Author Topic: Laser mice and mousepads  (Read 14674 times)
Offline Silikone
« on: Sun, 15 April 2012, 15:42:02 »
I have a laser mouse (G500), and I have heard that cloth pads don't work well with the sensor, and that hard pads are the best choice. A friend of mine lent me what I suppose is a cloth pad from Steelseries, and I did not notice any problems. While I didn't get the chance to do some proper tests, I can personally say that most of the rumors are bollocks. Still, I would like to know if more sophisticated tests prove otherwise. If any of you have this mouse, I would like to know your experiences.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #1 on: Sun, 15 April 2012, 15:50:12 »
I have a Lachesis and have used it on a cloth pad without noticing anything.
Offline Autolyze
« Reply #2 on: Sun, 15 April 2012, 17:41:48 »
I've got a G500 at home and another at work and they both seem cool with cloth pads.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sun, 15 April 2012, 17:57:44 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 14:04:53 by davkol »
Offline Arc'xer
« Reply #4 on: Sun, 15 April 2012, 18:01:34 »
You need to ignore all those comments that you have read, in fact most should ignore it except for the PTE sensor and it's jitter effect which is merely an effect from the z-axis tracking in it's sensor. It's certainly not a bull**** rumor because it has been observed when properly tested. The most common reasons would be dust, remember laser sensors read at much more finer granularity than optical; this also explains why they perform worse with cloth because they are reading the individual fibers of the cloth pad and being "too accurate" as strange as it sounds. The more solid hard pad or certain cloth pads with a different weave would produce better results as the sensor has a harder time "catching" the more individualized portion.
But there is one primary reason as to why most will never, ever find problems and like you said "and I did not notice any problems". The reason is most people use a high sensitivity or if they don't know anything about their sensitivity use a sensitivity that is way too high i.e. crank up the DPI and sensitivity as high as possible. Most of the problems come from people who are low sensitivity, a few medium sensitivity users have observed issues but it's much less so compared to a low sensitivity. If your a low sensitivity user then you may observe problems occurring especially if you are particularly sensitive to these kinds of issues.
Offline vun
  • Just one more thing
« Reply #5 on: Mon, 16 April 2012, 03:05:14 »
My G9x works perfectly fine on cloth and I believe it has the same sensor as the G500.
Offline FoxWolf1
  • 154
« Reply #6 on: Mon, 16 April 2012, 03:29:13 »
My Zealot (also Avago 9500) has no problems on a cloth (and old, and dirty, and cheap) mouse pad-- but then, I use high sensitivity.
Offline Nighted
« Reply #7 on: Mon, 16 April 2012, 20:45:08 »
I use a Steel Series QcK Mini with both a Corsair M60 and my MS Wireless 5000. Absolutely no issues. I like it so much that I have bought 2 back ups. ;)
^ 100% teleprompter free.
[SIGPIC][/SIGPIC]
Offline 1391401
  • MX CLEAR
« Reply #8 on: Mon, 16 April 2012, 21:16:27 »
I've used the same type of cloth pads that I used with ball mice since forever
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline Rinx7
« Reply #9 on: Tue, 17 April 2012, 16:05:35 »
The Rocketfish is decent if you want a cheap hard mousepad, if you have a SS Sensei you gotta try the thing on a hard mouse mat, with those giant pads it has on it it is lifechanging.
Offline All The Fire
« Reply #10 on: Tue, 17 April 2012, 18:57:58 »
Quote from: Arc'xer;575597
I had a feeling something like this was going on, every time I click my RAT7 I get jitter in a very similar pattern to how it tracks when lifted. And also found it more prominent on the thick cloth pad, less on the thin hardmat and pretty much non existent on my wooden desktop.
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
« Reply #11 on: Mon, 23 April 2012, 05:48:30 »
I have a G500, too, and I changed from a SteelSeries 4HD to a Puretrak Talent (clothpad) about 5-6 months ago because a friend recommended it to me.
Although I wasnt really convinced of clothpads at that time, I don't regret that I gave it a try.
I must say, that I'm a mid-sense player, so the tracking issues going around the net havent appeared to me yet.
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
Offline Netdewt
  • OLKB
« Reply #12 on: Mon, 23 April 2012, 08:39:24 »
What's a mousepad?
Offline Daniel Beaver
« Reply #13 on: Mon, 23 April 2012, 09:29:29 »
Quote from: Netdewt;579651
What's a mousepad?
It's like a smartphone screen protector, but for Teflon feet.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
« Reply #14 on: Thu, 26 April 2012, 04:28:01 »
Anyone here using a G9x and a cloth pad (I am using a Cyborg Glyde7, whatever); try lifting the mouse very slowly while ever so slightly moving it around, I am getting tracking with slight jitter up to 3mm LOD, then nothing, but then again at 6mm LOD I get tracking with extreme jitter all the way up to 12/13mm LOD.
Now with a hard mat (I am using a Roccat Sota); I get pretty much the same up to a 3mm LOD, then nothing, then again at 6mm LOD I get tracking with a bit less jitter up until an 8mm LOD.
Thought it was interesting.
Offline Gawkbasher
« Reply #15 on: Thu, 26 April 2012, 05:39:30 »
I used IntelliMouse Explorer 3.0s with X-Trac Rippers.  When I upgraded to a G9x, it didn't perform very well, but my pads were old and sort of worn.
I use a Razer Scarab now and while I can't say for sure if it performs better, I have a strong preference for it.  No dirty/hazy pads to constantly wash or replace.
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
