Author Topic: I think I broke a switch on my keyboard, advice please?  (Read 6552 times)
Offline Chocobo
« on: Sun, 06 May 2012, 23:29:20 »
Recently I spilled a few drops of liquid onto my keyboard and got a couple of sticky keys. I wanted to pop open the top of the Cherry MX Blue switch and look inside, and possibly apply some isopropyl alcohol directly to try to clean it. I found this Youtube video showing how to do it:
video link
I then attempted to do this on my CM Storm Quickfire Rapid... and instead of the top opening, the entire switch was dislodged from the PCB and the whole thing came out. It even pulled some of the soldering along with it.
I'm about 90% sure that this switch is simply broken now, can someone please confirm that? I believe that these switches should have two metal prongs (if that's the right term) sticking out of the bottom, which need to be soldered to the PCB. It appears that one of the prongs ripped out of the Cherry switch and remained stuck to the soldering. Do I have this correct?
So assuming I have a broken switch... if I want to replace it, I'll have to remove that broken prong, get a new switch, put it into the PCB and solder it, right?
Luckily this is just the FN key, which I honestly don't know if I would ever use. In fact it's already caused me some trouble when I've accidentally hit it (this is my first time on a keyboard with a FN key) so I don't think I mind if it's broken. Is there any reason why I shouldn't clip the prongs, insert the dead switch back into the board and stick the FN keycap on it, and just have a non-functioning key? Or would there be some problem I'm unaware of?
I'm somewhat new to mechanical keyboards and was hoping not to have to learn so much so quickly, but being stupid enough to spill a drink near my new keyboard has at least led to an educational experience. Any info would be appreciated, especially if I've got something wrong and could potentially damage something further. Thanks.
Offline 1839cc
« Reply #1 on: Sun, 06 May 2012, 23:32:09 »
Quote from: Chocobo;589950
Correct.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline Tranquilite
« Reply #2 on: Sun, 13 May 2012, 04:20:08 »
You tried to pop the top off a plate mounted switch... bad move man. Plate mounted switches need to be desoldered first before you can open them. You're lucky the pin that came out with solder on it didn't rip the entire trace out along with it.
Offline N8N
« Reply #3 on: Sun, 13 May 2012, 11:43:47 »
http://www.wasdkeyboards.com/index.php/products/keyboard-parts-1.html
You'll need to clean the busted prong out of the hole with a soldering iron and a solder sucker or solder wick, then solder the new switch in.  The slider and spring is still probably good in your old switch, if you want to toss it in your junk box.
good luck!
