Author Topic: O-ring  (Read 1622 times)
Offline tehsprayer
O-ring
« on: Mon, 16 April 2012, 18:14:51 »
Where do i buy 40A o-ring for cheap online, WASD for $17 seems way overpriced and I see no group buys thanks!
I live in Canada too.
REΛLFORCE 87U - uniform 55g
Offline Vneck
O-ring
« Reply #1 on: Mon, 16 April 2012, 18:21:07 »
Check the classifieds, there are some being sold by a member here.
Offline tehsprayer
O-ring
« Reply #2 on: Mon, 16 April 2012, 18:22:32 »
Link me i cannot find !
Offline Vneck
O-ring
« Reply #3 on: Mon, 16 April 2012, 18:27:53 »
http://geekhack.org/showthread.php?27841-O-Rings-various-sotfness-and-thickness-GB-leftovers&highlight=O-ring
Currently the third result for O-ring... Your two threads pushed it down ;)
Offline TheProfosist
  • Custom Layouts Only!
O-ring
« Reply #4 on: Tue, 17 April 2012, 00:05:08 »
just so you know for the quality of o-rings you get from wasd its not all that over price especially for retail.
Offline sordna
O-ring
« Reply #5 on: Tue, 17 April 2012, 01:52:33 »
Indeed! You don't want o-rings that will dry up and harden in a few months, etc. The ones from WASD will last years! They will probably outlive your keyboard, so you would transfer them to the next board you get. I strongly recommend the WASD pink 40A o-rings.
