Author Topic: KMAC DIY Thread  (Read 79444 times)
Offline SmallFry
Re: KMAC DIY Thread
« Reply #150 on: Mon, 05 November 2012, 15:40:01 »
What about the KPAD? I would assume that it is the top button? Granted, there is few enough buttons that it wouldn't take long to figure out by guess and check.
Offline TheProfosist
  • Custom Layouts Only!
Re: KMAC DIY Thread
« Reply #151 on: Mon, 05 November 2012, 16:22:38 »
thanks a bunch with the DFU mode was able to program my KMAC!
Offline jcrouse
Re: KMAC DIY Thread
« Reply #152 on: Mon, 05 November 2012, 18:56:52 »
Dude, I only just figured this out last night!
How in the he77 would you ever "figure" that out?
John
Offline alaricljs
  • I be WOT'ing all day...
Re: KMAC DIY Thread
« Reply #153 on: Mon, 05 November 2012, 20:01:34 »
Multiple pieces of info from different sources all put together.  It's a puzzle... blech.
Filco w/ Imsto thick PBT
Offline SmallFry
Re: KMAC DIY Thread
« Reply #154 on: Mon, 05 November 2012, 20:05:19 »
He77? I thought it was H-E-Doublehockeysticks!
Offline ZcHuer
Re: KMAC DIY Thread
« Reply #155 on: Mon, 05 November 2012, 22:55:10 »
Maybe many of you already known this, but some still may not. As it took me about 2 hours to figure out, I think I should write this down for whom have KMAC winkeyless with LEDs installed to TURN THE LEDS ON/OFF.
So here we go:
1. Download the New KMAC Keymap tools as provided in litster's OP.
2. Download Flip application via URL provided in the How to upload to KMAC.docx (Thanks to feng ^^), and install it.
3. Follow the How to upload to KMAC.docx to generate you own HEX file and upload to you KMAC winkeyless. Some IMPORTANT points to be aware of here:
     - Extract the New KMAC Keymap tools to a directory without any space in the name, e.g. C:\KMAC, otherwise, it can't generate a HEX file correctly.
     - When starting the KAMCS.exe, you are first required to use your KBDMania account to login. (The login window is in Korean...)
     - Assign one of the keys except the Esc as Fn, in my case it's my right alt. please also keep in mind that once the key is assigned as Fn, the original function of that key will never work again.
4. Once the new key map file (a .HEX file) successfully uploaded to your KMAC winkeyless, you can use your new Fn key + Esc to turn on/off the LEDs installed on your board, and you will surprisingly find that LEDs in different areas, i.e. ASDW LEDs is viewed in one area,  can be controlled separately.  Congratulations ;D
Please let me know if you have any questions  regarding to the above, I would be happy to be helpful. ^^
« Last Edit: Mon, 05 November 2012, 23:36:35 by ZcHuer »
Re: KMAC DIY Thread
« Reply #156 on: Mon, 05 November 2012, 23:24:03 »
Thanks for the help ZcHuer took SmallFry and I a while to figure all this out before you posted this.
Offline ZcHuer
Re: KMAC DIY Thread
« Reply #157 on: Mon, 05 November 2012, 23:45:08 »
Haha~~I was working on this till 1am last night. ;p
Re: KMAC DIY Thread
« Reply #158 on: Tue, 06 November 2012, 02:39:55 »
Well glad that you got it figured out I forgot how long it took SmallFry and I but is was over a weekend.
« Last Edit: Tue, 06 November 2012, 15:16:31 by TheProfosist »
Offline SmallFry
Re: KMAC DIY Thread
« Reply #159 on: Tue, 06 November 2012, 07:45:53 »
Yeah, twas a pain in the arse.
Re: KMAC DIY Thread
« Reply #160 on: Tue, 06 November 2012, 15:16:50 »
Sorries
Offline SmallFry
Re: Re: KMAC DIY Thread
« Reply #161 on: Tue, 06 November 2012, 16:23:26 »
Offline SmallFry
Re: KMAC DIY Thread
« Reply #162 on: Wed, 07 November 2012, 07:33:09 »
I found last night that the FN key is the DFU key on the KPAD. I'll have to upload the KMAC manual that I translated, it lost all the formatting but is completely usable and quite helpful if used side by side with the Korean manual. *makes mental note to upload English KMAC Manual*
Offline ZcHuer
Re: KMAC DIY Thread
« Reply #163 on: Wed, 07 November 2012, 08:11:21 »
That should be realy great ;D
Offline SmallFry
Re: KMAC DIY Thread
« Reply #164 on: Wed, 07 November 2012, 08:23:12 »
It is just Google Translated, however, it gets the point across well enough. You just need to use them side by side.
Offline WhiteFireDragon
    • youtube
Re: KMAC DIY Thread
« Reply #165 on: Wed, 07 November 2012, 18:18:59 »
For you guys that already built this, are there resistors in the matrix for the LEDs, or the fact that they're in series provide the correct resistance for the circuit?
Offline SmallFry
Re: KMAC DIY Thread
« Reply #166 on: Wed, 07 November 2012, 18:47:38 »
Here is the translated manual that I did in Google Translate...not the best, but helpful if used side by side with the KBDMania manual. It most importantly to me told me the DFU keys for the KMAC's is the Caps Lock key and for the KPAD, it is the Fn key. Also included is the syntax for macros on the KMAC's which is pretty handy.
Here...be kind to my Dropbox.
I'll upload it to a better place later unless somebody will do it for me, not quite sure how the attachments in front are hosted.
« Last Edit: Wed, 07 November 2012, 18:49:31 by SmallFry »
Offline emptythecache
  • out.
Re: KMAC DIY Thread
« Reply #167 on: Fri, 09 November 2012, 18:30:28 »
****, I don't have a kbdmania account. Is that the one that you need a korean phone number for, or am i thinking of otd?
Offline alaricljs
Re: KMAC DIY Thread
« Reply #168 on: Fri, 09 November 2012, 18:42:46 »
no ph # needed, but there is a spot for one
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: KMAC DIY Thread
« Reply #169 on: Wed, 14 November 2012, 23:21:39 »
New KMAC Keymap Program: http://go9.co/fqx
New KMAC Korean Manual: http://go9.co/fqs
New KMAC video: Not a valid vimeo URL
Offline SmallFry
Re: KMAC DIY Thread
« Reply #170 on: Wed, 14 November 2012, 23:33:01 »
What's new in it? Just support for the new KMACs? (Haven't looked at the files yet)
Re: KMAC DIY Thread
« Reply #171 on: Thu, 15 November 2012, 00:07:19 »
yea want to know as well and can i import my xml files into to edit?
Re: KMAC DIY Thread
« Reply #172 on: Thu, 15 November 2012, 19:23:28 »
Is there a password?
Hmmm, why does it log you in to to kbdmania?  Has anyone checked if this application is doing nefarious stuff?
« Last Edit: Thu, 15 November 2012, 19:28:19 by metalliqaz »
Offline SmallFry
Re: KMAC DIY Thread
« Reply #173 on: Thu, 15 November 2012, 19:30:15 »
The program requires you to have KBDMania account to log into the program. I haven't had any problems over here making the HEX files etc. Profosist, how is your layout working?
Re: KMAC DIY Thread
« Reply #174 on: Thu, 15 November 2012, 23:41:56 »
great now that i fixed a few things after testing my account is working fine as well.
Offline whiskerBox
Re: KMAC DIY Thread
« Reply #175 on: Sat, 17 November 2012, 21:20:25 »
Awesome now I can turn off the freaking led's at work... Nice Job
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline SmallFry
Re: KMAC DIY Thread
« Reply #176 on: Sat, 17 November 2012, 21:33:21 »
You could always do that. Though, glad you found it. You can also change the brightness.
« Last Edit: Sat, 17 November 2012, 21:35:16 by SmallFry »
« Reply #177 on: Sun, 18 November 2012, 02:56:01 »
brigness control doesnt seem to work on my board, or maybe my leds are just too bright in the first place...
    • youtube
Re: KMAC DIY Thread
« Reply #178 on: Sun, 18 November 2012, 05:34:59 »
Which LEDs did you pick, and do you have the specs for them? I just ordered some white, red, and purple, not sure how it's going to turn out.
Re: KMAC DIY Thread
« Reply #179 on: Sun, 18 November 2012, 13:21:20 »
I order 14000mcd green kingbright's http://tinyurl.com/bbdpham
Re: KMAC DIY Thread
« Reply #180 on: Fri, 30 November 2012, 00:28:42 »
I picked up a KPAD and was wondering what its all capable of doing since i already have a numpad on my KMAC and want to put it on the left side of my keyboard. Also dones it have different led modes or just on/off? Also the links for the new software seem to be dead i cant get to them...
Re: KMAC DIY Thread
« Reply #181 on: Sat, 01 December 2012, 05:21:56 »
The links for the new software are dead could anyone that already downloaded them please send them to me?
Re: KMAC DIY Thread
« Reply #182 on: Sat, 01 December 2012, 07:17:42 »
YGPM
Re: KMAC DIY Thread
« Reply #183 on: Sat, 01 December 2012, 07:22:48 »
YGPM
Thanks a bunch was much harder to program anything but the KMAC with the old version
Re: KMAC DIY Thread
« Reply #184 on: Tue, 04 December 2012, 02:39:05 »
anyone know why the KMAC software is limited to 12 macros?
Offline alaricljs
Re: KMAC DIY Thread
« Reply #185 on: Tue, 04 December 2012, 08:29:47 »
That's the way they wrote it.
« Reply #186 on: Tue, 04 December 2012, 08:35:46 »
:( I cant macro all the keys on my KPAD
Offline guilleguillaume
Re: KMAC DIY Thread
« Reply #187 on: Sun, 16 December 2012, 15:02:55 »
Thanks for this thread and all the contributions.
I've been able to program my Kmini after playing around with the manual and software. I'm really happy!
Offline sherryton
  • Kībōdo
    • Originative
Re: KMAC DIY Thread
« Reply #188 on: Sun, 16 December 2012, 17:41:33 »
How do you like it?
Re: KMAC DIY Thread
« Reply #189 on: Sun, 16 December 2012, 20:16:07 »
How do you like it?
I really enjoy it. Those MX Brown switches feel smooth as butter.
Also being able to program the layout you need is just fantastic.
Re: KMAC DIY Thread
« Reply #190 on: Sun, 16 December 2012, 20:31:26 »
How do you like it?
agreed i just wish they had a few more things in the software
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: KMAC DIY Thread
« Reply #191 on: Sun, 16 December 2012, 20:39:12 »
Bahh, I want to build something quite badly, either one of these, a phantom or a gh60.  Wish I had paid for a protoboard...
Offline sherryton
  • Kībōdo
    • Originative
Re: KMAC DIY Thread
« Reply #192 on: Sun, 16 December 2012, 23:23:08 »
How do you like it?
the switches are brown with 55g's.  The problem is that I did not have any lube at the time.  It would feel even better with lube.  I recommend you adding it when you have time!
Offline litster
Re: KMAC DIY Thread
« Reply #193 on: Sun, 31 March 2013, 21:10:03 »
Latest KMAC keymap software.  This standalone version doesn't require any login.  I was going to attach it here but the zip file is too large for GH.  So go to the link directly.
http://go9.co/iLJ
Offline Taeyoung
  • Taeyoung / 낭만곰팅
Re: KMAC DIY Thread
« Reply #194 on: Sun, 31 March 2013, 21:18:17 »
http://go9.co/iLJ
I've also uploaded the keymap software to my dropbox.
That might be a little bit faster than the direct link. :)
https://dl.dropbox.com/u/2386102/keyboard/kmac/standalone_20130217.zip
Offline HolidaySHRIMP
Re: KMAC DIY Thread
« Reply #195 on: Thu, 11 July 2013, 10:08:53 »
Oh god finally found this thread.  Got my KMAC reprogrammed finally!  That PDF was money even though I couldn't read it.  It had pictures and English for the buttons you press.
Caps->Control
LControl -> Windows
Scroll Lock -> LED toggle.
Woo hoo!
Offline Taeyoung
  • Taeyoung / 낭만곰팅
Re: KMAC DIY Thread
« Reply #196 on: Wed, 07 August 2013, 19:54:52 »
http://go9.co/iLJ
I think the following video will be helpful to understand how to change KMAC keymap and apply the modified keymap file to KMAC.
- Not a valid vimeo URL- KMAC manual : http://go9.co/fqs
I'm afraid the manual is Korean version other than English one but i think the pics in the manual will also give you some tips.
« Last Edit: Wed, 07 August 2013, 21:12:35 by Taeyoung »
Offline Jokrik
Re: KMAC DIY Thread
« Reply #197 on: Mon, 11 November 2013, 16:25:32 »
Have someone tried this on windows 8.1? or even windows 8?
I cant get the flip running , I can click on it but nothing happened
thus I cant make any changes
Re: KMAC DIY Thread
« Reply #198 on: Mon, 11 November 2013, 17:15:38 »
Does Flip start up and not connect to the KMAC or does Flip just not run at all?
Offline Jokrik
Re: KMAC DIY Thread
« Reply #199 on: Mon, 11 November 2013, 18:11:07 »
It does not run at all, i made some changes on the key and as ive seen in the video ive to run flip in the end
But when I press the flip button, nothing happened (no flip window appear)
