Author Topic: Dye PBT keycaps with Dharma pro dyes  (Read 3113 times)
Offline captain
« on: Sat, 07 April 2012, 14:40:15 »
Today was the big day. I put the darker keys in Kelly Green, the lighter keys in Chartreuse.  I'll post more as results come in.
« Last Edit: Sat, 07 April 2012, 14:43:37 by captain »
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline captain
« Reply #1 on: Sat, 07 April 2012, 16:43:25 »
After 3hrs soaking, time for heat.
Microwaving to ~190F
Offline captain
« Reply #2 on: Sat, 07 April 2012, 16:49:05 »
Offline captain
« Reply #3 on: Sat, 07 April 2012, 16:59:28 »
It is looking like an epic fail. :-(
Offline captain
« Reply #4 on: Sat, 07 April 2012, 17:08:20 »
My pants, on the other hand...  ;-P
Offline Input Nirvana
« Reply #5 on: Sun, 08 April 2012, 13:40:26 »
Those pants with the right hat and attitude....
Offline keyboardlover
« Reply #6 on: Sun, 08 April 2012, 17:50:01 »
...STILL belong in the 80s.
Offline Soheil
« Reply #7 on: Mon, 09 April 2012, 12:23:41 »
So what were the results?  Can you post pictures of the keys as fail as they may be?
Offline captain
« Reply #8 on: Thu, 26 April 2012, 07:00:08 »
I'll have to go hunt them up again. The only difference between brand new keys and these dyed ones is a slight green tint to a couple of stems. The keycaps didn't take any dye at all. I'm pretty sure this is because we used an acid dye, which is designed to work on wool and other natural fibers. Dharma makes many different types of dyes, and I believe they have one that is designed for synthetic fibers which is probably ideal for dying PBT keycaps.
Offline captain
« Reply #9 on: Thu, 26 April 2012, 07:05:05 »
Rinsing revealed nary a splotch, which is a good thing because now I have a second chance to try with the correct dye!
« Reply #10 on: Thu, 26 April 2012, 18:22:19 »
Why are you dying the bottom half of the two-piece keycaps?
Offline WhiteFireDragon
    • youtube
« Reply #11 on: Sat, 28 April 2012, 06:26:47 »
I'll post my results shortly. I've spent nearly $50 on dye alone, most from Dharma, and no results were good.
Offline keebler64
« Reply #12 on: Sat, 28 April 2012, 23:37:51 »
Quote from: WhiteFireDragon;584705
Your results sound like mine, minus the burning/melting. Tried Dharma and RIT on my NEC keys (I think they're PBT) for over an hour. RIT had the best results, except thr black turned my keys brown, then charcoal.
Good luck.
