Author Topic: I'm interested in trying Alps switches. What's a good keyboard to look for?  (Read 2971 times)
Offline megnin
  • Topre, or not Topre? That is the question.
After reading a couple of the Wiki's I think I'd like to try Alps switches, maybe Simplified Type I.  What keyboard would you suggest I look for?  I'm thinking about looking for a Filco Zero if that would be a good choice, since I like Filcos.
Thanks for any suggestions.
« Last Edit: Fri, 30 March 2012, 07:59:34 by megnin »
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline NorrisB
« Reply #1 on: Fri, 30 March 2012, 07:45:36 »
That or you could get a Ducky 1087XM new, id try green alps
Offline Wildcard
  • When caffeine isn't enough
« Reply #2 on: Fri, 30 March 2012, 07:52:16 »
Quote from: megnin;561452
After reading a couple of the Wiki's I think I'd like to try Alps switches, maybe Simplified Type I.  What keyboard would you suggest I look for?  I'm thinking about looking for a Filco Zero since I like Filcos.
If you could find a Filco zero that would be a good option. If you don't mind a large enter key, you could try a Solidtek 6600. Here's one on ebay for $39.00 + shipping here
Offline Wildcard
« Reply #3 on: Fri, 30 March 2012, 07:55:27 »
Quote from: NorrisB;561453
The Ducky is a good board, wonder if it still comes with that keychain freebie? But I believe green alps are type II and just slightly heaver.
Offline NorrisB
« Reply #4 on: Fri, 30 March 2012, 07:57:06 »
Green alps are similar to blues and bottum out at 50g
Offline megnin
« Reply #5 on: Fri, 30 March 2012, 08:08:27 »
Quote from: RiffRaff;561456
I saw that Solidtec on eBay.  I'm afraid I can not abide a large enter key.
Quote from: NorrisB;561459
That sounds good.  If I can't find a Filco Zero I'll look for a Ducky 1087XM.  I hope it's a TKL.
It looks pretty good from this: http://geekhack.org/showwiki.php?title=Island:23427
Offline megnin
« Reply #6 on: Fri, 30 March 2012, 12:41:08 »
Thanks for the advice.  From what I've seen of its availability it should not be hard to avoid the Filco Zero.  ;-)  I guess after I get paid I'll start looking for a Ducky XM Green.
Are there any vintage keyboards that can occasionally be found for a good price?  The Wiki lists a lot of keyboards but doesn't indicate your likelihood of finding any of them.
...I still want a Filco Zero though.  ;-)
Offline Magna224
« Reply #7 on: Fri, 30 March 2012, 16:03:31 »
Me too.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
« Reply #8 on: Fri, 30 March 2012, 16:21:31 »
ducky's alps felt a lot stiffer than blues.
Offline xquisit
« Reply #9 on: Sat, 31 March 2012, 21:20:38 »
Quote from: dante;561844
I didn't have mine very long (for obvious reasons :) but they do tend to break in after a week or two.
Someone here took a 1008XM and dumped all the switches into his AT101W; really great idea!  Although if you're going all the way throw them in a Northgate Ergo.  That would be shizzle de lizzle.
I'm new here and I see you picking up new stuff and letting it go so quickly. :]
Not bashing, just stating what I noticed - sorry for OT.
I\'d rather die like a man than live like a coward - 2pac
Offline xquisit
« Reply #10 on: Sun, 01 April 2012, 00:13:58 »
I hear you, I hope I like my KBT Race.
Maybe, I should sell my pre-order and get a Pure, because I always use the right shift to capitalize & the right shift is small as you know. I'd have to either use the left side of the right shift, or start using the left. Not sure what to do, because I am a tad impatient (for no reason, my computer won't even post).
Sorry to derail the thread, and I hope you find what you're looking for (both you and the OP).
