Author Topic: More tactile than browns, but non-clicky?  (Read 5104 times)
Offline Saturn
« on: Mon, 30 April 2012, 14:27:49 »
Simple question:
If I were looking for a switch that is more tacile than cherry browns, but non-clicky, what would you recommend?
Offline Reptile
« Reply #1 on: Mon, 30 April 2012, 14:28:48 »
Clears or ergo clears
sent from my mobile
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #2 on: Mon, 30 April 2012, 14:29:26 »
Try clears(55g) or Ergo clears(50g), which uses a clear switch with the springs from a red, blue, or brown switch.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline shawn o
« Reply #3 on: Mon, 30 April 2012, 14:31:26 »
Clears! I'm in the middle of converting a Filco right now!
Can't decide if I should use clear or grey for spacebar though?
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #4 on: Mon, 30 April 2012, 14:32:30 »
Man that looks time consuming!  Hope you have a good soldersucker
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #5 on: Mon, 30 April 2012, 14:46:10 »
I put some gray springs on blue switches and its really awesome if you Like the heavy switches :D
Sent from my PC36100 using Tapatalk 2
-Enzo Ferrari
Offline shawn o
« Reply #6 on: Mon, 30 April 2012, 14:47:16 »
Hakko 808. Still takes a while though. Kind of relaxing actually, in a weird sort of way. Working on it in my spare time, when I get any that is!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Mon, 30 April 2012, 14:49:21 »
Quote from: shawn o;586538
I did a panda/grey for spacebar (black spring, clear stem). Much better than a straight ergo clear for me on that key.
Offline Saturn
« Reply #8 on: Mon, 30 April 2012, 15:23:33 »
Thanks for the helpful responses.  Where's a good place to get a kb with clears or ergo clears?  I think EK had Leopold clears for a little while but I don't see them listed anymore.
Offline 1839cc
« Reply #9 on: Mon, 30 April 2012, 15:31:41 »
Saturn, you would have to make ergo clears yourself. Regular clears on non POS boards are hard to find. You might want to grab a POS anyway, if it's cheap enough, just to try them. It should be noted that they are hard to find because they are not popular. Most people don't like them.
Shawn o, I like the gray switch under the spacebar, escape, and sometimes enter, but it's fine either way for me.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline smknjoe
« Reply #10 on: Wed, 02 May 2012, 20:52:17 »
I thought the standard clears had the same springs as blacks. Is that not the case?
« Last Edit: Wed, 02 May 2012, 20:54:41 by smknjoe »
SSKs for everyone!
Offline Forsaken
« Reply #11 on: Wed, 02 May 2012, 20:57:25 »
Quote from: i3oilermaker;586540
The best soldersuckers are the ones built into an iron, like this http://www.mpja.com/40-Watt-Desoldering-Iron/productinfo/16922+TL/
Works like a dream. You just put it on top of the solder joint so that the component lead actually enters the hole in the iron tip, push the button, and BAM, ALL the solder comes up, leaving the component completely freed.
« Last Edit: Wed, 02 May 2012, 21:00:40 by Forsaken »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #12 on: Wed, 02 May 2012, 21:02:00 »
Quote from: smknjoe;588646
The clear springs are a tiny bit stiffer feeling to me than black springs. You can dig through the following to see tests people did on them:
http://geekhack.org/showwiki.php?title=Island:17248&do=comments&page=9
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #13 on: Wed, 02 May 2012, 21:04:07 »
clear springs are almost certainly stiffer than black springs
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Wed, 02 May 2012, 21:15:20 »
Yeah, it's softest to toughest = red/brown/blue, black, green, clear, grey. Then there is some obscure switch also but no real need to go there as it is unlikely you will encounter them unless you go looking.
