Author Topic: Dim KBC Poker LED's  (Read 18383 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Dim KBC Poker LED's
« Reply #50 on: Fri, 13 April 2012, 22:38:55 »
vortex is a very small outfit. they're good guys, but they're just enthusiasts like us, quite frankly. sorry to hear about the LEDs :(
on the upside, the LEDs are easier to replace than the SMD resistor you replaced
Offline Brendan
Dim KBC Poker LED's
« Reply #51 on: Sun, 15 April 2012, 21:50:51 »
I understand but they act like it's not a problem, that it should be fixed in the Pure. Well, I don't happen to own a Pure but rather a Poker and I feel like if there's no support for old models at all.
Offline mkawa
Dim KBC Poker LED's
« Reply #52 on: Mon, 16 April 2012, 00:06:22 »
my feeling is that until they find a US distributor with the ability to repair units, that actually will be the case :(
Offline net2522
  • lollollollol
Dim KBC Poker LED's
« Reply #53 on: Mon, 16 April 2012, 00:11:45 »
Did you try to change LED. I heard they're said is a quality of the LED that's the problem.
Offline Brendan
Dim KBC Poker LED's
« Reply #54 on: Wed, 18 April 2012, 20:31:53 »
That's odd as it's ONLY the arrow keys that are affected, and all 5 stay the same brightness. The escape key and cap locks functions fine, it's too big of a coincidence for me to believe that the LED's are to blame. Here's what I got back from them:
Vortex Keyboard
    hi, I think we got 2 way can solve your LED problem ,
    1 . I can send spare parts (LED) to HK seller, and he can send spare parts to you , but shipping cost you have to pay ( only HK seller to you)
    2. send your keyboard to HK seller , fix keyboard and return to you ,
    so , how do you think about that , or do you want try Pure ??
What should I do?
Offline mkawa
Dim KBC Poker LED's
« Reply #55 on: Wed, 18 April 2012, 23:16:55 »
tell them you want to try a pure, and have them send the pure to me ;)
but really, i'd avoid 2. 1 should actually be pretty inexpensive. i get stuff shipped from HK all the time. it's pretty cheap.
Offline Brendan
Dim KBC Poker LED's
« Reply #56 on: Mon, 30 April 2012, 23:19:01 »
I'm waiting for the distributor to contact my dad in HK, but so far, nothing.
