Author Topic: logitech g9x  (Read 6758 times)
Offline Danny356
logitech g9x
« on: Fri, 06 April 2012, 23:06:14 »
Just bought this mouse, is anyone missing a teflon foot on the smaller grip? According to google the smaller grip isnt suppose to have a teflon foot, but i wanted to ask just to make sure
Offline net2522
  • lollollollol
logitech g9x
« Reply #1 on: Fri, 06 April 2012, 23:11:41 »
They doesn't have one on smaller grip.  so Don't worry.
Offline funxion
logitech g9x
« Reply #2 on: Sat, 07 April 2012, 00:09:42 »
Just curious - which grip do you like better? I like the hard plastic one in comparison to the rubbery one.
Crush80
Filco MJ2 TKL
Offline NYC
logitech g9x
« Reply #3 on: Sat, 07 April 2012, 00:11:19 »
without casing is good and the one with the matte finish is nice also
Camo Filco Cherry Blues tkl, White Filco Majestouch 2 Cherry Browns tkl
Offline Deverica Wolf
  • My name is Hack, Geek Hack.
    • Head-Fi
logitech g9x
« Reply #4 on: Sat, 07 April 2012, 02:24:51 »
Quote from: net2522;569529
Yep. I thought the same too but it doesn't.
Quote from: funxion;569566
For web browsing, I like the Wide Load grip. For shooting games, I prefer the Precision grip but both hit my palm too much so I switched to a CM Spawn. I keep the Wide Load on and use it for Chrome and RTSs....
UNICOMP.Spacesaver BS  |  FILCO Majestouch-2 TKL  |  FILCO Majestouch-2  [-_-]~ TKL  |  FILCO Majestouch-2 TKL
FILCO Majestouch-2 TKL  |  Deck Legend - ToXic  |  CHERRY Touchboard ITA
Offline aerial
logitech g9x
« Reply #5 on: Sat, 07 April 2012, 03:35:09 »
Silver grip wears oout pretty quickly from my experience, spot where you hold your thumb changes color to black.
No issues with smaller grip though, and yes, it has no mouse feet on it.
Offline Gawkbasher
logitech g9x
« Reply #6 on: Sat, 07 April 2012, 03:45:07 »
The smaller grip doesn't need a pad because the pads on the mouse itself are the only thing touching bottom.
There's one on one side of the larger grip just to give it a third contact point for that larger surface area.
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline TheProfosist
  • Custom Layouts Only!
logitech g9x
« Reply #7 on: Sat, 07 April 2012, 05:46:07 »
I added a pad to the smaller grip on mine when i put new ones on i think it helped.
Offline funxion
logitech g9x
« Reply #8 on: Sat, 07 April 2012, 10:35:09 »
Quote from: aerial;569673
Yeah, thumb spot wore out like crazy. FPS's -_-
Crush80
Filco MJ2 TKL
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
logitech g9x
« Reply #9 on: Thu, 19 April 2012, 22:13:11 »
Quote from: funxion;569809
Now worries, you can easily buy another NEW Silver Casing off Ebay.  I did.
Offline funxion
logitech g9x
« Reply #10 on: Thu, 19 April 2012, 22:40:30 »
Quote from: Elrick;579378
Is this it? Is it a rough surface or smooth? I prefer the rough plastic feel, it provides for good grip.
Crush80
Filco MJ2 TKL
Offline dmbr
logitech g9x
« Reply #11 on: Thu, 24 May 2012, 17:03:33 »
Try to find the custom extra big grip. Wonderfully comfy if you have big hands.
Offline dippingriz
logitech g9x
« Reply #12 on: Sat, 26 May 2012, 08:53:17 »
The rough one is the best if you scuff it up with some sandpaper.  For some reason I can't get a good enough grip on the g9x.  I might be going back to my trusty mx518.  Really hard to beat.
Offline NewbieOneKenobi
Re: logitech g9x
« Reply #13 on: Thu, 19 July 2012, 09:32:31 »
I have that mouse and the custom (still Logitech anyway) extra big grip. Nice stuff.
Offline peptobiscuit
Re: logitech g9x
« Reply #14 on: Mon, 23 July 2012, 09:19:30 »
I like the wide load grip (the big softie). Mine hasnt worn down after 3000+ hours of use. But if you have acidic sweat or don't wash your hands, i could see it happening.
I also have one of the custom graphic extra large grips, but it makes the mouse too heavy IMO.
Offline TheBackgammon
Re: logitech g9x
« Reply #15 on: Mon, 23 July 2012, 16:23:13 »
Skip the G9x altogether and use a Deathadder or classic 518!
Re: logitech g9x
« Reply #16 on: Tue, 24 July 2012, 10:48:10 »
Also, gripless is cool. Kinda like Kinzu on steroids, I guess.
