Author Topic: Brand new (opened) Razer Nostromos $20 + postage  (Read 1243 times)
Offline Crake
  • Trade Count: (0)
« on: Sun, 15 April 2012, 18:27:31 »
Razer, bought new and used for a few hours. $20 plus postage.
I only used it a few hours. Every now and then the output from some of the keys (it was random - not from a particular key/s)  would loop-repeat until the subject key was pressed again.  Based on forums about it, the problem seems to be a generally issue with the product not my device per se. It had the newest firmware, per the firmware updater, so I did not continue with the firmware update.  Razer support said I should do the firmware update again and let it update even with that message but I had already uninstalled the software and did not mess with it anymore.
It would be a good mod project candidate or perhaps I was not patient enough to explore the problem and it is just a firmware fix.
