Author Topic: HHKB 2 Hub not enough power?  (Read 5837 times)
Offline trax
« on: Wed, 04 April 2012, 15:21:05 »
I got a mini USB stick for my HHKB PRO 2 but due to some weird reason it says that theres not enough power for the connected device?
Hows this possible? Its only an usb stick.
Also got a bigger/older USB stick that does work :(
« Last Edit: Wed, 04 April 2012, 15:24:19 by trax »
Switches tried so far
Cherry MX Red Blue Black Clear
ALPS White Black (fake)Blue
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline captain
« Reply #1 on: Wed, 04 April 2012, 15:23:49 »
What is the HHKB plugged into?  If its an iPad there isn't even enough power for the keyboard!  ;-P
Also, note that HHKB Integrated USB 2.0/1.1 Hub (Current supply limited to 100mA). Your thumb drive probably draws more than 100mA.
« Last Edit: Wed, 04 April 2012, 15:28:10 by captain »
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #2 on: Wed, 04 April 2012, 15:24:33 »
I had the same experience when I plugged a USB stick into mine.  :-(
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline captain
« Reply #3 on: Wed, 04 April 2012, 15:28:36 »
How much current do the Happy Hacking Keyboards draw?
Maximum: 100mA Actual: 30mA
How much current do the Happy Hacking Keyboards Lite2 support on the USB downstream port?
[Downstream of HHKB Lite2(USB)]supports 100mA.
« Last Edit: Wed, 04 April 2012, 15:38:26 by captain »
Offline trax
« Reply #4 on: Wed, 04 April 2012, 15:40:34 »
The stick states to be compatible with USB 1.1
Meh, just sending it back.
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline hcry4
  • HHKB Hoarder
« Reply #5 on: Wed, 04 April 2012, 16:08:27 »
Yea. It's just how it is. Most usb sticks probably won't work. Some mice don't work either because there isn't enough power. For example, deathadder is okay, but xai and sensei don't work.
Offline o2dazone
« Reply #6 on: Wed, 04 April 2012, 18:54:09 »
yeah, it's the amount of power the HHKB sends to those ports. It's enough to power my trackball, but devices that draw more power, or require "charging", the HHKB doesn't give it enough juice. Definitely lame.
Offline ironman31
« Reply #7 on: Wed, 04 April 2012, 20:10:17 »
Is there any way to mod this?
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline trax
« Reply #8 on: Thu, 05 April 2012, 12:32:35 »
Quote from: ironman31;567132
I've overclocked USB ports, but only the frequency.
I'm not sure if its even possible, according to captain the hub only provides 100mA.
Honestly its not HHKB to blame, wikipedia states "A device may draw a maximum of 5 unit loads (500 mA) from a port in USB 2.0"
Montereys
ACER
White Black
Futaba
Buckling Sprin
