Author Topic: iPad 3 keyboard and case recommendations  (Read 1228 times)
Offline xquisit
« on: Wed, 25 April 2012, 01:14:02 »
I think my last thread got deleted, because it can't be found.
I need a case and keyboard recommendation for an iPad 3, and I would prefer to buy it from Amazon.
Thanks in advance.
I\'d rather die like a man than live like a coward - 2pac
Offline xquisit
« Reply #1 on: Fri, 27 April 2012, 03:43:54 »
looking for a bluetooth keyboard and case for my ipad 3
Offline mickd
« Reply #2 on: Fri, 27 April 2012, 08:23:18 »
As for a case, I would say the smart cover. It doesn't really PROTECT though, but damn does it look nice.
Offline errol
« Reply #3 on: Fri, 27 April 2012, 08:45:18 »
Not sure how much protection you need. My iPads primary function is a learning tool for my kids, and one of them is under 2, so I require a lot of protection!
This is what I use and I highly recommend it:
http://www.amazon.com/GRIFFIN-GB02480-Survivor-Extreme-Duty-Military/dp/B0055Q9NH0/ref=sr_1_14?ie=UTF8&qid=1335533808&sr=8-14
I haven't seen one for the iPad3 yet, but I'm sure it's in the works.
There's a lot of good reviews for GumDrop cases on youtube:
http://www.amazon.com/GumDrop-Cases-Drop-Series-Case/dp/B007IGRGII/ref=sr_1_5?ie=UTF8&qid=1335533808&sr=8-5
If you're looking for a more sleeker design, maybe some one with more experience can help. There are tons of options out there!
GL
Money is your army, every dollar is a soldier.
