Author Topic: Which switch is this?  (Read 1634 times)
Offline 1391406
« on: Tue, 13 March 2012, 14:10:09 »
I just received the FK-2001 I ordered and was wondering if anyone would be so kind as to identify which switch this is, if possible?
Offline stingrae
« Reply #1 on: Tue, 13 March 2012, 14:15:30 »
Quote from: 1391406;544702
white alps?
Says alps, is white, seems logical.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline 1391406
« Reply #2 on: Tue, 13 March 2012, 14:28:35 »
I was hoping there wasn't an off-chance it was Simplified Type IV but rather Complicated.
Offline REVENGE
« Reply #3 on: Tue, 13 March 2012, 14:36:08 »
The non-Windows key FK2001s are supposed to have complicated white ALPS. Check the wiki for more info and a guide to opening white ALPS switches.
Offline Magna224
« Reply #4 on: Tue, 13 March 2012, 15:25:00 »
I think its complicated, in more ways than one. Opening it would be the best choice though but be very careful when putting it back together to get everything lined up correct.
Offline eltocliousus
« Reply #5 on: Tue, 13 March 2012, 16:56:45 »
Quote from: ripster;544800
ALPS is like a box of chocolates.
If you start mashing them they'll turn into a gooey mess?
Offline stingrae
« Reply #6 on: Tue, 13 March 2012, 17:42:41 »
Lol.
You REALLY have to open it up to tell.
Have you been watching Forest Gump recently?
but fair enough I can't argue with you I just thought the question wasn't defined enough so I gave the most obvious answer, always the wrong thing to do!
Offline rknize
    • metaruss
« Reply #7 on: Tue, 13 March 2012, 18:46:42 »
I'm uncertain about your wikis as well.
Russ
Offline rknize
    • metaruss
« Reply #8 on: Tue, 13 March 2012, 19:03:58 »
This why I won't vote in your poll.  You are better off in the box.
Russ
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #9 on: Tue, 13 March 2012, 19:13:36 »
Quote from: 1391406;544719
Looking through the ALPS switch wiki – indeed complicated and type I simplified look identical from the outside. Can't tell with type IV as there isn't a clear photo. Type II (XM) are obviously different in shape, and those are the rubbish ones that you want to avoid.
I seem to recall reading that opening up complicated ALPS is a bad thing as they're much harder to reassemble, so make sure you choose a worthless switch like scroll lock to inspect.
I don't think that any stigma should be attached to simplified ALPS in general – after all, they're our best hope of getting new and exciting boards produced, such as HHKB ALPS ... Oh look, a pig, up there in the sky ...
I set my Tactile Pro 3 up on my desk again earlier and after spending quality time with an Acer 6312, I was surprised how light and smooth the Type I switches were on the Tactile Pro 3. The tinny, pingy sound of Type I simplifieds is what bothers me more – but that may be more to do with the way Matias build keyboards, as I don't have a FILCO Zero Fukka for comparison (I would LOVE a Fukka FILCO Zero 105, do you hear me Diatec??)
XM switches are the hated ones, as they're so stiff and difficult to type on, and you won't have those.
Bore Awards
Offline rknize
    • metaruss
« Reply #10 on: Tue, 13 March 2012, 20:59:15 »
Quote from: ripster;545145
Anyway Quantum mechanics is all about statistics and THIS is statistically significant results.
http://geekhack.org/showthread.php?26781-Do-you-think-Ripster-is-the-1-Keyboard-Expert-on-Planet-Earth
Statistics and quantum mechanics are funny that way.  The outcome often defies logic.
 With respect to your poll, I would feel more inclined to reply if it didn't deal in such absolutes.  If it asked something along the lines of, "is Ripster, overall, a knowledgeable resource in the area of mechanical keyboards despite his penchant for posting such," I would be more inclined to respond.
I don't expect you to like this post, since it was written on my DROID Razr MAXX using Tapatalk.
Russ
