Author Topic: Poker DIY kit - EXCLUSIVELY AVAILABLE AT GEEKHACK ! ! !  (Read 105789 times)
Offline Djuzuh
« Reply #200 on: Fri, 25 May 2012, 08:28:38 »
Yes they are pcb mounted and plate mounted.
Mouser probably carries the pcb mounted switch only, which is a bit cheaper.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #201 on: Fri, 25 May 2012, 08:33:25 »
the switches listed are probably pcb mount switches, as the poker PCB has the pcb-mount fixation holes. however, the plate can be used with the pcb mount switches.
last someone checked, mouser had pretty limited stock, in that they have fewer switch varieties and they have very few on hand.
green are blues with stiffer springs. light grey are clears with stiffer springs iirc. check the MX switch wiki
Offline mosrael
« Reply #202 on: Fri, 25 May 2012, 11:13:57 »
I apologize if this has already been answered elsewhere in the thread and I overlooked it, but did we ever get a solid answer on whether the plate kits were up for sale by themselves?
Offline metafour
« Reply #203 on: Fri, 25 May 2012, 11:26:52 »
Quote from: mosrael;599927
The first post seems to indicate the plate is available for $11.
Don't remember if anyone mentioned if the plate can be added to existing Pokers though.
Offline mosrael
« Reply #204 on: Fri, 25 May 2012, 11:42:44 »
Oh yeah, well, I expect it's just a matter of desoldering the switches, mounting them, and resoldering the whole board, which is no big deal. As long as I can buy one without the rest of the kit!
Offline metafour
« Reply #205 on: Fri, 25 May 2012, 11:45:28 »
That's my question though, do you need to desolder all the switches or can you just pop the plate on?
Offline mkawa
« Reply #206 on: Fri, 25 May 2012, 11:45:35 »
actually, you don't need to desolder the switches to plate an existing unplated poker. you will need to desolder the LEDs, but that's it.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #207 on: Fri, 25 May 2012, 11:47:25 »
Well, take off the switch tops too and try not to lose any parts  ;)
Filco w/ Imsto thick PBT
Offline mosrael
« Reply #208 on: Fri, 25 May 2012, 11:56:04 »
I was gonna experiment with taking off the switch tops and mounting the plate that way, rather than desoldering. Good to hear that'll work.
Offline tadbitnerdy
« Reply #209 on: Fri, 25 May 2012, 12:15:42 »
So can these two things be confirmed?  I really want to make sure before I buy a plate (just like everybody else)
1.  Can I buy a plate buy itself?
2.  Can the plate be mounted to an pre-built Poker without desoldering the switches/LEDs?
Thanks,
-Tad
Offline alaricljs
« Reply #210 on: Fri, 25 May 2012, 12:26:49 »
The answer to #2 is directly above your post.  The answer to #1 ultimately comes from iMav, but as it's a separately listed item with it's own price I'm inclined to expect that you can order it alone.  iMav's order to them is hardly going to contain info on who ordered what, just a list of parts and quantity, then he gets to sort it out on his end and send it to you.
Offline iMav
  • geekhack creator/founder
« Reply #211 on: Fri, 25 May 2012, 12:29:37 »
Seperately listed items can be ordered seperately.
Offline tadbitnerdy
« Reply #212 on: Fri, 25 May 2012, 16:22:01 »
PM and payment sent.  Yay!
Offline Loligagger
« Reply #213 on: Fri, 25 May 2012, 19:37:32 »
You can use the stock poker stabilizers with the plate mount right? Even if you took the top off, how would you push the plate mount past the four lips on the corners of each switch?
Offline tadbitnerdy
« Reply #214 on: Fri, 25 May 2012, 19:41:48 »
From what I've seen, all you need to do is desolder the 7 LEDs.  Then remove the tops of all the switches, place the plate, reattach the tops of the switches, and solder the LEDs back on.  I'm assuming the stabilizers will work because this is a plate made for the Poker.  Hopefully my assumption is correct.
-Tad
Offline __red__
« Reply #215 on: Sat, 26 May 2012, 14:24:00 »
Newbie question.  Why the obsession with plate mounting?
Offline Djuzuh
« Reply #216 on: Sat, 26 May 2012, 14:26:36 »
easier to clean, looks less messy, people like myself who haven't a lot of electronic experience are afraid to break a pcb plate.
Offline mkawa
« Reply #217 on: Sat, 26 May 2012, 20:12:35 »
pcb flex is the ban of the poker's existence
Offline __red__
« Reply #218 on: Sat, 26 May 2012, 20:33:17 »
So I assume that if you have a plate you also have a pcb?  ie, you don't do wire-wrap or point to point circuitry?
Offline Djuzuh
« Reply #219 on: Sat, 26 May 2012, 20:35:22 »
yes.
the plate goes in the middle of the switch, but the switch is still soldered to the PCB.
Offline __red__
« Reply #220 on: Sat, 26 May 2012, 20:41:55 »
Time to see if I can find a service who will cut square holes in metal plate :-)
Offline Djuzuh
« Reply #221 on: Sat, 26 May 2012, 20:44:37 »
Don't forget to write a wiki article once you've find a service and tested it out please :P
« Last Edit: Sat, 26 May 2012, 20:47:36 by Djuzuh »
Offline jcrouse
« Reply #222 on: Mon, 28 May 2012, 20:30:02 »
@iMav ... How do we add extra items, another stabalizer set or mounting plate (or switches), to an existing order?
Thanks,
John
Offline Icarium
  • I AM A MONKEY!
« Reply #223 on: Wed, 30 May 2012, 07:34:58 »
I'd rather not count so can anybody tell me how many switches I should order for the entire board? :)
EDIT: Found the answer in some other post: 61 switches
EDIT:
Earlier in the thread somebody complained about this being as expensive as a fully assembled Poker but those don't come with aluminium casings, do they?
>> Was answered in this way somewhere else as well.
« Last Edit: Wed, 30 May 2012, 08:52:39 by Icarium »
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
« Reply #224 on: Wed, 30 May 2012, 10:14:47 »
This is a lot more expensive than a normal fully assembled poker, but as far as I know it's the only place you can get official aluminium cases for them.
So it's worth it if you like DIY and want an aluminium case for your poker.
« Reply #225 on: Wed, 30 May 2012, 10:21:09 »
Quote from: dorkvader;603875
Is the "official" aluminum case for the Pure not the same as this?
Offline iMav
« Reply #226 on: Wed, 30 May 2012, 11:02:16 »
FYI, this group buy ends at the end of the month (as per VorTex's request).  I have absolutely no idea if we will ever offer this again.
Offline mkawa
« Reply #227 on: Wed, 30 May 2012, 12:03:20 »
this is your chance to get pokers, people. switches are plentiful right now so order up!
Offline yearn4
  • formerly known as 4en
« Reply #228 on: Wed, 30 May 2012, 14:22:23 »
are there any soldering experts that are willing to offer their services?
Offline jcrouse
« Reply #229 on: Wed, 30 May 2012, 14:23:17 »
Quote from: 4en;604057
Read the thread. There are many options.
Offline Loligagger
« Reply #230 on: Wed, 30 May 2012, 18:28:07 »
If anyone doesn't want the second PCB I'll buy it from them.
Offline mkawa
« Reply #231 on: Wed, 30 May 2012, 18:47:34 »
have switches, want pcb, will solder (!!)
Offline yearn4
« Reply #232 on: Wed, 30 May 2012, 19:14:15 »
hey imav so your paypal address is LITERALLY "me@imav.org"?
Offline alaricljs
« Reply #233 on: Wed, 30 May 2012, 19:16:28 »
Why not?  Mine is me@  ok... one of mine.
Offline yearn4
« Reply #234 on: Wed, 30 May 2012, 19:50:15 »
ahh where's mkawa :(
Offline alaricljs
« Reply #235 on: Wed, 30 May 2012, 19:50:52 »
Round abouts the west coast
Offline mkawa
« Reply #236 on: Wed, 30 May 2012, 19:57:25 »
i'm socal. always happy to solder things up for people, but promptness isn't my greatest strength at the moment. might be best for me to offer a soldering service within an uncertain timeframe for free in exchange for a pcb :)
Offline postlapsaetia
« Reply #237 on: Thu, 31 May 2012, 00:09:54 »
Paid & pm'd
Offline rhune
« Reply #238 on: Thu, 31 May 2012, 14:18:23 »
Put in an order for the plate :thumb:
Offline jblack801
« Reply #239 on: Thu, 31 May 2012, 16:19:49 »
stoked for a plate, not stoked to desolder my current poker.
Offline whiskerBox
« Reply #240 on: Thu, 31 May 2012, 16:25:10 »
Quote from: jblack801;604904
+1 :rofl:
It wont be that bad, at least its not a 104.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline jblack801
« Reply #241 on: Thu, 31 May 2012, 16:51:47 »
Quote from: whiskerBox;604908
+1 :rofl:
I'm not too worried, I'll just need to get a solder wick or something. Very true 104 wouldn't be as entertaining, it'll get me ready for the ErgoDox keyboard though.
Offline metafour
« Reply #242 on: Thu, 31 May 2012, 16:53:03 »
I thought it was already stated that you only need to desolder the leds to put the plate on?
Offline WRXChris
« Reply #243 on: Thu, 31 May 2012, 17:09:18 »
I'm going to be throwing in a last minute order for at least a plate and set of stabilizers, but I'm so tempted to buy a kit!!!  Just not sure I can justify it with 2 pokers already and intent to buy a pure... I guess this is what they call first-world problems, lol.
Offline jblack801
« Reply #244 on: Thu, 31 May 2012, 18:04:13 »
Quote from: metafour;604952
It appears to have been clarified. Thanks for pointing out my failure to read previous posts. :sorry:
Offline Loligagger
« Reply #245 on: Thu, 31 May 2012, 18:06:35 »
These bits in red get in the way if you just take the top of the switch off (the plate needs to go under them in other words). Unless there's some way I'm missing to push the plate under these they'll need to be desoldered.
[ Attachment Invalid Or Does Not Exist ] 51945[/ATTACH]
Offline WRXChris
« Reply #246 on: Thu, 31 May 2012, 18:30:46 »
Quote from: Loligagger;605049
(Attachment Link) 51945[/ATTACH]
You're right, they will all have to be desoldered.  I just finished modding a filco to ergo clears, and can confirm that the plate must be in between the pcb and switches, and there is no way to squeeze the plate over the switches after they are soldered to the pcb.
The red highlights in Loligagger's picture rest on top of the plate.  They are on the bottom section of the switch, so taking the top of the switch off will not get them out of the way and hence you can't slip the plate past them.
This make me lean towards wanting to buy a kit now... desoldering sucks with cheap equipment.
Offline metafour
« Reply #247 on: Thu, 31 May 2012, 20:30:12 »
Quote from: metafour;599965
Quote from: mkawa;599966
Quote from: alaricljs;599967
Bought two plates today. FML =\
Offline tadbitnerdy
« Reply #248 on: Thu, 31 May 2012, 20:37:28 »
Oh well, guess I'll use this to hone my skills.
Offline alaricljs
« Reply #249 on: Thu, 31 May 2012, 23:00:13 »
Apologies on that one, I shall do penance by going to bed early so I can get that much needed sleep for my brain to function  ;)
