Author Topic: Need help finding a microphone  (Read 5301 times)
Offline Son of Gnome
« on: Sat, 28 April 2012, 21:44:48 »
SO I just bought a pair of sennheiser 555 from a fellow member. Now I need to find a microphone to use with them. I am not sure if I want a clip on mic or a desk mic. I will be using it mostly for skype and video game playing, I also may stream with it as well.
Offline stereophonic
« Reply #1 on: Sat, 28 April 2012, 22:07:57 »
I would suggest the Logitech USB Microphone. It's not too expensive, but the quality is excellent for a desktop mic. You can just set it anywhere within a reasonable proximity to you on the desk and it will sound good. It's like 20 bucks on newegg
« Last Edit: Sun, 29 April 2012, 01:21:34 by stereophonic »
Offline Hente
  • huehuehue
« Reply #2 on: Sun, 29 April 2012, 00:34:12 »
I'd been planning on getting this thing for a while since its damn cheap and judging from that test clip, the sound quality isn't bad at all, especially at that $3 price: http://www.dealextreme.com/p/xty-operator-style-earbud-microphone-set-2631
Test sound clip: http://soundcloud.com/mictest1-2/xtymictest
Velcro dot for attachment to HD555: http://www.adorama.com/LQVP5.html?utm_term=Other&utm_medium=Shopping%20Site&utm_campaign=Other&utm_source=gbase&utm_term=Other&utm_medium=Affiliate&utm_campaign=Other&utm_source=cj_4166869
What I was planning on getting before discovering the XTY mic was the Labtec LVA-7330, there is currently a new one up for sale on ebay for $15 + shipping & a used one for $10 + shipping. There are also a couple up on ebay, including a .99 + shipping listing.
« Last Edit: Sun, 29 April 2012, 00:41:38 by Hente »
Offline Mysteric
  • Formerly 'Mackem'
« Reply #3 on: Sun, 29 April 2012, 11:05:05 »
The Antlion Modmic could be a good choice.
Offline tehsprayer
« Reply #4 on: Sun, 29 April 2012, 11:52:53 »
blue snowball is good.
REΛLFORCE 87U - uniform 55g
Offline big_bopper
« Reply #5 on: Sun, 29 April 2012, 12:45:34 »
If you go the clip on route, this Zalman is a nice option. It's under $10 and sounds great. I use it for everything and everyone always says I come through crystal clear.
CM Storm Quick Fire Rapid | Razer Black Widow Ultimate |White Keycool 87 MX Clear
Offline ricercar
  • mostly abides
« Reply #6 on: Sun, 29 April 2012, 17:21:05 »
Quote from: tehsprayer;585614
More kudos for the Snowball. Works well for voice (games, skype) as well as music.
I had the Zalman clip-on mic and didn't think much of it beyond being convenient. Music reproduction was atrocious.
Offline nar
« Reply #7 on: Sun, 29 April 2012, 21:10:30 »
Quote from: ricercar;585826
The zalman really isn't good if your trying to capture anything other than voice, but if it's just a voice it does a pretty good job, especially for it's price. You really need to use the mic boost for it though.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline big_bopper
« Reply #8 on: Sun, 29 April 2012, 21:25:27 »
I guess it depends on what you're using it for and how much you want to spend.
If you're going beyond the OP's original stated goals and have a little bit bigger budget, then I wouldn't recommend the the Zalman either.
Offline zeDoktor
    • http://www.hexomega.com
« Reply #9 on: Sun, 29 April 2012, 21:50:21 »
Well, to be fair, the Zalman mic never postures as a mic for instrument or music recording. I picked up a Zalman mic for my 555's and so far it seems to be doing well enough. The only unfortunate side effect is that the Zalman mic does not have a mute. I spent a little bit of time searching google and figured out an AutoHotKey script that works well enough for my purposes. The audio of myself that I've heard so far sounds at least as good as the Plantronics Audio 655 headset that I have while allowing me to listen through my 555's which are superior for music and significantly more comfortable. The Zalman mic lacks the boom-raise mute but mapping the AHK to Mouse4 works out well enough for me.
Saying that a $9 voice mic is poor at music reproduction is tantamount to saying that your DSL router would be bad at routing all the internet traffic between New York and Paris. I would even go so far as to say that the Zalman has superior directional capability and captures less of the other sounds in my room than the Plantronics headset. I can almost guarantee that this would be the case versus a desk-mounted microphone.
SteelSeries 6Gv2 / Razer DeathAdder Black  / CM Storm QuickFire Rapid / Logitech G5 BF2142 / Microsoft Sidewinder X4 / Rosewill RK-9000 White / Anker 8200
Offline Lanx
« Reply #10 on: Tue, 01 May 2012, 04:26:11 »
i got some olympus omnidirectional mic that came with a lapel clip and an extra long separate audio cord.
pretty sure it's this one
http://www.amazon.com/Olympus-ME-52W-Noise-Canceling-Microphone/dp/B000MYPPPE/ref=sr_1_1?ie=UTF8&qid=1335864300&sr=8-1
skype ppl say i sound the best, out of other ppl they've skyped with.
Offline Namkung
« Reply #11 on: Tue, 01 May 2012, 06:03:04 »
Quote from: stereophonic;585263
I second the logitech usb mic.
I find any sort of clip on to be annoying and this desktop mic actually does not pick up other noises causing background noise like many desktop mics are known to do
* Proud winner of the first GH SC2 tournament *
REALFORCE 87UB 55g
REALFORCE 87UW 45g
Offline feteru
« Reply #12 on: Tue, 01 May 2012, 19:58:15 »
Yeah, I have the Zalman, and if you are just trying to pick up voice for cheap, then it works fine. If you want to have a more serious mic, you could go for the Blue Snowball, and beyond that, people using the Shure SM57 that I have heard sound really good (casters and some studio musicians. The Snowball and the SM57 would require mounts and pop filters though, but yield the best results.
Offline dmbr
« Reply #13 on: Thu, 24 May 2012, 12:31:34 »
I second this. Owned one before upgrading to a Blue Yeti, and despite being ~1/5 the price, the quality when using Mumble or other team-speak options which apply substantial compression, the two sound about the same; the Yeti picks up more minute sounds, which is arguably a downside for casual use.
Pin-on mics are of inferior quality across the board.
