want a little more feedback first.
Also, did you go with tempered glass or bare display?
Click Clack
Offline Blazestorm
« Reply #131 on: Wed, 14 March 2012, 03:53:46 »
It's not looking good on the overclockable Catleaps unless you buy a Tempered glass version, simply because they sold less often and it appears the older versions are still in stock
I wouldn't recommend that Ergotron stand, I know this one works (I have my Catleap mounted on one right now)
http://www.ebay.com/itm/280826234518
Offline elbowglue
« Reply #132 on: Wed, 14 March 2012, 03:58:15 »
I'm going for a tempered glass one hope to get an overclockable one..
Darn now I need to find a good deal on a stand.  $40 for that one that you listed.
Hey blazestorm, with that ergotron stand, does the monitor lower all the way down to almost touch the desk?  I think with a 27 inch monitor I'm almost going to want it to touch my desk to be appropriate height.
Quote from: omuerte;545525
« Last Edit: Wed, 14 March 2012, 04:04:05 by elbowglue »
Offline BiNiaRiS
« Reply #133 on: Wed, 14 March 2012, 05:25:10 »
Quote from: elbowglue;545534
it goes to about 1-2cm from the desk. it's really nice. i have the 3m branded version but it's the same mount.
KMAC 2 w/ErgoClears
Offline Blazestorm
« Reply #134 on: Wed, 14 March 2012, 05:56:17 »
Mine sits flush with the base at the lowest height in landscape. Sits flush at the highest height in portrait.
« Reply #135 on: Fri, 16 March 2012, 00:02:10 »
Does anyone know how to open up the shimian?
« Reply #136 on: Fri, 16 March 2012, 05:12:27 »
Got my Yamakasi Catleap Q270 in yesterday and I am extremely pleased. I can't find any dead pixels and I don't think I can ever go back to a 1920 resolution....this is just awesome.
[SIGPIC][/SIGPIC]
Offline omuerte
« Reply #137 on: Sat, 17 March 2012, 06:27:14 »
Pulled the trigger on a Catleap Q270 today - I'll report in when it arrives. If it's awesome I might order a second ;)
Click Clack
Offline WhiteFireDragon
    • youtube
« Reply #138 on: Wed, 21 March 2012, 08:57:53 »
Did these just get cheaper? I see $361.90 from the ebay link.
Offline Reptile
« Reply #139 on: Wed, 21 March 2012, 09:25:06 »
Quote from: WhiteFireDragon;552372
On the Achevia yes I see $361.90
Hoping the catleap monitors will continue to drop :amen:
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline elbowglue
« Reply #140 on: Wed, 21 March 2012, 11:13:30 »
Some ergotron stands for these monitors:
http://www.ebay.com/itm/330705339847?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2067wt_885
I offered $30, they accepted, you might be able to get it for less..
Offline Blazestorm
« Reply #141 on: Wed, 21 March 2012, 11:53:22 »
http://www.overclock.net/t/1232084/yamakasi-catleap-q270-100hz-guaranteed
Guys on Overclock.net are working towards getting 120hz capable boards back in the Catleaps / special edition manufactured. Figure some people might be interested.
Offline kidchunks
« Reply #142 on: Wed, 21 March 2012, 20:20:18 »
Quote from: Blazestorm;552556
Saw that link posted earlier on [H]. I put in my vote. :) Definitely be down for buying two if they end up making them.
Topre || BS > *
my root : kidchunks[dot]com
Offline mkawa
« Reply #143 on: Wed, 21 March 2012, 20:24:15 »
haha what
*****es be crazy
Offline ThePringler
« Reply #144 on: Thu, 22 March 2012, 13:27:13 »
Will this run fine on my ATI 3870x2 Graphics card? Spent about ~$700 on this baby about 5 or 6 years ago I believe. Completely out of the graphics card loop now.
Thanks!!
Offline Phil21
« Reply #145 on: Thu, 22 March 2012, 14:55:31 »
I've had one for a few days now.  It's sitting right next to my Dell 27" screens, and honestly I prefer it for some things so far.
The glossy screen is much nicer for text, if you're in a light-controlled area.  Reading text just seems so much nicer on the eyes that w/ the AG coating.  The Dell's have much less light bleed, and do seem to be more viewable off-angle than the catleap.  Otherwise the viewing experiences are very similar.
It came with a bad DVI cable, so I was pretty bummed for a bit until I tried one I already had.  Otherwise worked great out of the box, with one stuck pixel that I've found which is not noticeable.
The shipping was pretty crazy too - I got this 3 days after I submitted the order, and it came in a GIANT box via USPS.  I was expecting a week or two, based on prior shipping experiences from that area of the world.
The only thing that really sucks on these is the stand - get your own aftermarket stand if you don't already use monitor arms.
Offline Wildcard
  • When caffeine isn't enough
« Reply #146 on: Fri, 23 March 2012, 02:38:46 »
Quote from: Phil21;553797
Don't know if this has changed much with the new LCD's, but sometimes you can "un-stick" a bad pixel. Use something soft like a white eraser on a mech pencil and place it over the stuck pixel. Wiggle it with medium to high force for a few seconds and then release. If it doesn't work the first time, repeat just once more.
Offline mkawa
« Reply #147 on: Fri, 23 March 2012, 12:30:36 »
good information about these from tftcentral:
http://www.tftcentral.co.uk/news_archive/26.htm#korean_ips27
Offline bavman
« Reply #148 on: Sun, 25 March 2012, 21:09:52 »
I really wanna buy one of these but everyday they seem to get cheaper. I don't know how much longer I can wait.
Can someone also clarify something for me? All of the ads say that it doesn't work with 5850/70. But people say it works, but you can't view BIOS. Is this the case for every card? or just some of them?
« Last Edit: Sun, 25 March 2012, 21:13:09 by bavman »
Offline Tennobanzai
« Reply #149 on: Thu, 29 March 2012, 01:59:32 »
Quote from: bavman;556688
Are you talking about the DPs? If so I think they had some problems on the 58xx series
Edit: nvm, I guess these monitors dont have DP. I thought it would since mine does and they have the same panel
« Last Edit: Thu, 29 March 2012, 02:17:31 by Tennobanzai »
