Author Topic: Model F vs. M  (Read 2620 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
Model F vs. M
« on: Sat, 28 April 2012, 23:56:28 »
Hey all,
I was wondering what is the different between an IBM model M and F? what is considered better and why? and lastly how much would one in new condition cost?
Cheers!
Offline bootstrap
    • epiguru.com - My Personal Website
Model F vs. M
« Reply #1 on: Sun, 29 April 2012, 00:22:38 »
They feel different. The keys on the Model F feel lighter and crisper (my experience: Model F PC/AT (x 3) vs a Model M 1391401 and a Model M "Mini" SSK). The layouts of the F and M are also different - most people prefer that of the Model M. The choice between the Model F and Model M is a personal one - I like my Model F PC/AT. :smile:
You will be lucky to find a NIB Model F PC/AT. From recollection, the last one I saw sold for about $800+ on eBay.
There are 2 NIB XTs on eBay:
http://goo.gl/zam85
http://goo.gl/5AxXM
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
Offline Mugen
Model F vs. M
« Reply #2 on: Sun, 29 April 2012, 01:01:29 »
Thanks for the explanation! what are XTs? >_<
Model F vs. M
« Reply #3 on: Sun, 29 April 2012, 08:40:06 »
I am no expert, but I have owned, used, and dis-assembled several of each of these varieties.
The 83-key XT keyboard has an odd and uncomfortable layout, and is not compatible with modern motherboards unless you use Soarer's converter or something like a Hagstrom unit. Many people believe that it has the best feel of all the buckling spring keyboards. It is very heavy and has a metal back for the case.
The 84-key AT keyboard has a more conventional layout, and will work on a modern computer (if you buy the proper adapter plugs). The entire shell is plastic, and the front edge, at the spacebar, especially, is very hard to pry apart without damage.
The battleship Model F 122-key terminal keyboard is huge and heavy, and also requires Soarer's Teensy. It weighs a ton and has the black metal back.
All these can be taken apart and the barrels and springs moved around to approximate ANSI or ISO layouts, if you prefer (although there is not much to do with the XT in its original case). This is not easy to do because there are multiple curved plates, plus a multitude of individual barrels and springs, that must be held together tightly and slid sideways in a force fit. It is not as bad on the small ones, but the big one is a nightmare, hence my bolt-mod wiki.
All of these topics are discussed at length in several wikis here, although they can be difficult to find.
http://en.wikipedia.org/wiki/IBM_PC_keyboard
http://en.wikipedia.org/wiki/IBM_Model_M
« Last Edit: Sun, 29 April 2012, 08:46:55 by fohat.digs »
- Plato
