Author Topic: New Keyboard; Loose switches  (Read 1143 times)
Offline Difesa
« on: Thu, 12 April 2012, 23:07:27 »
Hello all,
I recently bought a WASD V1 and I've noticed that some of the switches, especially the packspace, have a little play in the mounting.  Is this an RMA worth defect? or is this simple a side effect of plate mounting?  I can understand if this is normal, however if this is a product of wear, I think I may be experiencing it a bit early.
Thanks for the consideration!
Offline daerid
    • Rossipedia
« Reply #1 on: Thu, 12 April 2012, 23:19:22 »
Totally normal, you can just apply a little bit of Lithium grease to the stabilizers and it should go away.
