Author Topic: Name it. We'll do our best to get it. (v2.0)  (Read 886875 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Name it. We'll do our best to get it. (v2.0)
« Reply #1200 on: Mon, 03 August 2015, 10:06:49 »
Do you think you guys will ever stock some non low profile aluminum 60% cases?
As in high profile? Are you able to provide a picture as an example? I can say that it is not an impossibility, just something we have either overlooked or just not considered.
Basically cases were you can't see the switch housing.
Do you know of any aluminum cases with this higher profile?
This is what I'm talking about.
Here is a example of a low profile TEX case next to a normal height MKC case.  See how the MKC case hides the switch housings?
TEX 60% vs MKC 60% by Compact Keyboards, on Flickr
More non low profile case examples. These particular cases were from group buys.
Hammer & Duck Poker Pitch Comparision by Compact Keyboards, on Flickr
This is one that was sold on Massdrop.
Thanks for the pics, we will see what we can do to acquire something similar, or perhaps the very thing...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #1201 on: Mon, 03 August 2015, 10:34:58 »
Do you guys know when (or if) there will be more Matias Quiet Click V60 Mini keyboards in stock?
« Last Edit: Mon, 03 August 2015, 11:00:22 by nickheller »
Offline 00zeRO
  • * Moderator
« Reply #1202 on: Mon, 03 August 2015, 13:02:25 »
We hope to restock in the coming months.
Offline bcredbottle
« Reply #1203 on: Mon, 03 August 2015, 16:05:55 »
Matias/Alps springs. Please!
Offline 00zeRO
  • * Moderator
« Reply #1204 on: Mon, 03 August 2015, 16:23:45 »
we will look into it...
Offline bcredbottle
« Reply #1205 on: Mon, 03 August 2015, 19:34:31 »
I know it's a longshot but I'm sure lots of people would like some 72g springs to make their Matias switches feel more like Clears or Greens. You'd only need to offer one set of springs since the Matias switches are already super light
Offline dante
« Reply #1206 on: Sat, 08 August 2015, 12:22:27 »
Two things:
1. Any chance on stocking Rainbow or Milky/White Transparent Jelly POM's?  Chinese market just got restocked and these are available through Gateron I believe.  This would probably be fairly popular with the backlit crowd.
2. On the incoming KBT Next keyboards ... Are these using rebranded Gaterons?  I can't tell from the translations as some say it's Gateron and others say these these are a brand new switch.  If that's the case then what do folks do when replacements are needed?  Also will I heard rumors of a tenkeyless version .. true/false?
Offline 00zeRO
  • * Moderator
« Reply #1207 on: Sat, 08 August 2015, 23:30:44 »
Two things:
1. We are on this...stay tuned.
2. KBTalking switches are another brand that is not Gateron. Not sure if its to be a trade secret or not. What I can tell you is that they are an absolute joy to type on and I am a die hard fanboy of this other switch manufacturer.
Offline dante
« Reply #1208 on: Sun, 09 August 2015, 09:42:32 »
Two things:
Ok but what about replacement switches / tkl?
Offline tigersharkdude
« Reply #1209 on: Sun, 09 August 2015, 13:09:34 »
Random as hell, I want one of the Varmillo Keyboards spacebears that says "don't cry for me Argentina" in black
Offline 00zeRO
  • * Moderator
« Reply #1210 on: Mon, 10 August 2015, 10:51:06 »
Two things:
We plan to carry the very same KBTalking switches in singles/packs like our others.
Offline 00zeRO
  • * Moderator
« Reply #1211 on: Mon, 10 August 2015, 10:53:12 »
I have never seen a spacebear before...do they growl?
As for space bars, we are doing what we can to gain Varmilo as a brand...so...
Offline Data
« Reply #1212 on: Mon, 10 August 2015, 16:30:35 »
#WINNING
« Reply #1213 on: Mon, 10 August 2015, 16:41:09 »
I found a SpaceBear
My phone corrected it to  Spacebear.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #1214 on: Mon, 10 August 2015, 17:34:27 »
I found a SpaceBear
Autocorrect? You must talk about SpaceBears A LOT!
« Reply #1215 on: Mon, 10 August 2015, 17:37:45 »
I found a SpaceBear
kind of, i won one in the last binge sale and autocorrect kept changing it to spacebar so I changed spacebar to correct to spacebear
Offline RELLIK
  • WTB Bro Power Core WASD Set...Still...
« Reply #1216 on: Sun, 16 August 2015, 04:23:49 »
Any chance of the FC660M in black with MX reds? I loathe anything white because of eventual yellow =\
     KUL-87        FC660M       Filco MJ2
Offline dante
« Reply #1217 on: Sun, 16 August 2015, 09:30:34 »
Speaking of Leopold, that brand doesn't show up here: https://mechanicalkeyboards.com/search.php
Offline 00zeRO
  • * Moderator
« Reply #1218 on: Mon, 17 August 2015, 10:08:54 »
um, if you put Leopold as a search keyword it does...https://mechanicalkeyboards.com/search.php?keyword=leopold&switch_id=ALL&size=ALL&man=ALL&key_plastic=ALL&interface=ALL&cord_length=ALL&usb_kro=ALL&ps2_kro=ALL&x=0&y=0&in_stock=on. I will get with ShakeR and see what we can do about adding it to the brands...thanks for showing us
Offline 00zeRO
  • * Moderator
« Reply #1219 on: Mon, 17 August 2015, 10:12:21 »
Check again, I fixed it.
Thanks again, dante: the vigilant
Offline 00zeRO
  • * Moderator
« Reply #1220 on: Mon, 17 August 2015, 10:13:41 »
Our goal is to carry as many Leopold keyboards as we can...so yes, we do plan to carry other colors beyond white.
Offline dante
« Reply #1221 on: Mon, 17 August 2015, 12:30:24 »
Is there a way to preorder specific models from you in Leopold's catalog?  I already have the gray 660c I would like to get a white/gray 660c in the future.
Offline trees
  • I like bagels.
« Reply #1222 on: Tue, 18 August 2015, 14:03:40 »
Any chance you guys are going to stock the KBP v60's with gateron switches?
B.Face HHKB - B.mini - Black/Purple Custom
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1223 on: Tue, 18 August 2015, 14:13:22 »
+1   I would like to get a white FC750RT (A Korean made one with the fixed spacebar spacing).
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline trenzafeeds
  • **** off
« Reply #1224 on: Tue, 18 August 2015, 14:15:38 »
There isn't any chance of you guys stocking PCB mount gaterons in larger quantities for a lower price per switch, is there?
demik will never leave.
Unless he gets banned.
Offline 00zeRO
  • * Moderator
« Reply #1225 on: Tue, 18 August 2015, 21:01:57 »
We are working on this...
Offline trenzafeeds
  • **** off
« Reply #1226 on: Wed, 19 August 2015, 08:11:07 »
Yaaayyyy, that'd be amazing!  :thumb:
Offline 00zeRO
  • * Moderator
« Reply #1227 on: Wed, 19 August 2015, 10:27:10 »
Not sure if KBParadise wants to go with Gaterons...they seem to be cornering the market on 60% Matias Alps at the moment...
Offline trees
  • I like bagels.
« Reply #1228 on: Wed, 19 August 2015, 10:29:30 »
Ah, alright. I know they did the massdrop for them, i had assumed they were planning on making it an actual for sale product.
Offline Data
« Reply #1229 on: Wed, 19 August 2015, 16:31:08 »
I really wish you guys had MX Browns in stock.  I'm about to place another order for switches...   :'(
Offline 00zeRO
  • * Moderator
« Reply #1230 on: Wed, 19 August 2015, 16:41:17 »
Try Greetechs, they are awesome!
Offline trenzafeeds
  • **** off
« Reply #1231 on: Wed, 19 August 2015, 16:50:36 »
It's true, Greetechs are currently my go-to for blues at the very least. They do their tactility well.
Offline Data
« Reply #1232 on: Wed, 19 August 2015, 19:47:44 »
Mmm...   :-[  :-X
Offline 00zeRO
  • * Moderator
« Reply #1233 on: Wed, 19 August 2015, 20:13:37 »
Mmm...   :-[  :-X
To answer your original request, we hope to restock Cherry Brown MX switches soon.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #1234 on: Wed, 19 August 2015, 23:57:40 »
Last Night placed an order for your KBParadise TKL V80 Dolch Mechanical Keyboard (Matias Quiet Click)
SKU: KBP-V80MTS-Q-DOL
 Stock: Pre-Order Only
 Available for Pre-Order! Estimated Arrival: 11/05/15*
Even though it won't show up till the beginning of November 2015, still looking forward to seeing it when it arrives on my front door.
Nice to see the Vendor here giving us valuable info on what's happening with his company and incoming stock, we need more retailers like yourself here on Geekhack  :thumb: .
Offline 00zeRO
  • * Moderator
« Reply #1235 on: Thu, 20 August 2015, 12:09:13 »
Thank you for the order, and confidence. We certainly try our darndest.
Offline Data
« Reply #1236 on: Fri, 21 August 2015, 08:25:25 »
Mmm...   :-[  :-X
I need these like, now... so I'm going to pull the trigger on some Greetechs.  If they suck I blame you!!!
Offline 00zeRO
  • * Moderator
« Reply #1237 on: Fri, 21 August 2015, 10:47:05 »
Mmm...   :-[  :-X
You will like them...
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1238 on: Mon, 31 August 2015, 02:22:34 »
Seen that you guys got some FC750Rs about to come in.  Do you think that you will start stocking the white versions also?
Oh, and what about the white FC660C?
WTB/WTS/WTT ---->
Offline 00zeRO
  • * Moderator
« Reply #1239 on: Mon, 31 August 2015, 07:36:01 »
Our relationship with Leopold is still relatively new. We hope to be able to carry more capacitive type keyboards soon. And the white mx TKL is inevitable.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1240 on: Mon, 31 August 2015, 07:47:34 »
Okay cool. Please try to get the FC750RTs that accept standard spacebars. I think I read the Korean made ones do.
I don't know if all current new ones do by now, but some of the first 750Rs used the old Leopold spacebar spacing.
WTB/WTS/WTT ---->
Offline trenzafeeds
  • **** off
« Reply #1241 on: Mon, 31 August 2015, 14:48:34 »
These don't hold interest particularly to me, but I'm sure it would be a massive hit if you guys sold single or three-pack 6.5u spacebars in like a couple different basic colors.
Offline 00zeRO
  • * Moderator
« Reply #1242 on: Mon, 31 August 2015, 15:25:47 »
Good idea. We will certainly look into it. Thanks.
« Reply #1243 on: Wed, 02 September 2015, 16:18:46 »
Any chance you guys can sell the Leopold PBT caps seperately?
Like these?
http://www.ebay.com/itm/PBT-Keycap-Set-for-Cherry-MX-based-Leopold-Keyboard-Front-Face-Englih-Black-/281377716241
Specifically looking for side print black.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1244 on: Fri, 04 September 2015, 00:19:16 »
What about stocking some of the gold plated Cherry stabilizers that Sprit makes (PCB & Plate mount)?
Are the gold springs on your website Sprit's?
WTB/WTS/WTT ---->
Offline ATXTider
  • I keep it playa while some choose to play it safe
« Reply #1245 on: Wed, 09 September 2015, 11:04:38 »
Will you guys be restocking KUL's?  I noticed their logo disappeared off your site a while back.
Offline 00zeRO
  • * Moderator
« Reply #1246 on: Wed, 09 September 2015, 12:38:28 »
No, we will no longer be stocking Keyed Up Lab keyboards. Once we sell our remaining inventory, adios to them.
Offline ATXTider
« Reply #1247 on: Wed, 09 September 2015, 12:56:40 »
Offline 00zeRO
  • * Moderator
« Reply #1248 on: Wed, 09 September 2015, 13:20:25 »
Did you have a specific item in mind? Please email us at support@mechanicalkeyboards.com because we may have an open box keyboard with your name on it.  :cool:
Offline saturnotaku
« Reply #1249 on: Thu, 10 September 2015, 09:37:10 »
Stock of their keyboards has all but evaporated across the board with no whiff of new inventory for the last several months. According to one post on Facebook, they are supposedly replenishing their supplies, but that was several weeks ago.
As a seller, I'm hoping there might be some insight that you could share, if you are permitted to do so.
