Author Topic: How do you install Xubuntu ontop of ubuntu to how you install gnome  (Read 1656 times)
Offline twilek
Hi, I need to install xubuntu because frank, unity and gnome 3 are bull. So can someone tell me the terminal commands for this.
fossala
  •  Guest
« Reply #1 on: Mon, 05 March 2012, 15:29:56 »
apt-get install xubuntu-desktop
Seriously thought pick the right forum for the right questions.
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Mon, 05 March 2012, 16:27:49 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 13:41:32 by davkol »
fossala
  •  Guest
« Reply #3 on: Tue, 06 March 2012, 01:29:57 »
Sorry I don't normally use ubuntu so I just use root.
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
« Reply #4 on: Tue, 06 March 2012, 02:32:11 »
Quote from: fossala;536648
LOL.  I'm also not a big fan of ubuntu's sudo.  I usually just type in "sudo su," work as root, then exit.
BTW OP if you haven't heavily customized your system, I would recommend just doing a fresh install of Xubuntu, in order to minimize the amount of bloat.  Installing XFCE on top of an existing Ubuntu installation is just messy in my opinion.  Then again you could just remove all of the bloat after installing XFCE, but that would probably take quite a while LOL.
fossala
  •  Guest
« Reply #5 on: Tue, 06 March 2012, 02:37:45 »
Don't type "sudo su" it creats security problems. What you should do is "sudo passwd root" because root exists it just doesn't have a password.
On a side not why use ubuntu, they are not opensource everything except ubuntu os is closed source (ubuntu one, ubuntu for andriod) even ubuntu os nags you to install propritary drivers. Use a good os like Debian or OpenBSD.
Offline cactux
  • Topre Knight
« Reply #6 on: Tue, 06 March 2012, 03:22:59 »
su -
[FS]☠ The temple lol ->HERE<-
Offline quickcrx702
« Reply #7 on: Tue, 06 March 2012, 09:08:01 »
Quote from: fossala;536700
Root always has a password on my boxes :)
I always do the following when setting up a machine:
sudo su
passwd
Why does "sudo su" create a security problem?
If you really want to take the time and setup your installation, Arch is the way to go.
Offline cactux
  • Topre Knight
« Reply #8 on: Tue, 06 March 2012, 14:19:51 »
^ +1
