Author Topic: IBM Model M NEW 6ft SDL 6 Pin to USB Converter cables and adapters available  (Read 47744 times)
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
I see these cables went down to $35 now.
Offline dragonxx21
  • Trade Count: (0)
Would this be a good alternative to soarer's adapter?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
Soarer's adapter is really only necessary for older boards with different protocols or connectors. Many Model Ms come with PS/2 connectors, so they're easy to connect and use with many computers. Unfortunately, many newer motherboards and laptops don't come with PS/2 ports. If you wanted to use your Model M on one of these, you could use a PS/2 to USB adapter with the original cable, or get one of these to replace the cable altogether.
Offline dragonxx21
  • Trade Count: (0)
Well I use a laptop and I'm unsure of what would be best. I'm leaning towards soarer because of the remapping ability.
Keyboards Owned:
  • Trade Count: (1)
That is an apples-to-oranges comparison.
Orihalcon's sleek USB cables are simple, clean, single-task, and work flawlessly.
Soarer's Converter / Teensy is a do-it-yourself toolkit that requires time at the workbench but provides a wide range of options. It also takes some (perhaps considerable) effort to make it attractive or hidden.
- D Trump 2026-10-24
Offline Hellmark
  • Trade Count: (0)
To be honest, I'm kinda surprised I've not seen someone come up with a replacement controller for the M where you could pop a Teensy in, for an internal soarer conversion.
  • Trade Count: (1)
That would not be hard to do. There is plenty of room inside, but would it really gain you anything?
Offline Hellmark
  • Trade Count: (0)
It would make things a bit cleaner. No worrying about having any external enclosures, extra cables, etc.
  • Trade Count: (0)
Old thread, and I hadn't realised that orihalcon was a member here, but I have one of these cables and it works fine with my Model M on my Mac.
  • Trade Count: (1)
There is nothing cleaner than orihalcon's cable. It is a direct replacement for the original coiled cable.
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
Has anyone tried the cheaper SDL to PS/2 cable he makes?
Offline IonutZ
  • Trade Count: (0)
  • Stay awhile and listen
    • SC
Hey is there any chance that I can get one of these USB cables WITHOUT a chipset in them? Just a USB to Model M socket cable. Behind the cable I have a Soarer's converter which already does the PS/2 -> USB conversion with full NKRO.
Offline joneslee85
  • HHKB Scrub JP
  • Trade Count: (0)
  • Professional Rubyist programmer!
    • Ruby Journal
It's great cable. Wonder if anyone out there made USB to SDL coiled cable?
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline ComradeSniper
  • HHKB Pro
  • Trade Count: (0)
I'm not sure why you'd want coiled, tbh. The stock coiled cable on my M just gets in the way.
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
Holy **** jones you've resurrected quite a lot of threads these past couple days
Offline joneslee85
  • HHKB Scrub JP
  • Trade Count: (0)
    • Ruby Journal
I would love to buy 2 if you do customised coiled version
Offline joneslee85
  • HHKB Scrub JP
  • Trade Count: (0)
    • Ruby Journal
There is something special about coiled cable that reminds me about my childhood when I first have my PC running DOS.
Offline orihalcon
  • Trade Count: (0)
Hi guys, I'll be relisting these soon as I realize that the original post is getting to be almost two years old now.  I'll try to make a habit of checking my PM's daily again.  Thanks!
Offline Michael
  • Formerly Bro Caps
  • Trade Count: (0)
I have bought several of these in the past. Amazing work, and solid quality. A+++++
Offline tjcaustin
  • King Klaxon
  • Trade Count: (0)
    • Buy stuff
Right after I bought one on ebay.  Oh well, still means I don't have to buy a hugely expensive crimp tool and keep huge stocks of plugs and chips in my house.
Offline Muffin860
  • Trade Count: (0)
If I buy this:
http://www.ebay.com/itm/USB-Female-Soarers-Converter-for-Mechanical-Keyboards-Remapping-Macros-NKRO-/301452854832?pt=LH_DefaultDomain_0&hash=item462ffd8630
And use it to make my Rapid-I programmable: Would the keyboard still retain the function of the led modes? Also, I'm assuming that if I used one on a numpad that did not send real numpad scancodes, I could program it to do so? Thanks in advance.
IBM Model M
Offline iw0rm3r
  • Trade Count: (0)
Re: IBM Model M NEW 6ft SDL 6 Pin to USB Converter cables and adapters available
« Reply #71 on: Sat, 10 February 2018, 08:45:53 »
I've got a IBM Model M from 1988 with detachable PS/2 cable, and I want to be able to swap my gaming keyboard with this one by hotplugging it (without restarting the PC). PS/2 interface doesn't let me do this so I've searched for the solutions a little and found your conversion cable. So the question is: can I hotplug Model M using your cable that is already connected to PC (so that I won't have to reconnect the USB end to PC every time)? And the second question: as I know, your cable is based upon Soarer's software, so is it possible to modify keyboard layouts with your cable etс.?
P.S. Sorry for my bad English.
  • Trade Count: (1)
« Reply #72 on: Sat, 10 February 2018, 09:38:49 »
The answer to both questions is "yes"
Orihalcon's cables can be hot-plugged and the chip inside can be re-mapped. The computer will only see one of them at a time, however, if you ever get more than one.
Offline iw0rm3r
  • Trade Count: (0)
« Reply #73 on: Sun, 11 February 2018, 05:34:58 »
Thank you. And where can I download the software to re-map the chip?
  • Trade Count: (1)
« Reply #74 on: Sun, 11 February 2018, 09:08:38 »
I believe that Orihalcon will give you instructions with the purchase of his converter cable, otherwise wcass gave an easy re-mapping technique in reply #560
https://geekhack.org/index.php?topic=17458.msg335414#msg335414
and there is a spreadsheet with scan codes and HID_listen values in Soarer's original docs.
Offline Tactile
  • Trade Count: (2)
« Reply #75 on: Sun, 11 February 2018, 09:10:24 »
The first post in this thread.
REΛLFORCE
