Author Topic: Double shots or not?  (Read 3441 times)
Offline Mikelittoris
« on: Thu, 15 March 2012, 10:56:53 »
Found some keyboards on ebay and I was wondering about them keycaps. I think they look quite cool, and i've seen similar boards with double shots. Does anyone know something about these boards?
Here's the link: http://www.ebay.co.uk/itm/ALPHAMERIC-KEYBOARD-EO64MPC-AC-/300580368606?pt=UK_BOI_Retail_Shop_Fitting_POS_Equipment_ET&hash=item45fbfc70de
IBM Model M SSK -91 (Bolt moded), Geekhack ESC, RGB modifiers and lt blue WASD cluster.
IBM Model M -95
IBM Model N2 -94
IBM Model F -85 (122-key Terminal) Using a Teensy with Soarer\'s adapter code.
Offline Autolyze
« Reply #1 on: Thu, 15 March 2012, 13:30:30 »
I'm not positive about that board in particular, but I do know that Devlin makes some flat doubleshots that look a lot like the ones pictured. POS keyboards often see quite a bit of use, so I think it's pretty likely that those ones are doubleshots.
