Author Topic: I think i'm sick.. with the Mechanical fever!  (Read 7198 times)
Offline NYC
« Reply #50 on: Tue, 27 March 2012, 17:17:41 »
would just go for new so you dont worry about nothing at all your first to open~
Camo Filco Cherry Blues tkl, White Filco Majestouch 2 Cherry Browns tkl
Offline Homiko
« Reply #51 on: Tue, 27 March 2012, 17:39:49 »
Quote from: NYC;558522
but I want to "real thing" the ibm model m is the first one and the unicomp is the one that came after.
but still you are right, I'm still new and I don't want to get stuck with a keyboard that will brake or something after a year.
still thinking..
Offline Soarer
« Reply #52 on: Tue, 27 March 2012, 19:12:44 »
Hmm, I dunno. I guess I had roughly the same choice when I wanted my first buckling spring, but it was biased by the fact that I could get the IBM here vs paying hefty shipping and taxes to get a Unicomp sent over from the US. Have a read up about bolt-modding the IBM before you decide, because that fixes the most likely fault you'll find with a Model M, which is broken plastic heat-stakes (aka rivets).
Offline slueth
« Reply #53 on: Tue, 27 March 2012, 19:23:52 »
I would get the cheap Kentucky keyboard from Unicomp, I prefer Unicomp keyboards because they have that windows key and also it is USB :D.
Offline Homiko
« Reply #54 on: Wed, 28 March 2012, 12:35:01 »
Quote from: slueth;558591
I don't really use the windows key i usually turn it off..
Offline slueth
« Reply #55 on: Wed, 28 March 2012, 12:53:50 »
hmm.. Unicomp has versions that do not have window keys as well, just trying to get you to buy from Unicomp, gotta keep em alive and all :D
Offline Homiko
« Reply #56 on: Wed, 28 March 2012, 16:24:02 »
Quote from: slueth;559404
lol, I think I will go with the unicomp one after all, thnx ;)
